Paddie 3rd Gear June 30, 2008 Share June 30, 2008 Basically, the flaps are not working (in my case, 1 is broken) so outside air can come in. What Ah Huat did was sealed up the opening and disconnect the wire so that recirculation mode is always ON. No more smell from outside. Total time taken - 15 mins, total cost - $15. Money well spent if you asked me. No need to feel like smelling poison gas when lorries are near you. I'm not sure it's a good idea to completely seal the flap. On longer drives (esp to Malaysia) you should switch off the recirculation at least once in a while to get fresh oxygen in the car, otherwise you will feel sleepy very easily. Also, by never letting fresh air into the air-con system, mould grows faster on the air-con coil and that's the source of the sour smell from the air-con after a while. ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 30, 2008 Author Share June 30, 2008 I will live with it. If need fresh air, juz wind down the windows lor. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 30, 2008 Author Share June 30, 2008 oic...do any bros here knows any air con servicing around the east...i am staying at tampines...thanks! hope to solve my condition as well... Juz go to Markcool and get it done with lah. I am also staying in the east wat, Eunos. Link to post Share on other sites More sharing options...
Tomcat Neutral Newbie June 30, 2008 Share June 30, 2008 actually, why did he not recommend replacement instead? Link to post Share on other sites More sharing options...
Ultramega 1st Gear June 30, 2008 Share June 30, 2008 So what about your dashboard no light problem? Could be the fuse. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 30, 2008 Author Share June 30, 2008 Replacement is not cheap. Mine's an old car anyway. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 30, 2008 Author Share June 30, 2008 That one not solved yet, never bring down. Anyway, it's only the odometer part very dimmed so maybe will juz leave it. Link to post Share on other sites More sharing options...
Weixiang_2008 Clutched June 30, 2008 Share June 30, 2008 thanks for ur findings Link to post Share on other sites More sharing options...
Jtb 6th Gear May 4, 2013 Share May 4, 2013 i keep getting outside air intermittenly under recirculation mode and checked the fresh air on-off mode is working fine. Anybody has this problem with FD1? it kicks in to receive outside air for awhile and back to recirculation! Link to post Share on other sites More sharing options...
5936 1st Gear May 4, 2013 Share May 4, 2013 Some foreign objects such as leaves or twig may be blocking the flap, Or seals around flap, usually sponge, may have degraded. Since A/C is usually on preferred re-circulatiion made almost all the time, you can tape the flap down to kep it at " permanent re-circulation" mode. Link to post Share on other sites More sharing options...
Jtb 6th Gear May 4, 2013 Share May 4, 2013 Some foreign objects such as leaves or twig may be blocking the flap, Or seals around flap, usually sponge, may have degraded. Since A/C is usually on preferred re-circulatiion made almost all the time, you can tape the flap down to kep it at " permanent re-circulation" mode. can i diy as trying to locate to seal? Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 4, 2013 Share May 4, 2013 i keep getting outside air intermittenly under recirculation mode and checked the fresh air on-off mode is working fine. Anybody has this problem with FD1? it kicks in to receive outside air for awhile and back to recirculation! Try setting temperature setting to 22 degree and below Link to post Share on other sites More sharing options...
5936 1st Gear May 4, 2013 Share May 4, 2013 Yes, Very easy. Find the AC filter location. usually behind glove compartment. The flap is around there. Aluminium tape works better than duct or masking tape. Link to post Share on other sites More sharing options...
Jtb 6th Gear May 4, 2013 Share May 4, 2013 Try setting temperature setting to 22 degree and below temp was set at 22, outside odour sucked in while passing by a canal. Link to post Share on other sites More sharing options...
Kklim Supercharged April 11, 2023 Share April 11, 2023 Been having this odd problem when I'm on the road: recirculation mode (usually On all the time) goes Off (can feel outside air coming in) and comes back On again after about 20 seconds. What could be causing this? Link to post Share on other sites More sharing options...
Volvobrick Supersonic April 11, 2023 Share April 11, 2023 On 4/11/2023 at 3:26 PM, Kklim said: Been having this odd problem when I'm on the road: recirculation mode (usually On all the time) goes Off (can feel outside air coming in) and comes back On again after about 20 seconds. What could be causing this? Mercedes? Alway auto off. Very irritating. Link to post Share on other sites More sharing options...
Kklim Supercharged April 11, 2023 Share April 11, 2023 On 4/11/2023 at 3:33 PM, Volvobrick said: Mercedes? Alway auto off. Very irritating. 13-year-old Nissan Sylphy. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 11, 2023 Share April 11, 2023 On 4/11/2023 at 3:26 PM, Kklim said: Been having this odd problem when I'm on the road: recirculation mode (usually On all the time) goes Off (can feel outside air coming in) and comes back On again after about 20 seconds. What could be causing this? It is program to open and let in fresh outside air during a long drive. The reason is that you wont be breathing too much of your own carbon dioxide and feel sleepy. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
DIY Air Con Recycle Mode Default On For Hyundai Matrix
Elon Musk: Come to work or stay home forever!
Anyone applied for or working at Car companies? Need help.
Start/ Stop function not working = weak battery?
Home SingTel Fixed line not working
My experience working in civil service...
