To leave in neutral?
Is it advisable to shift to neutral gear when say I am stuck in a traffic jam for auto transmission car? Will this additional gear change do any damage to the gear box?
u can engage in N...
when the lights turn green, floor the accelerator then push the gear to D...
no lah, just joking [sly][sly][sly]
personally i think engaging N once in a while is ok...
modern gear system won't damage so easily...
Personally I feel its not necessary to switch to 'N' unless under those traffic condition which is totally not moving at all, lets say if you are in 'N' position and suddenly the car in front of you moves, will you be in a hurry to switch back to 'D' and move off ? This will result in damaging the auto g/box in the long run if you do it often.
Edited by Kawarides
Shift D --> N --> D will cause wear n tear to tranny but less vibration
U gotta weight the cost and benefit lor
just leave in "D". if your leg tired just pull handbrake.
stick to D will put a stress to brake pad but can launch anytime
Holding the car stationary using the brakes does not wear the brake pads out. There is no friction between the pads and the discs, so how can they wear out? Imagine you take an eraser and just push it down onto a piece of paper. Does it wear out? Only when you rub it then it will.
