Ixat 1st Gear November 20, 2008 Share November 20, 2008 Hi bros, can feel my car vibrating when at idle in the morning before moving off. This is even after the "engine temp cold" light goes off. After driving around for 5-10min and when at traffic light the car do not vibrate anymore, totally still, almost can't feel engine on. Is there some other fluids thats not warmed up yet tat cause the pre-move-off-at-idle vibration? Or is it time to change engine mount anyhow? Its a 1.6M Hyundai Getz. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Fortress Clutched November 20, 2008 Share November 20, 2008 (edited) If I may ask how old is the car, mileage, any change in spark plugs recently(or when). Usually it is quite straight forward. Cold engine or low in lub oil, are also possible reasons. Edited November 20, 2008 by Fortress Link to post Share on other sites More sharing options...
Ixat 1st Gear November 20, 2008 Author Share November 20, 2008 Hi Fortress, thanks for your reply! Car is 3yrs in next month and mileage is 86K. Last serviced 6K ago with Amsoil 5W30 and OEM copper plugs. Engine oil is at 50% between low and full on the dipstick. Could it be that although the engine cold light is off, the temperature is still not really warmed up sufficiently and that caused the vibration? Link to post Share on other sites More sharing options...
Fortress Clutched November 20, 2008 Share November 20, 2008 It could be the case of cold engine, but you probably would have noticed it after all this time. 50% between stick is a probably the case of slow warm up.. Link to post Share on other sites More sharing options...
Unltd 5th Gear November 20, 2008 Share November 20, 2008 In Singapore unlikely it is due to temperature that causes vibration, it is better to go mechanic to check and likely it is due to cracked engine mount. There are many old cars that do not bother to change until the engine mount vibration is too huge, it is your preference... Link to post Share on other sites More sharing options...
Shiwao Clutched June 26, 2009 Share June 26, 2009 (edited) Resurrecting this Bros, just to check one thing 1) car just hit 60K maintaince and AD said engine mount rubber has almost worned. said if I want to change, and that costs $700 b4 GST. 2) battery pan corroded to change is $125 b4 GST Anywhere else can I go? Any advises? Please. Am driving Mazda 2 TIA! Edited June 26, 2009 by Shiwao 1 Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear June 26, 2009 Share June 26, 2009 (edited) Resurrecting this Bros, just to check one thing 1) car just hit 60K maintaince and AD said engine mount rubber has almost worned. said if I want to change, and that costs $700 b4 GST. 2) battery pan corroded to change is $125 b4 GST Anywhere else can I go? Any advises? Please. Am driving Mazda 2 TIA! Try City Auto The price should be cheaper Edited June 26, 2009 by Mzrmazda3 Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 26, 2009 Share June 26, 2009 Resurrecting this Bros, just to check one thing 1) car just hit 60K maintaince and AD said engine mount rubber has almost worned. said if I want to change, and that costs $700 b4 GST. 2) battery pan corroded to change is $125 b4 GST Anywhere else can I go? Any advises? Please. Am driving Mazda 2 TIA! just go to Mazda stockits to buy the engine mounts, much cheaper and then get workshop to change, labour should be less than $100. Link to post Share on other sites More sharing options...
Shiwao Clutched June 26, 2009 Share June 26, 2009 okie bros darn sian, last week CEL came on, changed one knock sensor, carrot headed for $328 Guess I'll have to make a run to the stockist tomorrow. Thanks all. Link to post Share on other sites More sharing options...
Enduro25 Clutched June 28, 2009 Share June 28, 2009 i also driving a getz ard the same age as ur car..just gone for servicing 2day.the mechanic suddenly pop up a question asking mi am i going to change my car?is best to change ur car now as ur engine is still ok cos tats sumthing wrong wif ur engine..i stunned for awhile ..cos he is saying tats some sound inside my engine(like some coins washing in the washing machine)..the onli problem is to overhauled the engine which is ard 5k.. i had been servicing my car on time for 3 yrs..hai~dun even noe wat causes this.. 1 Link to post Share on other sites More sharing options...
Poortraveller 1st Gear June 28, 2009 Share June 28, 2009 kah motor Link to post Share on other sites More sharing options...
Kotila Clutched June 28, 2009 Share June 28, 2009 why kah motor????? 1 Link to post Share on other sites More sharing options...
Ixat 1st Gear June 28, 2009 Author Share June 28, 2009 i also driving a getz ard the same age as ur car..just gone for servicing 2day.the mechanic suddenly pop up a question asking mi am i going to change my car?is best to change ur car now as ur engine is still ok cos tats sumthing wrong wif ur engine..i stunned for awhile ..cos he is saying tats some sound inside my engine(like some coins washing in the washing machine)..the onli problem is to overhauled the engine which is ard 5k.. i had been servicing my car on time for 3 yrs..hai~dun even noe wat causes this.. Bro that sounds scary. Good to get a 2nd opinion before making any decisions. BTW whats your engine cap? Link to post Share on other sites More sharing options...
Watwheels Supersonic June 28, 2009 Share June 28, 2009 i also driving a getz ard the same age as ur car..just gone for servicing 2day.the mechanic suddenly pop up a question asking mi am i going to change my car?is best to change ur car now as ur engine is still ok cos tats sumthing wrong wif ur engine..i stunned for awhile ..cos he is saying tats some sound inside my engine(like some coins washing in the washing machine)..the onli problem is to overhauled the engine which is ard 5k.. i had been servicing my car on time for 3 yrs..hai~dun even noe wat causes this.. That kinda sound/noise could be from the faulty tappets. Our family car used to have that noisy coin clinging sound, after the tappets were changed, no more such noise. Get a outside workshop mechanic to give a 2nd opinion. Tappet Link to post Share on other sites More sharing options...
Yuan 6th Gear June 28, 2009 Share June 28, 2009 just go to Mazda stockits to buy the engine mounts, much cheaper and then get workshop to change, labour should be less than $100. Yup. Agreed. Unless TS has some trusted workshops where they can bring in the oem/stock mounts at cheaper prices and install for a labour cost. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 28, 2009 Share June 28, 2009 i also driving a getz ard the same age as ur car..just gone for servicing 2day.the mechanic suddenly pop up a question asking mi am i going to change my car?is best to change ur car now as ur engine is still ok cos tats sumthing wrong wif ur engine..i stunned for awhile ..cos he is saying tats some sound inside my engine(like some coins washing in the washing machine)..the onli problem is to overhauled the engine which is ard 5k.. i had been servicing my car on time for 3 yrs..hai~dun even noe wat causes this.. Get a second or a third opinion. Overhauling of engine is quite a big issue and cost matter. Link to post Share on other sites More sharing options...
Enduro25 Clutched June 28, 2009 Share June 28, 2009 im driving a 1.4cc.. Link to post Share on other sites More sharing options...
Enduro25 Clutched June 28, 2009 Share June 28, 2009 so any trustworthy wkshop for mi to go to hv this problem rectify? ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
