Enduro25 Clutched November 25, 2008 Share November 25, 2008 My poor car cross about 50 speed humps a day, excluding speed regulating strips. This type of usage, how long can the shock absorbers last? Can last 10 years? I tried bouncing the car, but the suspension is too firm, I can hardly move it. My wife ill treat the car by crossing the humps at up to 60 km/h. go for check and change if there's a need... ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear November 25, 2008 Share November 25, 2008 Bro, with your kind of usage plus your Bor zooming pass humps at 60km/hr, your shocks would definately have an earlier retirement as compared. Jap rides normally have their stock shocks leaking at around 60,000-80,000km subject to the kind of treatment which they received from their drivers Link to post Share on other sites More sharing options...
Porche 5th Gear November 25, 2008 Share November 25, 2008 just changed nia...first new set Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie November 26, 2008 Author Share November 26, 2008 When u go over those humps, does the car keep bouncing? Do u feel the handling sloppy going around fast corners? When u brake, does the front dive very low? All these r signs of worn shocks. If your mech checked & say its OK, he sud know then. Answer to the above is NO, it feels okay except for the creak sound (notice it more when the car is cold) My mech NEVER check one, he just says dampers are expensive and dont need to change. If I listen him, everything also do not need to change. Only need to repair if the car cannot move. Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie November 26, 2008 Author Share November 26, 2008 I am at 120,000km (4 years old), dampers seem to be damping well except for the creaking sound. I think I will change them at 150K since times are bad. Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie November 26, 2008 Author Share November 26, 2008 So far leak not detected, looks pretty dry, or maybe the shocks are gas driven and not oil driven. Link to post Share on other sites More sharing options...
Boopoo Neutral Newbie November 26, 2008 Share November 26, 2008 change mine at 70000km kyb Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 27, 2008 Share November 27, 2008 Sometimes the "creak" sound cud b caused by the springs or worn or dry bushings. Sometimes some spray lube might help but only temporary. Link to post Share on other sites More sharing options...
Yellowrx8 Clutched November 27, 2008 Share November 27, 2008 Mine rear suspension is getting softer... Wat could be the problem? Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie November 27, 2008 Author Share November 27, 2008 Dont think caused by springs, but spraying lube is dangerous as it may get onto the rotors, after that got no brakes. Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie November 27, 2008 Author Share November 27, 2008 Time to change your shock absorbers and burn a lot of cash Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 29, 2008 Share November 29, 2008 Normally its the shocks which r wearing out. Springs seldom get soft unless u overload your car often. Link to post Share on other sites More sharing options...
Yellowrx8 Clutched November 29, 2008 Share November 29, 2008 Thanks broz... Noted. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 29, 2008 Share November 29, 2008 The lube is sprayed at the bushings. Use the thin long plastic tube to direct it directly to the moving parts of the bushings. I used to do it regularly for my previous car which used to squeak at the bushings. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 29, 2008 Share November 29, 2008 No problem. We share advice in MCF. Link to post Share on other sites More sharing options...
Shull Turbocharged December 4, 2008 Share December 4, 2008 (edited) bro, don't mine me tumpang your thread.. since abt 2yrs back, my ride has become more and more bumpy..esp when i go thru hump, totally got no damping..then when i went for servicing, my mechanic told me that my 2 rear absorber spoilt liao..oil is leaking from them.. he recommended me to change the 2 shocks only as the spring is still in good condition.. my car is coming to 6yo next jan, mileage is 140,000km..so i would like to know whether it's advisable to change the absorber or not..and approx how much is the damage? also, if i want to change all 4 side to coilovers, how much will the damage be? Edited December 4, 2008 by Shull Link to post Share on other sites More sharing options...
Pjlee25 Neutral Newbie December 6, 2008 Share December 6, 2008 roughly how much is the cost of changing shocks and springs for jap cars? Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie December 8, 2008 Author Share December 8, 2008 I dont know your car model etc, so how to guess? You can be sure that the price difference between a lambo and chery is a lot. If anyhow guess, I think two shocks will set you back about $500 inclusive of labour if you use ORIGINAL parts. Should be cheaper if you use OEM parts or others. ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Budget 2025 - February 2025.
Change Disc Rotors
Change Disc Rotors
X for twitter change request
