D325 Neutral Newbie October 16, 2009 Share October 16, 2009 the drop in filter is the same as the Gen 2 or Persona. Meaning to say if you can find a gen 2 drop in filter, it can fit your exora... one more thing i left out when considering this car... its the fuel consumption... on paper... it claim that it can do about 13.8km/l... but i told myself... with such a small engine and big body... 13.8 must be b-------t... if it can do 10... i'm more than happy... right now i'm doing about 9 - 10... with 50% highway and 50% city driving... i'm quite a heavy footer... i believe that a wish or stream is doing about 10 - 12? not sure also... i'm quite ok with the fuel consumption because bigger car definately use more petrol... just have to get used to it... hope that the F/C will get better with the newly installed filter... which i think chances are low... it gives a better driving experience is good enuff... i'll be installing my NGK irdium plugs on my next servicing... do bit by bit... den u feel the difference... if all go in at one go... no fun liao... =] ↡ Advertisement Link to post Share on other sites More sharing options...
Blackhawk Neutral Newbie October 16, 2009 Share October 16, 2009 Hi D325, Do you use Ron 95? How many litres of fuel are required to fill an empty tank? Can share? Tks. Link to post Share on other sites More sharing options...
Mustang 1st Gear October 16, 2009 Share October 16, 2009 the drop in filter is the same as the Gen 2 or Persona. Meaning to say if you can find a gen 2 drop in filter, it can fit your exora... one more thing i left out when considering this car... its the fuel consumption... on paper... it claim that it can do about 13.8km/l... but i told myself... with such a small engine and big body... 13.8 must be b-------t... if it can do 10... i'm more than happy... right now i'm doing about 9 - 10... with 50% highway and 50% city driving... i'm quite a heavy footer... i believe that a wish or stream is doing about 10 - 12? not sure also... i'm quite ok with the fuel consumption because bigger car definately use more petrol... just have to get used to it... hope that the F/C will get better with the newly installed filter... which i think chances are low... it gives a better driving experience is good enuff... i'll be installing my NGK irdium plugs on my next servicing... do bit by bit... den u feel the difference... if all go in at one go... no fun liao... =] Sure can improve,My mom in law gets an average 11.5 km/l 50% highways and 50% city.Average speed 100kmh Link to post Share on other sites More sharing options...
D325 Neutral Newbie October 16, 2009 Share October 16, 2009 (edited) i used 95 for my first tank... engine was loud and less power... but when i filled my second tank with 98... not so loud and slightly more powerful.... but dunno if its me... or its really that case... i was thinking of reverting to 95... cos i hear that 95 gives better FC... the most petrol i ever pumped in was 58 litres... i dried my tank in m'sia and i pumped 58 litres in... =] Edited October 16, 2009 by D325 Link to post Share on other sites More sharing options...
D325 Neutral Newbie October 16, 2009 Share October 16, 2009 Sure can improve,My mom in law gets an average 11.5 km/l 50% highways and 50% city.Average speed 100kmh den i better quickly change my plugs... petrol is damn expensive! Link to post Share on other sites More sharing options...
Babyt 4th Gear October 16, 2009 Share October 16, 2009 (edited) my 2l qashqai can give 10km/l avg yet 1.6l exora gives around 11km/l.... same 50%highway 50%city Edited October 16, 2009 by Babyt Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 16, 2009 Share October 16, 2009 den i better quickly change my plugs... petrol is damn expensive! don b surprise u c no result......don xpect SP to do wonders Link to post Share on other sites More sharing options...
GoodCar 4th Gear October 16, 2009 Share October 16, 2009 my 2l qashqai can give 10km/l avg yet 1.6l exora gives around 11km/l.... same 50%highway 50%city Got use correct tyre pressure? Link to post Share on other sites More sharing options...
Panhard 1st Gear October 16, 2009 Share October 16, 2009 my 2l qashqai can give 10km/l avg yet 1.6l exora gives around 11km/l.... same 50%highway 50%city though one is 2.0L & the other 1.6L but both weight around 1.4ton. so which gives better FC? Link to post Share on other sites More sharing options...
Sktan10 5th Gear October 16, 2009 Share October 16, 2009 though one is 2.0L & the other 1.6L but both weight around 1.4ton. so which gives better FC? I think he means 2.0L vs 1.6L difference in FC is only 1km/L. To be frank,not so worth cos hardly have any big saving in FC between the two. In terms of power,there's a big difference. One advantage is only saving in road tax $48/mth. Link to post Share on other sites More sharing options...
Mustang 1st Gear October 16, 2009 Share October 16, 2009 An eye for an eye la,How can compare 1.6 with 2.0?The 2 litre got extra hp and torque plus bigger displacement hence the advantage.Unless Exora is turbocharged but still give 11l then its different. Link to post Share on other sites More sharing options...
Sktan10 5th Gear October 17, 2009 Share October 17, 2009 An eye for an eye la,How can compare 1.6 with 2.0?The 2 litre got extra hp and torque plus bigger displacement hence the advantage.Unless Exora is turbocharged but still give 11l then its different. Since the FC falls into almost a 2.0 category,is naturally for people to compare it with a 2.0L NA car. Same FC means not going to save much on petrol,why 1.6L instead of 2.0L,right?Unless one really likes the car alot. I believe qashqai is running on 17" rims whereas exora is 15". If ignore the FC part,exora is a good choice eps cheapest among all mpv. Link to post Share on other sites More sharing options...
Doosan 1st Gear October 17, 2009 Share October 17, 2009 bro, jz ot abit, jz read fr www.malaysiakini.com that proton arena was almost kena ban by nz authority of securing 1star in nz ancap rating? kiwi recommended that this arena should not be on the road Link to post Share on other sites More sharing options...
Mustang 1st Gear October 17, 2009 Share October 17, 2009 bro, jz ot abit, jz read fr www.malaysiakini.com that proton arena was almost kena ban by nz authority of securing 1star in nz ancap rating? kiwi recommended that this arena should not be on the road Aussie use this pick up(Jumbuck) for almost any ocassion and right now they just start to test the safety rating,Too late liao.That Jumbuck(Arena) is only 1990s technology bro,No airbag,ABS,etc..I can alomst see it in every small town or village in Australia Link to post Share on other sites More sharing options...
D325 Neutral Newbie October 19, 2009 Share October 19, 2009 ya la... but so far... whenever i change the spark plugs... i see difference... FC may not change much... but driving experience definately better... Link to post Share on other sites More sharing options...
D325 Neutral Newbie October 19, 2009 Share October 19, 2009 i would say that its value for money.... its not the cheapest among all MPVs... cos there's still china makes and smaller MPVs... like the APV... it cost slightly more den $50k... but its converted from a van technology... looking at the outlook... its like a van... but very good space also... bad thing is... its a suzuki... but made in indonesia... like i mentioned earlier... what i like about this car is that this car is fully designed and tuned by lotus... european design for the price tag of a japanese sedan... even the signal is on the left side... like those european cars... i used to feel that space in between the 2 front seats is very empty... because there's no centre console... only 2 holes for you to put in your waterbottles... so i went m'sia in search of a centre console.... 80RM and viola! i've a centre console that i can rest my hand and also to put some stuff in in... after i put the console... i realised why they designed the car without the console.... because when i drive... i tend to leave my left hand on the console... and drive with my right hand... as a result of that... I DON'T SIGNAL... aaahaha... just my 2 cents worth.... =] Link to post Share on other sites More sharing options...
Caaa Clutched October 19, 2009 Share October 19, 2009 How much is Suzuki APV cheaper than Proton Exora? Good to know u enjoy your car.... Link to post Share on other sites More sharing options...
Doosan 1st Gear October 19, 2009 Share October 19, 2009 tks bro, i watch documentary film every tuesday nite that these kagaroos always chk every damm barang2 that entering their country (for security reasons) , y they dont test/chk tis jumpback then, importer down there kelong oredi kah? ↡ Advertisement Link to post Share on other sites More sharing options...
Vincar to distribute Proton’s first electric vehicle in Singapore
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Proton X50
Proton X50
Proton eMas 5 previewed – rebadged Geome Xingyuan, RWD, 250 to 325 km WLTP
Proton overseas
Proton overseas
New Proton Perdona.
New Proton Perdona.
Proton To Introduce smart Electric Vehicles In Malaysia
