Rayleigh 6th Gear August 10, 2016 Share August 10, 2016 Shouldn't the total unshaded A+B = 1/4 + 1/4 = 1/2 ? No it shouldnt be cos it is not summation but proportional. For example, Item A given 20% discount and Item B given 20% discount, the net discount is still 20% off the combine cost. ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic August 10, 2016 Share August 10, 2016 No it shouldnt be cos it is not summation but proportional. For example, Item A given 20% discount and Item B given 20% discount, the net discount is still 20% off the combine cost. Ha, I would fail psle maths nowadays. 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic August 10, 2016 Share August 10, 2016 Shouldn't the total unshaded A+B = 1/4 + 1/4 = 1/2 ? No. It's bad practice to reuse A and B for the areas since those are already defined in the question. So let's use x for the area of the biconvex (eye of Sauron/cat's pupil) shape and y for the smaller area. Unshaded area = 3y + x Total area = 12y + 4x = 4(3y + x) So unshaded area = 1/4 of the total. 1 Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear August 12, 2016 Share August 12, 2016 Dear psle maths gurus. Pls help contribute the answer.....hehehe. Link to post Share on other sites More sharing options...
Ender Hypersonic August 12, 2016 Share August 12, 2016 (edited) Dear psle maths gurus. Pls help contribute the answer.....hehehe. The shaded area has the same area as the 9 x 5 trapezium. Reason is since both triangles are identical and have the same overlapping area. So the "non-overlapped" area are the same for both triangle. Just apply the trapezium formula for area, or for p6, will be split the trapezium into a 6 x 5 rectangle and a 3 x 5 triangle and add them up Edited August 12, 2016 by Ender 1 Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear August 12, 2016 Share August 12, 2016 The shaded area has the same area as the 9 x 5 trapezium. Reason is since both triangles are identical and have the same overlapping area. So the "non-overlapped" area are the same for both triangle. Just apply the trapezium formula for area, or for p6, will be split the trapezium into a 6 x 5 rectangle and a 3 x 5 triangle and add them up You are the man!!! Link to post Share on other sites More sharing options...
Topspin 2nd Gear August 12, 2016 Share August 12, 2016 The shaded area has the same area as the 9 x 5 trapezium. Reason is since both triangles are identical and have the same overlapping area. So the "non-overlapped" area are the same for both triangle. Just apply the trapezium formula for area, or for p6, will be split the trapezium into a 6 x 5 rectangle and a 3 x 5 triangle and add them up Clap clap Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear August 12, 2016 Share August 12, 2016 (edited) Can I treat it as 1 unshaded triangle = 1/2 x 5 x 3 = 7.5. The other 5 shaded triangle is equally identical so 7.5 x 5 = 37.5 cm2 Like this ok? But im not comfortable doing this way bcos I totally skip making use of 9cm. How do you make use of all 9cm 3cm 5cm information and solve it using rect + tri combination? The shaded area has the same area as the 9 x 5 trapezium. Reason is since both triangles are identical and have the same overlapping area. So the "non-overlapped" area are the same for both triangle. Just apply the trapezium formula for area, or for p6, will be split the trapezium into a 6 x 5 rectangle and a 3 x 5 triangle and add them up Edited August 12, 2016 by Hiphiphoray Link to post Share on other sites More sharing options...
Ender Hypersonic August 12, 2016 Share August 12, 2016 (edited) Can I treat it as 1 unshaded triangle = 1/2 x 5 x 3 = 7.5. The other 5 shaded triangle is equally identical so 7.5 x 5 = 37.5 cm2 Like this ok? But im not comfortable doing this way bcos I totally skip making use of 9cm. How do you make use of all 9cm 3cm 5cm information and solve it using rect + tri combination? Yes, you can treat is as 5 little triangles. But what I would do is recognised that the trapezium on the right is exactly the same area as the shaded area as explained earlier. The trapezium formula = (9+6)/2 X 5 = 37.5 cm2 Edited August 12, 2016 by Ender 1 Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear May 22, 2019 Share May 22, 2019 PSLE Maths 2018 Q 28 (2 marks) - actual question Can somebody help me to answer this question...….in as simpler form as possible suitable for a 12 year old kid to absorb. Thank you. Jasmin formed two cuboids with unit cubes. The length, breadth and height of the bigger cuboid are 2 times those of the smaller cuboid. She used 384 unit cubes to form the bigger cuboid. How many unit cubes did she use to form the smaller cuboid? I got the answer by trial & error via the factors of 384. Wonder if there is a simpler answer. PS....I personally feel that the actual PSLE Maths Exam is a lot easier than the SA2 paper of some schools....(namely Nan Hua, Rosyth, Raffles....they set unbelievable difficult questions!! Put unnecessary stress on students.) Link to post Share on other sites More sharing options...
Ender Hypersonic May 22, 2019 Share May 22, 2019 Visualise by stacking cubes. Use match boxes. The bigger cuboid whose length, breath and height is twice the smaller will be 8 times bigger in volume.. 384/8 =48? Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear May 22, 2019 Share May 22, 2019 hmmm...make sense. 2U : 1U --> 4x4x4 : 2x2x2 = 64 : 8 ( 8 times bigger) hence 348/8 = 48. U are really good in P6 Maths. Thanks. Link to post Share on other sites More sharing options...
1fast1 Supersonic May 22, 2019 Share May 22, 2019 PSLE Maths 2018 Q 28 (2 marks) - actual question Can somebody help me to answer this question...â¦.in as simpler form as possible suitable for a 12 year old kid to absorb. Thank you. Jasmin formed two cuboids with unit cubes. The length, breadth and height of the bigger cuboid are 2 times those of the smaller cuboid. She used 384 unit cubes to form the bigger cuboid. How many unit cubes did she use to form the smaller cuboid? I got the answer by trial & error via the factors of 384. Wonder if there is a simpler answer. PS....I personally feel that the actual PSLE Maths Exam is a lot easier than the SA2 paper of some schools....(namely Nan Hua, Rosyth, Raffles....they set unbelievable difficult questions!! Put unnecessary stress on students.) This is a similarity question asked before they've learned about similarity (Secondary subject). Volume ratios are the cube of the side ratios. Anyway they've done basic algebra in P6, so just say that small cuboid volume is xyz but large cuboid volume is (2x)(2y)(2z)=(2)(2)(2)xyz = 8xyz. That's how you get eight times lol. 1 Link to post Share on other sites More sharing options...
Ender Hypersonic May 22, 2019 Share May 22, 2019 This is a similarity question asked before they've learned about similarity (Secondary subject). Volume ratios are the cube of the side ratios. Anyway they've done basic algebra in P6, so just say that small cuboid volume is xyz but large cuboid volume is (2x)(2y)(2z)=(2)(2)(2)xyz = 8xyz. That's how you get eight times lol. Trust you to come out with the mathematical proof. Link to post Share on other sites More sharing options...
1fast1 Supersonic May 22, 2019 Share May 22, 2019 Trust you to come out with the mathematical proof.Haha. Get em while they're young, is what I say. All this nonsense about units and blocks just rots the brain. It's as much math as physics is about feelings and motivations of particles. Link to post Share on other sites More sharing options...
Ender Hypersonic May 22, 2019 Share May 22, 2019 hmmm...make sense. 2U : 1U --> 4x4x4 : 2x2x2 = 64 : 8 ( 8 times bigger) hence 348/8 = 48. U are really good in P6 Maths. Thanks. Last time my son was P6, I have to do the other schools exam paper together with him.. Now I drop to P4 standard liao, coz my daughter is in P4, and I am giving her the same math training as I gave my son. Link to post Share on other sites More sharing options...
mersaylee Hypersonic May 22, 2019 Share May 22, 2019 This is a similarity question asked before they've learned about similarity (Secondary subject). Volume ratios are the cube of the side ratios. Anyway they've done basic algebra in P6, so just say that small cuboid volume is xyz but large cuboid volume is (2x)(2y)(2z)=(2)(2)(2)xyz = 8xyz. That's how you get eight times lol. Whenever I see math question I need the greenWhenever I see explanation by others I need the blue Whenever I see your post... 2 packs of red also not enough to cure the migraine 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic May 23, 2019 Share May 23, 2019 Whenever I see math question I need the green Whenever I see explanation by others I need the blue Whenever I see your post... 2 packs of red also not enough to cure the migraine Lol!! ↡ Advertisement Link to post Share on other sites More sharing options...
All the best to parents of PSLE candidates
Own up, do you surf pornhub? 🤔
PSLE Math: Is It Really That Tough? How Should Students Tackle Difficult Questions In The Exam?
Math Question
Math Question
PSLE exams.... what is it for???
Question on Transfer of Car Ownership
Question for Car Servicing
