Tire pressure monitoring system (TPMS)
Achtung
May I ask the avg labour cost for tpms installation? Want to change it together with new tyre but in case the tyre shop charge a carrot price
My tyre shop always do it for free (internal sensors) when I change the tyres. Just buy the tpms from shopee etc.
  • Praise 2
Can intro which tyre shop u usually go to?
Bought these TPMS the valve screw in type and one day the screen went blank with no readings.
The screw plug batt went dead? How long are they suppose to last? 6mths or 1yr??
So basically is to throw away if that happens and get another brand new set as its relatively cheap.
LoL. What did you buy? Got at least a pic to show?
No display means battery flat. Charge the display unit? If the sensor batt is about to go flat usually there is a visual and sound warning. Usually run by a button battery. Easy to replace with the tool provided.
Edited by Watwheels
Display unit is all good and bright except no reading with  a - - - -  for all 4. And yes... It kept on pee pee pee then.
The valve looks like a concealed unit. Shall get the small spanner equipped to see whether it could be opened.
Battery is 1632 size button. There should be some small tools that came with the set to swap out the batteries. I think you can buy the batts from daiso if not Japan home.
It’s the valve battery bro. Just change them and they are good to go.
All went flat at the same time? Did you try to reset the reading? After you reset it should stop beeping then you have to drive to a certain speed for it to get back a reading. At stationary it cannot get a reading.
Yours is external sensor or internal sensor?
Edited by Watwheels
2 hours ago, Hamburger said:
Decided to try another one. So just wait for it.
I am using this set for the vezel.
Brought in November 2020. No issue with battery except the regular Batt charge up once every 3 weeks.
Thanks for the heads up. Me gonna just stuck it in the 12V socket, for convenient sake.
Sorry, I thought have posted the picture.😂 Getting old.
Anyway cost around 30 plus. Using power bank toncharge it up once every three week.
Edited by Kopites
i bought mine in 2020 too... less than $20
changed battery once (DIY)
but recently start to leak... tyre pressure dropping from 2.3bar to 1.9bar in 2-3 days
did a check, confirmed leaking from the sensors
now thinking of changing to the better internal ones
