Hjteo 1st Gear December 12, 2009 Share December 12, 2009 Did the mech confirm with a cooling system pressure test? any compression test done as well? Got to weigh the pros and cons of each. Replace gasket - Labour is probably $200. parts depends - parts for top overhaul including Gasket probably $100 plus. A proper workshop will ensure that the valves are cleaned and lightly lapped. Replace with recon engine - has the above been done or needs to be done? after getting those info, you will need to decide cause it's coming from your wallet. =) ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 12, 2009 Share December 12, 2009 Do not go by colour like what many third world countries peasant do when it time to take medicine. =============== But that the fastest way to check if compatable or not. Once u find the stuff, then u have to read the fine print. For me, if the colour is not the same, I wud not buy. If same colour, my next step is the read carefully the instructions to b sure. But I still prefer to buy from authorised stockist if their prices r acceptable. That is what I did for my Optra as the colour is orange but can b mistaken for the red Toyota type. If possible, I still prefer to buy original or OEM for my cars. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 12, 2009 Share December 12, 2009 Have you asked a workshop to do a pressure test on the cooling system to find out if the pressure is able to hold and within specs? The other thing to find out is if the thermostat is still there. In my current H. Accent, taking out the thermstat affects the system and cause water loss. Got to replace the radiator which leaked due to insufficient water level. Fixing back the thermostat fixed the whole issue and is working back to norm. ============ Never listen to those back-yard mechs who advise to remove the thermostat if u experience high water temp. Maybe change a new thermostat as the present one might b sticking not opening properly causing the water to overheat, but removing it will cause the car to run too cool, especially on cold nights or during heavy rain & your engine might suffer power loss & jerking even. I know cos it happened to me long time ago. Link to post Share on other sites More sharing options...
SporeHongkong Neutral Newbie December 12, 2009 Author Share December 12, 2009 Did the mech confirm with a cooling system pressure test? any compression test done as well? Got to weigh the pros and cons of each. Replace gasket - Labour is probably $200. parts depends - parts for top overhaul including Gasket probably $100 plus. A proper workshop will ensure that the valves are cleaned and lightly lapped. Replace with recon engine - has the above been done or needs to be done? after getting those info, you will need to decide cause it's coming from your wallet. =) got few quotes from 160-250 for replacing of gasket..engine wise as some say if chg gasket things wont be the same as in screws n etc..cause affected the engine..thats y engine also going up lorry?if get recon will it be costly?performance wise will better?but i feel not necessary unless theres a real need for it..n yes exactly have to plan n budget..no pt spending too much unnecessary wastage.. Link to post Share on other sites More sharing options...
SporeHongkong Neutral Newbie December 13, 2009 Author Share December 13, 2009 could i jus add on if anyone can tell me where to buy the radiator cap from as in 0.9 pressure cap..?and also the spare water tank?cause it might not be closed tightly.. Link to post Share on other sites More sharing options...
Opel17 6th Gear December 13, 2009 Share December 13, 2009 could i jus add on if anyone can tell me where to buy the radiator cap from as in 0.9 pressure cap..?and also the spare water tank?cause it might not be closed tightly.. Didn't you already changed the radiator cap [rubber cap] on 1/12 ? I dun think the spare water tank have to be changed due to "not closed tightly", becos usually there is a vent hole to allow excess coolant to overflow out. This tank is not supposed to be pressure tight. Link to post Share on other sites More sharing options...
SporeHongkong Neutral Newbie December 14, 2009 Author Share December 14, 2009 that was the bottom rubber cap..now after assesment willl need to chg the top cap,the one on top of the radiator..cause my spare tank cover abit broke off thats y water comes out from there on the way back from overflow.. Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 14, 2009 Share December 14, 2009 could i jus add on if anyone can tell me where to buy the radiator cap from as in 0.9 pressure cap..?and also the spare water tank?cause it might not be closed tightly.. Either u get from stockist or petrol station. Link to post Share on other sites More sharing options...
Pride14 Neutral Newbie December 14, 2009 Share December 14, 2009 hi bro, you can get the radiator cap from all major petrol stations they got sell.... Link to post Share on other sites More sharing options...
SporeHongkong Neutral Newbie December 14, 2009 Author Share December 14, 2009 Either u get from stockist or petrol station. bro where's stockist? petrol kiosk as in ask from the counter or at those with service ctr in them? sorry not sure abt it Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 14, 2009 Share December 14, 2009 bought mine at 3.30 a btl..green coloured solution..pour in whole can n add on water..but now slight leak from bottom of car again..hai..dont know wat happened.. ================= Just send to your trusted mech to trace where the leak is coming from. Maybe a water hose is leaking? Then just change the hose can already. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 14, 2009 Share December 14, 2009 If your ride is a Japanese or Asian make and model - your chance of mistake is very very slim if you use Japanese original coolant. Japanese coolant is deisgned for use with soft water where as European coolant are more for slightly hard water. ===================== My ride is a bit more complicated. U see its an Optra. American brand. Korean car. Australian engine. Assembled in Thailand. So like that how? Thats why I played it safe & bought the original coolant sold by GM. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 14, 2009 Share December 14, 2009 Do not go by colour like what many third world countries peasant do when it time to take medicine. =========== Er.......Then why do the manufacturers colour their coolants differently. I always tot its for easy identification. Like that u mean must read the fine print throughly on all different types of coolant sold b4 using? Even me being a third world peasant knows better than to assume all white tablets r Panadol. Link to post Share on other sites More sharing options...
Opel17 6th Gear December 14, 2009 Share December 14, 2009 bro where's stockist? petrol kiosk as in ask from the counter or at those with service ctr in them? sorry not sure abt it You can try Autobacs, ask the staff for assistance to select the right radiator cap. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 14, 2009 Share December 14, 2009 What car your driving? Just buy the radiator cap from stockist. Find yr stockist here: www.autoparts.com.sg Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 15, 2009 Share December 15, 2009 bro where's stockist? petrol kiosk as in ask from the counter or at those with service ctr in them? sorry not sure abt it It will be one the shelves, next to wiper blades + any other motoring products. So I seen, there are two sizes available only. BTW, I only visit Shell petrol station, not sure if other brands petrol station have or not. The best is go to stockist. Wat car are u driving??? Link to post Share on other sites More sharing options...
SporeHongkong Neutral Newbie December 15, 2009 Author Share December 15, 2009 am driving a honda..but wat abt those spare tanks?as in the cap for the overflow tank is abit out so i thought of changing it too..have checled on my way jus now but the petrol kiosk with the service ctr in it say out of stock for the 0.9 cap..anywhere else got open till 11+ at nite? cause i usually work till late..thks alot to all.. Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 15, 2009 Share December 15, 2009 Just give a call to any Honda stockist and enquire. All they need is ur car model. ↡ Advertisement Link to post Share on other sites More sharing options...
