Engine water dry up fast?
SporeHongkong
hi
just want to know how often and how much water do you fill in the coolant reservoir?
my car is still below 1000km, and the coolant at the reservoir will drop abt 1 cm every week, my ussage of the car is abt 1.5hr everyday, is that normal? i dont see any leakage and the coolant looks normal green.
thx
Coolant level should not drop for months. Bring your car back for checks.
Or, are you mistaken the water reservoir for the wiper as coolant?
You may have a slow leak somewhere.
I changed my radiator cap and it seemed to slow down the leak, but it still leaked slowly.
Then I found the hose at the heater core is the real culprit. There was a slight leak and the firewall is a bit damp. I fixed another hose clamp and it seemed to solve that problem.
Naturally, there's still some evaporation and the coolant might drop just a little.
If you use a higher than spec radiator cap, you increase the coolant pressure and that force any leak to accelerate. Besides, the heater core, there's also two more hoses to the throttle body which potentially could leak.
[laugh] I dun think Adhi had mistaken the water reservoir for the wiper since he can identify the coolant as green.
Question shld be when he does his checks? Moments after he had driven his car or in the morning before start up. If moments after he had driven his car, of course the coolant will take some time to return to the reservoir. It will not be an accurate check.
hi
kb27:how fast your is your coolant leak? empty the reservoir within days?
and after you fix the leak, how fast is the evaporation of the coolant? like many be 1 month only drop 1/4 from the resevoir?
ben5266: yes its the coolant reservoir. my previous car got leak from the radiator fins, so i can see it very clear because the coolant is sputting out. but my current car i cant find any traces of the coolant.
watwheels: i check the next morning. and i realise it drop abt a line after i use the car. and abt 1 cm in a week.
if theres no leak, is there any posibility that the ratio of the water is too much compare to the coolant? which makes the level in the reservoir to keep on droping when i use the car.
thx.
Before I fix the leak, the overflow tank would become empty in about 3 months.
After I fixed the leak, it would drop maybe about 1/4 over the same period.
On 11/22/2009 at 3:58 AM, Yeobh said:
When the engine is running hot the coolant will expanse and excess coolant/water vapour will drain via the radiator cap relief valve into the coolant collection bottle.
The reverse will happen when your kill the engine, the cool down coolant system in the engine will creat negative pressure (vacuum) which in turns will draw the coolant back into the system.
If there is no white smoke emission when your run yr engine, my conclusion is yr ride coolant volume is just too low.
There is white smoke emimission  when i run my engine  and also the radiator s coolant  dries very fast.  What can be the problem.  Thanks for your help
Serious liao - likely coolant leaks into the combustion chamber.  Probably quite expensive to fix.
Supercharged
Need to do top overhaul. About $1600.
depend on what car, and how bad is it.
1600 is very very lucky case.
There is a leak into the engine where the coolant mixes with the engine oil,  hence there is emission of white smoke. It is best to get a good workshop to check the cylinder head gasket, cylinder heads, engine block for signs of damage or cracks.
Likely a top overhaul will fix the problem, but if there are damage or cracks to other parts of the engine, those parts will need to be replaced as well.
  • Praise 2
