Vextan 1st Gear January 25, 2010 Share January 25, 2010 Anyone done re-laminate of kitchen cabinet before ? Any contractor to recommend ? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Kxbc Turbocharged January 25, 2010 Share January 25, 2010 Anyone done re-laminate of kitchen cabinet before ? Any contractor to recommend ? Thanks. I asked before and was told cost of re-laminating is only slightly cheaper than redoing the whole cabinet. 1 Link to post Share on other sites More sharing options...
Vextan 1st Gear January 25, 2010 Author Share January 25, 2010 (edited) I asked before and was told cost of re-laminating is only slightly cheaper than redoing the whole cabinet. ok thanks. i guessed it is not cheap or worth it also. but existing cabinet still in good condition, it is such a waste to discard the whole thing. donno can diy or not. Edited January 25, 2010 by Vextan Link to post Share on other sites More sharing options...
Kxbc Turbocharged January 25, 2010 Share January 25, 2010 ok thanks. i guessed it is not cheap or worth it also. but existing cabinet still in good condition, it is such a waste to discard the whole thing. donno can diy or not. I was in the same boat as you some years ago also. Maybe contractor wanted to earn the slight extra and said that to me. You should call some carpenters up and ask for clarity. DIY definitely not possible unless you have the right tools and workshop. My cabinet was like done in the factory and then just added together on site, which took at least 1 day. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged January 25, 2010 Share January 25, 2010 Not worth the money and time. Very time consuming to re-laminate the cabinet. Better to wait till it is really broken and have it re-done. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged January 25, 2010 Share January 25, 2010 Ikea's is not cheap and there aren't major DIY store (UK type) in s'pore. Link to post Share on other sites More sharing options...
Vextan 1st Gear January 25, 2010 Author Share January 25, 2010 thanks guys. i have gotten two shop names which i will call to enquire. however, as kxbc said about the cost, i am not too hopeful. will update ya later. Link to post Share on other sites More sharing options...
Alechi 2nd Gear January 25, 2010 Share January 25, 2010 Actually ... u can DIY laminate .... very very much cheaper just remember to buy industry strength glue Link to post Share on other sites More sharing options...
Watwheels Supersonic January 25, 2010 Share January 25, 2010 Actually ... u can DIY laminate .... very very much cheaper just remember to buy industry strength glue Yes. Laminate is the easy part but removing the old laminate is the time consuming part. After that you have to sand away the gum residue leh... Link to post Share on other sites More sharing options...
Jman888 Moderator January 25, 2010 Share January 25, 2010 (edited) ok thanks. i guessed it is not cheap or worth it also. but existing cabinet still in good condition, it is such a waste to discard the whole thing. donno can diy or not. depends on how big, I actually diy my wardrob doors (4 tall panel and 4 small panel - total height from floor to ceiling), bought the laminate material from homefix, paint the frame. took one whole day, luck thing was the width of the door not too long, the laminate paper can cover without the need to overlap! I guess kitchen cabinet need the tougher and waterproof material. Edited January 25, 2010 by Jman888 Link to post Share on other sites More sharing options...
Alechi 2nd Gear January 25, 2010 Share January 25, 2010 (edited) U are right. My suggestion below : step 1: remove all the cabinet doors (i.e. unscrew the hinges) and rip off laminates step 2: rip off remaining laminates on cabinet step 3: use an electronic buffer (sandpaper kind) to lightly buff the gun residue away ... no need to be perfect ... aga aga can liao step 4: measure the size of laminate, cut and glue the frames, followed by the detached doors. step 5: let dry naturally ( remember don't blow dry with hairdryer - may warp the laminate) step 6: fix doors back and work is done about 2 days worth of effort - max Yes. Laminate is the easy part but removing the old laminate is the time consuming part. After that you have to sand away the gum residue leh... Edited January 25, 2010 by Alechi 1 Link to post Share on other sites More sharing options...
Sgnick 1st Gear January 25, 2010 Share January 25, 2010 The single colour laminate i found sold at Homefix is PVC laminate adn dont look very lasting The type used on kitchen cabinets by contractors are call Formica? Were can buy Formica cheaply? Also, most carpenters wont want to help relaminate, they will just tell u to change the doors and drawers. Link to post Share on other sites More sharing options...
AhTAN Neutral Newbie January 25, 2010 Share January 25, 2010 formica a brand of laminate.. jus like pampers is to diapers and maggie mee is to instant noodles. the reason y carpenter dont usually help with relaminating the doors for u is bcos of the time spent on taking it off the plywood.. if he calculate the time spend n charge it to the consumers, im sure nobody will wanna pay. thats y its as good as changing new cabinets.. Link to post Share on other sites More sharing options...
Hungee Neutral Newbie January 25, 2010 Share January 25, 2010 formica a brand of laminate.. jus like pampers is to diapers and maggie mee is to instant noodles. the reason y carpenter dont usually help with relaminating the doors for u is bcos of the time spent on taking it off the plywood.. if he calculate the time spend n charge it to the consumers, im sure nobody will wanna pay. thats y its as good as changing new cabinets.. Agreed that work required is much more than re-install new ones. I did re-laminating of kitchen cabinet for my parents, but changed all the doors lah. took 2 days to do. Price $1.2K. Maybe to change the cabinet & table top as well will cost another $1k ... Link to post Share on other sites More sharing options...
Sgnick 1st Gear January 27, 2010 Share January 27, 2010 formica a brand of laminate.. jus like pampers is to diapers and maggie mee is to instant noodles. the reason y carpenter dont usually help with relaminating the doors for u is bcos of the time spent on taking it off the plywood.. if he calculate the time spend n charge it to the consumers, im sure nobody will wanna pay. thats y its as good as changing new cabinets.. Yes i know formica is a brand of laminate, but it is definitely a higher quality than normal PVC laminate sold in homefix right? i see, so assuming laminate material cost is cheap, but time is more, compare to new doors and drwaers material but less time Price: laminate (more time+less material) = new door (less time+more material) ? Is it really same? Link to post Share on other sites More sharing options...
Moredhel 2nd Gear August 18, 2011 Share August 18, 2011 Formica have a showroom in Geylang iirc. 8 ft X 4Ft sheet of Formica costs S$58 again iirc. There are many other laminate suppliers. Three at least in Sungei Kadut Thousands of designs. Dam hard to choose. But we were lucky and the MD of one of the suppliers just happened to be in the showrooms when we were there and he ran us through the easy way to make a choice. Took about 10 minutes when previously we had spent 10 hours and were nowhere near a decision. Care to share his sage advice? Link to post Share on other sites More sharing options...
Doraemon84 Neutral Newbie September 13, 2011 Share September 13, 2011 Care to share his sage advice? I am also having some headache in choosing my kitchen cabinets. Any one have a good and reliable kitchen cabinetry company to help me out? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 4, 2012 Share April 4, 2012 Anyone done re-laminate of kitchen cabinet before ? Any contractor to recommend ? Thanks. Not tried DIY yet ↡ Advertisement Link to post Share on other sites More sharing options...
SG Cabinet 2025
SG Cabinet 2025
Recommendations for light kitchen carpentry and sink works
Steel cabinet
Steel cabinet
How to clear kitchen choked floor piping?
Guess your 2020 Cabinet
PAP New Cabinet 2015! Reshuffle 2017/2018
Repair of Convection Oven Built In (Kitchen)
