Blueblueman 4th Gear March 2, 2016 Share March 2, 2016 Today just checked with stockist, a pair of lower arm for vios is $360. Any idea where to get cheaper parts? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Vinceng Turbocharged March 3, 2016 Share March 3, 2016 There lower arm bush can easily last 10 years, if you drive over humps with caution, at close to a complete stop. 5km/h. Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 3, 2016 Author Share March 3, 2016 There lower arm bush can easily last 10 years, if you drive over humps with caution, at close to a complete stop. 5km/h. I must be very impatient then... Mine is third set already... Each set last 3+yrs only... Hehehhe.... Link to post Share on other sites More sharing options...
Kurty Supercharged March 11, 2016 Share March 11, 2016 Is there a need to change? I have never change since day 1.. car is 10 years old. I guess it must be damaged but can't seem to find any seller for this despite make is in malaysia. .. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 11, 2016 Share July 11, 2016 I was recently "analyzing" groaking sound n steering swivel slight left despite left cv joint replacement n possibly might point to a new culprit called lower ball joint. Anyone w similar experience? I recalled a fren recently scrapped his ride wc same as mine tt replaced lower arms 2-3yrs back but claimed chassis full of loose noise. So was suspecting lower arm replacement was ineffective solution but no chance to experience it. Link to post Share on other sites More sharing options...
Kurty Supercharged July 11, 2016 Share July 11, 2016 those sound commonly came from drive shaft aka CV or lower arms. if you using your ride for a long time, its good to change. there's many type of material to go for, currently I'm in the midst of changing the lower arm bush to nylon type. the critical component seems to be the ball joint, don't see many people replacing in Malaysia although I know it can be done.. just those bugger want an easier way out.. Link to post Share on other sites More sharing options...
Kb27 Supersonic July 12, 2016 Share July 12, 2016 Lower arm bushing are being destroyed due to the thousands of humps LTA put all over the roads, in particular, when you don't slow down. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear July 13, 2016 Share July 13, 2016 i realise the bush is a modular unit which is separate from the lower arm. has anyone replaced the cracked bush instead of the entire lower arm before? it's a real waste to replace the entire lower arm just because of the damaged bush. Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged July 13, 2016 Share July 13, 2016 Just replace the bush if the arm is not damaged. Link to post Share on other sites More sharing options...
Blueblueman 4th Gear July 13, 2016 Share July 13, 2016 Dismantling the bush and labour cost maybe higher than cost of arm that's why some mech suggest change arm. Might be different with different car model Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 13, 2016 Share July 13, 2016 Different make different model different alternatives. There are bushes that can be pressed out while some are sold as a whole unit. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 14, 2016 Share July 14, 2016 Lower arm bushing are being destroyed due to the thousands of humps LTA put all over the roads, in particular, when you don't slow down. i'd think the strips hurt more than the humps, no? Link to post Share on other sites More sharing options...
sti8k 1st Gear July 15, 2016 Share July 15, 2016 I got quote $240 for front stabilizer bush and linkage. Jap MPV... Reasonable? Link to post Share on other sites More sharing options...
Pentium77 Clutched July 21, 2016 Share July 21, 2016 I got quote $240 for front stabilizer bush and linkage. Jap MPV... Reasonable? since your ride is japan MPV, u can go to spare parts shop and tell them your ride model and year and the item you want and bring to your regular workshop to replace,and ask the workshop to send your ride for alignment too, just pay labour and the alignment cost ↡ Advertisement Link to post Share on other sites More sharing options...
Lower your car interior temp when parking in the hot SUN
Persistent Lower Back Pain
Front lower arm and suspension questions
Spare Tire - where can I find a replacement?
New petrol company Sinopec in SG.. lower prices coming?
Nissan Latio Ignition Coils Replacement
Dead battery: Which car battery provider you call?
Side mirror back cover replacement. where and how much?
