Tom_kkh 1st Gear July 4, 2010 Share July 4, 2010 (edited) going to do my servicing next month. intent o pour engine treatment/additive for the engine. any recomandations? TIA Edited July 4, 2010 by Tom_kkh ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic July 4, 2010 Share July 4, 2010 MMO Link to post Share on other sites More sharing options...
Eyke Supercharged July 4, 2010 Share July 4, 2010 Yes: don't. Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 4, 2010 Share July 4, 2010 why does your engine oil need such additives? Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 4, 2010 Author Share July 4, 2010 maybe le me rephase. saw those selling at autobac that claims to furthe protect yr engine if u mix them with yr engine oil. some supposed to make yr engine smoother or better wear protection. not those that pours into the fuel tank Link to post Share on other sites More sharing options...
Weiming 1st Gear July 4, 2010 Share July 4, 2010 I think the most important thing is to use a good quality engine oil and change it as your servicing schedule dictates. If you are planning on keeping your vehicle for the long term or the vehicle is old (like mine), you can use Auto-Rx. Very well regarded on BITOG (Bob Is The Oil Guy) forums. I am using it on the maintenance dose as my engine has just been completely re-built. Link to post Share on other sites More sharing options...
5936 1st Gear July 4, 2010 Share July 4, 2010 Additive or no additive does not really make a dig difference to me. More important is the quality synthetic EO. as in my case svc interval is 15K. Most additive's effect is either cannot be quantify, or felt, or only short term. I think all burn off after a while, or maybe i got thick skin cannot feel But occassionally, out of curiosity I still add in. Just to make me feel good. I will add in the Engine treatment and not EO treatment. Some of them are not cheap too. I wonder if it's logical to buy additive or just go for oil change instead... as some of this anti wear additives are already blended in the EO. If you want to add, try this tech stuff. Can get from AutoB_c @ $70+ "CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil". from Liqui Moly. Advice: Check and make sure the Additives are not Engine flush or Leak Repair.. These may seize up engine..... Have fun and enjoy your experiment. Link to post Share on other sites More sharing options...
Otan Neutral Newbie July 4, 2010 Share July 4, 2010 Can check out this Prostaff Rikitaro Engine Treatment Link to post Share on other sites More sharing options...
5936 1st Gear July 4, 2010 Share July 4, 2010 Looks powerful. Any idea what is it made of? If it is good stuff I will also like to KIV and try later. In Japanese? need $$ to pay someone to translate. Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 5, 2010 Author Share July 5, 2010 hey guys, thanks for the replies. Ya, i am looking more into engine protection rather than for increase in BHP. The only way my car can go fast is to change it I know I will not feel the difference, just want to have additional protection. whether it works or not is another question. Just hoping to have more protection to the engine... Link to post Share on other sites More sharing options...
Jasonjst 3rd Gear July 5, 2010 Share July 5, 2010 Additive or no additive does not really make a dig difference to me. More important is the quality synthetic EO. as in my case svc interval is 15K. Most additive's effect is either cannot be quantify, or felt, or only short term. I think all burn off after a while, or maybe i got thick skin cannot feel But occassionally, out of curiosity I still add in. Just to make me feel good. I will add in the Engine treatment and not EO treatment. Some of them are not cheap too. I wonder if it's logical to buy additive or just go for oil change instead... as some of this anti wear additives are already blended in the EO. If you want to add, try this tech stuff. Can get from AutoB_c @ $70+ "CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil". from Liqui Moly. Advice: Check and make sure the Additives are not Engine flush or Leak Repair.. These may seize up engine..... Have fun and enjoy your experiment. This cera tec is good stuff , can bring back a 10years old engine to life ! I have tried it and make my old engine run more smoothly ! But it think for new engine , maybe cant tell any different since torelances are stiff tight right ? Link to post Share on other sites More sharing options...
5936 1st Gear July 5, 2010 Share July 5, 2010 You also tried that. They dont display at the additive shelf. it's like a sacred item to them. Kept with the cashier. Maybe they had bad experience loosing them. For me I just put for the sake of putting it. Can feel the effect for a while. You maybe right that it can be felt from engines with higher mileage. Link to post Share on other sites More sharing options...
Ky13 Clutched July 5, 2010 Share July 5, 2010 Try LC20. Good stuff. No idea where to buy in singapore these days tho... Link to post Share on other sites More sharing options...
Tohto Hypersonic July 5, 2010 Share July 5, 2010 Try LC20. Good stuff. No idea where to buy in singapore these days tho... Yes. This is good. But I don't know who is selling it now. Link to post Share on other sites More sharing options...
Etnt Turbocharged July 5, 2010 Share July 5, 2010 Email him directly [email protected] http://www.o2asis.com/ Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 5, 2010 Share July 5, 2010 How much are the additives? Maybe better to buy good oil and save money on additives. Shaffer 7000 now only $8.50 and Redline if buy 5 bottles at $12.50 Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear July 5, 2010 Share July 5, 2010 How much are the additives? Maybe better to buy good oil and save money on additives. Shaffer 7000 now only $8.50 and Redline if buy 5 bottles at $12.50 where to fine Redline if buy 5 bottles at $12.50 Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 5, 2010 Share July 5, 2010 where to fine Redline if buy 5 bottles at $12.50 My car forum - market place. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Alzheimer's 'grand slam' for Biogen and Eisai: five things to know
Hemorrhoids - piles treatment
