Dtitan 1st Gear October 26, 2010 Share October 26, 2010 Hi bro, Maybe u like to find out more http://www.htyre.com/engine-carbon-remover.html seems quite interesting. Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Legan 1st Gear October 26, 2010 Author Share October 26, 2010 Hi GemLeo, Yup, engine refresh is engine flushing. Tan Chong always give ECU readout when servicing. Everything is "OK". But of course... everything to AD is ok one. Dtitan, Last tank I used Caltex 98. No sound also. But sian, cos Latio supposed to be able to use RON92. Don't know why like that. Link to post Share on other sites More sharing options...
Dtitan 1st Gear October 26, 2010 Share October 26, 2010 Hi Legan, Yea I understand, anyway price between 95 & 98 is bit more. Take it as extra cleaner everytime u pump petrol lor.. Take it easy. Maybe u can consider going to Malaysia short trip, 1 day to KL, shop shop, then back to Sin. Think it will help alot.. Cheers Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 26, 2010 Share October 26, 2010 Hi Legan, Did you try the Redline fuel cleaner? Is actually the same stuff as Techron but a lot more concentrated. Link to post Share on other sites More sharing options...
Itsec 2nd Gear October 26, 2010 Share October 26, 2010 Update After changing engine oil and doing an engine flush at Tan Chong Motors yesterday, I went to top up Caltex Ron95 again. End up the knocking sound is even louder. Sian. Don't know what to do next have you tried clear carbon as many suggested? Link to post Share on other sites More sharing options...
Beehive3783 Twincharged October 26, 2010 Share October 26, 2010 Update After changing engine oil and doing an engine flush at Tan Chong Motors yesterday, I went to top up Caltex Ron95 again. End up the knocking sound is even louder. Sian. Don't know what to do next just change the damned spark plugs can or not? It's obvious that they need to be changed even if there's no pinging but what I see is that you're just lazy to get it done. Link to post Share on other sites More sharing options...
Legan 1st Gear October 26, 2010 Author Share October 26, 2010 just change the damned spark plugs can or not? It's obvious that they need to be changed even if there's no pinging but what I see is that you're just lazy to get it done. Bro, not lazy to change. is there is a lot of things to remove in order to access the plugs for Latio. Plus plugs for Latio is expensive. And labour is expensive too. Just want to try other options first. Link to post Share on other sites More sharing options...
Legan 1st Gear October 26, 2010 Author Share October 26, 2010 Tried clear carbon at high rev for 10mins only. no use also, maybe need to go north.... have tried STP. Maybe will try Redline. Link to post Share on other sites More sharing options...
Panhard 1st Gear October 26, 2010 Share October 26, 2010 if use 98 octane no problem then just continue using it dont mess up the engine with all kinds of repairs/upgrade.... still cheaper this way. Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 26, 2010 Share October 26, 2010 Isn't changing plugs cheaper than flushing engine? Link to post Share on other sites More sharing options...
Dtitan 1st Gear October 26, 2010 Share October 26, 2010 Hi, Dun think the ping got anything with the plugs. Latio plugs can last 100k km as stated in manual. i jus changed mine at 95k, it started to ping at 110k km. So dun think its the plug. cheers Link to post Share on other sites More sharing options...
Bighappyjer 1st Gear October 26, 2010 Share October 26, 2010 wtf 100k?? I change plugs at 25~30k. Link to post Share on other sites More sharing options...
Kspchew 2nd Gear October 26, 2010 Share October 26, 2010 Isn't changing plugs cheaper than flushing engine? Bro, is Tan Chong using the original Denso spark plugs? Went over to Ubi branch last week and they used NGK ones instead. Link to post Share on other sites More sharing options...
GemLeo 1st Gear October 26, 2010 Share October 26, 2010 Hi bro, Try 98 caltex, i tried for abt 2 fulll tanks before the ping sound goes away. I tried after Caltex 98, i switch to caltex 95. After a while the ping came back n i switch back to caltex 98, sound gone. Good luck im mostly on caltex 95.. still not sure what pinging sounds like.. am used to the noise... from engine and tyres.. but the noise doesnt sound irregular to me... Link to post Share on other sites More sharing options...
Beehive3783 Twincharged October 27, 2010 Share October 27, 2010 Bro, not lazy to change. is there is a lot of things to remove in order to access the plugs for Latio. Plus plugs for Latio is expensive. And labour is expensive too. Just want to try other options first. So many people have pointed fingers at the spark plugs and you still refuse to change. Oh well Link to post Share on other sites More sharing options...
Kangadrool Supersonic October 27, 2010 Share October 27, 2010 (edited) Of all, spark plug is probably the cheapest to change. Edited October 27, 2010 by Kangadrool Link to post Share on other sites More sharing options...
Legan 1st Gear October 27, 2010 Author Share October 27, 2010 Latio plugs alone is $120 or more. Havent include labour to remove remove intake manifold etc. it's that troublesome Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 27, 2010 Share October 27, 2010 Just buy normal spark plugs from stockist lah. There's Fong Tat and Teck Guan for you too choose from. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
