Gabby1234 Neutral Newbie September 25, 2019 Share September 25, 2019 Thanks for the replies. Does that mean I should push the SE for the better deal? Anyway, Car@Expo is around the corner, would it be wiser to wait and see then. ↡ Advertisement Link to post Share on other sites More sharing options...
Gabby1234 Neutral Newbie September 25, 2019 Share September 25, 2019 35 minutes ago, alex976 said: My FIL bought his for 102,888 (3 years warranty & 1 year free svc) Got top up for open CAt COE. I rmb dun take loan top up 1.5k and dun take their in-house insurance top up another 1.5k. This was when? Link to post Share on other sites More sharing options...
Kohanson 3rd Gear September 25, 2019 Share September 25, 2019 On 9/12/2019 at 4:19 PM, Noopie said: HI, any of mazda 6 owners experience vibration of your car for a few seconds due to rpm going lower than 700rpm? Happens to me when stationary or in low speed reversing. Its not air con compressor kicking in that causes this as the vibration also takes place even when air con is off. The vibration is due to low rpm causing rough idle which will cause the car to rattle for a few seconds. It will stop rattling after the rpm increases again. Car is 6 months old so I reckon its not the air filter, maf sensor dirty, carbon in throttle body or engine mounting problems. Went to mazda they said its low rpm problem due to emission standards, I am not convinced. Any one has this problem? This happens to mine once in awhile when reversing and the rpm is likely just above 500. My car is 2 mths old. Link to post Share on other sites More sharing options...
Nostalgia 4th Gear September 25, 2019 Share September 25, 2019 (edited) On 9/22/2019 at 12:23 PM, Conan86 said: Yea I have to agree that android auto without touch is very unintuitive, this is across the board and not limited to Mazda HU though. I’ll only recommend the CarPlay/AA update to people who drives a lot and relies on the infotainment for navigation without using a phone mount. (Actually I feel that navigation with phone mount is still the best as we can adjust our routing options and pick alternative easier with the touch screen). Otherwise not worth it if it’s just for daily A-B driving Um. Not true. The whole point of Android Auto is a simpified UI on a bigger touch screen on your UI. Don't know why it doesn't work on your Mazda HU, but works perfectly on Android Auto compatible HU like Pioneer HU. I've been using the Pioneer 8850BT for 3 years, no issue. The newer ones apparently let you connect wirelessly, without a cable. Edited September 25, 2019 by Nostalgia Link to post Share on other sites More sharing options...
Kohanson 3rd Gear September 25, 2019 Share September 25, 2019 The tok sound also happen to me almost every morning but it is a very faint sound. It happened to my previous ride long time ago after i changed to lowering springs and drove for 5 years, so i am not that concern about it unless it will cause premature wear on the bushings or any other part of the suspension. But i will just feedback this to the mechanic to check and to put as a record in case anything happen and they put the blame on me. Link to post Share on other sites More sharing options...
alex976 5th Gear September 25, 2019 Share September 25, 2019 5 hours ago, alex976 said: My FIL bought his for 102,888 (3 years warranty & 1 year free svc) Got top up for open CAt COE. I rmb dun take loan top up 1.5k and dun take their in-house insurance top up another 1.5k. July Link to post Share on other sites More sharing options...
GTO-1 5th Gear September 25, 2019 Share September 25, 2019 11 hours ago, Nostalgia said: Um. Not true. The whole point of Android Auto is a simpified UI on a bigger touch screen on your UI. Don't know why it doesn't work on your Mazda HU, but works perfectly on Android Auto compatible HU like Pioneer HU. I've been using the Pioneer 8850BT for 3 years, no issue. The newer ones apparently let you connect wirelessly, without a cable. It's more to do with Mazda's half-baked implementation of AA on their cars. Touch just doesn't work, you have to use the dial. We knows it's half baked because carplay has touch support while the car is parked. Link to post Share on other sites More sharing options...
Sherman_s 1st Gear September 25, 2019 Share September 25, 2019 Self installed AA foc with touch enabled. Just follow the guide found here mazdatweaks.com Havent used the mazda connect ui ever since. 1 Link to post Share on other sites More sharing options...
Nostalgia 4th Gear September 26, 2019 Share September 26, 2019 13 hours ago, GTO-1 said: It's more to do with Mazda's half-baked implementation of AA on their cars. Touch just doesn't work, you have to use the dial. We knows it's half baked because carplay has touch support while the car is parked. Yeah I know. I was replying to a post that said AA has no touch across the board, and it's not limited to Mazda HU. Link to post Share on other sites More sharing options...
Disgaea Neutral Newbie September 26, 2019 Share September 26, 2019 I just bought a new Mazda 6 and I am also facing a loud knocking noise after i parked the car for quite sometime. Also the vibration issue. Really regret. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear September 26, 2019 Share September 26, 2019 On 9/24/2019 at 9:00 PM, Gabby1234 said: Hi guys I've just been to the mazda carnival over the weekend and was quoted 112888 for the mazda6 executive with the usual freebies like dash cam, desire membership etc. However as I look thru this thread, I find some of you are saying you bought it around 100k? What is going on here? Note also I'm not trading in my car and I'm not taking a loan from them Hi Gabby, Believe it was 104k for executive when first launched and coupled with drop in the then COE price ... standard version was indeed <100k. Mine was 109k back in Aug 2018 without considering the 1k service voucher and 500 good-will-rebate that my salesperson applied for his customers. With falling COE price, 113k is indeed a surprise albeit good old for owners. Cheers, Richard Link to post Share on other sites More sharing options...
richard_crl032 6th Gear September 26, 2019 Share September 26, 2019 (edited) On 9/24/2019 at 7:16 PM, GTO-1 said: I think it's up to the user, but I can say that the new AA interface is definitely designed for touch in mind. It's basically the phone interface. I'm sure you can navigate with a dial, but it was designed around the dial. I'd my understanding is correct, Carplay in Mazdas does work with touch, but only if the car is in park. So they definitely can implement it for AA, they just haven't. Hi GTO, Indeed YYMV and hence wanted to also share that with AA for discerning audiophiles, crystal clear internet radio and hi-res stations like hi online channels at 320kbps makes beautiful music: <<http://www.hionline.eu/app/>> Cheers, Edited September 26, 2019 by richard_crl032 Link to post Share on other sites More sharing options...
Skywire01 1st Gear September 26, 2019 Share September 26, 2019 (edited) 7 hours ago, Disgaea said: I just bought a new Mazda 6 and I am also facing a loud knocking noise after i parked the car for quite sometime. Also the vibration issue. Really regret. Suggest to log in your complains officially to TEK so that they are aware of the common issues. I have highlighted this issue with T.penjuru and pending for them to get back to me with a solution. Edited September 26, 2019 by Skywire01 Link to post Share on other sites More sharing options...
Disgaea Neutral Newbie September 26, 2019 Share September 26, 2019 36 minutes ago, Skywire01 said: Suggest to log in your complains officially to TEK so that they are aware of the common issues. I have highlighted this issue with T.penjuru and pending for them to get back to me with a solution. Complained already and sent in quite a number of time for them to try to resolve. Still waiting for their solution too. Seems to be a common issue for all the new Mazda 6. Link to post Share on other sites More sharing options...
Skywire01 1st Gear September 27, 2019 Share September 27, 2019 11 hours ago, Disgaea said: Complained already and sent in quite a number of time for them to try to resolve. Still waiting for their solution too. Seems to be a common issue for all the new Mazda 6. Which service center did you go? Link to post Share on other sites More sharing options...
Zensproperty Neutral Newbie September 27, 2019 Share September 27, 2019 So far so good after ubi side refresh my ecu ... maybe u guys who have the vibration problem can head there ... till now 2 weeks plus no issue ... happy with what they did Link to post Share on other sites More sharing options...
Disgaea Neutral Newbie September 27, 2019 Share September 27, 2019 6 hours ago, Skywire01 said: Which service center did you go? Went to the Ubi one. 31 minutes ago, Zensproperty said: So far so good after ubi side refresh my ecu ... maybe u guys who have the vibration problem can head there ... till now 2 weeks plus no issue ... happy with what they did Trying to ask them to help. Feels like engine misfire. Link to post Share on other sites More sharing options...
Osiris 1st Gear September 30, 2019 Share September 30, 2019 Anyone figure out how to see live view on the free Hella 820? Some how dont have the live view button. ↡ Advertisement Link to post Share on other sites More sharing options...
2026 Mazda EZ-60 / CX-6e
Perodua Bezza
Perodua Bezza
Camry, Accord, Teana which is more Luxurious?
2025 Mazda 6e
2025 Mazda 6e
