What is spare tyre pressure?
Quantum
never carried spare tyre before even if driving to Malaysai, thinking to use spare tyre in next Malaysia trip, can anyone advise what pressure for spare tyre? my current tyres pressure are 220psi
Just pump 80% of the max rated pressure on the spare tire sidewall.
If regular sized spare tyre, inflate as for the other tire.
If compact spare tyre, inflate as indicated on tyre wall
However if your spare tyre is more than 4years old, avoid going above 80km/hr.
Tyre have shelf life of 4years, after it's expiry they are likely to burst (especially when running in hot weather) because the rubber component may have hardened and cracked.
also check out:
http://www.aa1car.com/library/tire_expire.htm
I believe sometimes there is/are lump(s) mosquito bite on the tyre, signalling a forthcoming tyre burst soon. It is good idea to examine the tire regularly for such defects/symptoms. Had 4 of 5 stock tire burst at age above 6 years.
There is usually a label at the driver's door side. shld be 240psi
For Space saver,should be 60 Psi,for standard size,it should be 40 Psi for most cars,240Psi.???Exploded already.
240?? what unit
should be unit convertion err,
6 years old tyres? Still can use meh?
I change my tyres every 2 years (will do cross-rotation once, at 12th month mark), and my mileage is about 16,500km/yr.
You are really brave. :ph34r:
I did tire rotation regularly and the five tire travelled at least 120,000kmober 6 years plus, before they burst one after another (while driving/parked)
