Pokyman 1st Gear August 4, 2011 Share August 4, 2011 yo bros ... if i change my Wish rims to 18 " from 15" , would i have any braking issues? My stock brakes able to handle the upsize? thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear August 4, 2011 Share August 4, 2011 errr. nope. but.. ur fc will be affected. Link to post Share on other sites More sharing options...
Vectrasonic 2nd Gear August 4, 2011 Share August 4, 2011 What's your ride? 3 size up leh. Can fit or not? Link to post Share on other sites More sharing options...
Caldina 1st Gear August 4, 2011 Share August 4, 2011 No problem. 225/40R18 Link to post Share on other sites More sharing options...
Calvin79 2nd Gear August 4, 2011 Share August 4, 2011 What's your ride? 3 size up leh. Can fit or not? erh... i think he said "Wish" Link to post Share on other sites More sharing options...
The_young_once Neutral Newbie August 4, 2011 Share August 4, 2011 Do it, if previous generation 2005 Corolla Altis can fit 18" no reason why not a Wish, sure can fit, want to change, change big, otherwise stock or even steel+hubcap is good enough! Kenny Link to post Share on other sites More sharing options...
Help1 1st Gear August 4, 2011 Share August 4, 2011 hmm...maybe u should ask yourself this question "can you afford/bear to pay the money for 18" tyres when time comes to change"???? alot of car owners upgrade without thinking, and when time comes to change, ouch their pocket lighter and heart pain cos they need to pay more for tyres.... Link to post Share on other sites More sharing options...
Calvin79 2nd Gear August 4, 2011 Share August 4, 2011 hmm...maybe u should ask yourself this question "can you afford/bear to pay the money for 18" tyres when time comes to change"???? alot of car owners upgrade without thinking, and when time comes to change, ouch their pocket lighter and heart pain cos they need to pay more for tyres.... and to add on, FC becomes higher... all these are stuffs that you must look at... because its a pretty big increase... Link to post Share on other sites More sharing options...
Shull Turbocharged August 4, 2011 Share August 4, 2011 I'm driving 2L Civic and i don't even dare to think about 18".. The thought of the increase in FC(and the power loss) is enough to kick the idea out of my head. Don't even need to go to the price of 18" tires.. [sweatdrop] Link to post Share on other sites More sharing options...
Solar Turbocharged August 4, 2011 Share August 4, 2011 (edited) he didn't mention FC... so it should be ok for him. anyway, if really worry about FC, get the lightest you can find.. edit.. to minimize the FC increase Edited August 4, 2011 by Solar Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 4, 2011 Share August 4, 2011 FC??? me went from 16"-18", FC increase is insignificant. It all about right foot...... Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 4, 2011 Share August 4, 2011 yo bros ... if i change my Wish rims to 18 " from 15" , would i have any braking issues? My stock brakes able to handle the upsize? thanks in advance Can,but the ride will be very harsh. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged August 4, 2011 Share August 4, 2011 Go for it man.. Wish on 15" looks wimpy.. If yr 15" is stock rim, it should be very heavy. As long as 18" rim is light weight less than 8 kg, tyre width not wider than 225 mm, if 205 or 215, then fc wouldn't affect much. But 18" tyres quite ex.. Cheapest $170.. All the way to $300+.. Way higher than $70-$130 for 15" Link to post Share on other sites More sharing options...
Mecontle 1st Gear August 4, 2011 Share August 4, 2011 i think wish no use 18" la, ur pickup will need to floor everytime ,ur braking will feel like its gone liao, the steering also harder to turn, potholes will shake everything inside, but when u do corner u be amazed how well it holds Link to post Share on other sites More sharing options...
Jefkking Clutched August 4, 2011 Share August 4, 2011 (edited) up size 3 inches will:- - Loss your engine power - Need to acelerate more on gas pedal and increase of your fuel consumption, dropped of fuel efficiency & forkout more costs on monthly fuel bill - Rim: what rim you're looking for ? Cheap package (Rims + tires) BUT heavier in rim weight & noiser of tire given in package (18 inches rim each will weight between 13 to 15 kg and are you ready for high rolling reisistance after installed ? - If genuine light weight rim choice should be 10 to 12 kg (max) but have to use consider using "Enkei", "OZ", "Yokohama Advan" & "Advanti "(Light weight series) but pay more in costs. - Next, tire type (Pattern): Performance (C-Dirve, A-Drive, Advan etc) or silence type (Advan DB) ? (Don't forget that by inch up of 3 inches, the tyre contact surface with the road surfaces had increased by couple of mm (or cm) , road noise is higher than 15 inches and you'll also lost some of quiet ride too. (Unless sound insulation and preapre to forkout another couple of hunrded dollars for insulation works) - replacement tires costs: An 18 inches tire will cost range between S$ 250 to S$ 350 depends on brand and thread patterns. All in all, ask yourself, are you ready for the above issues prior to final decision making ? Happy driving. Edited August 4, 2011 by Jefkking Link to post Share on other sites More sharing options...
Aeromania 1st Gear August 4, 2011 Share August 4, 2011 i've seen mark X with 16" rims which supposedly shld be ugly but his rims are black and tire profile quite high and it actually looks damn cool. I believe road noise in the car shld be awfully quiet also lol Link to post Share on other sites More sharing options...
Pokyman 1st Gear August 5, 2011 Author Share August 5, 2011 What's your ride? 3 size up leh. Can fit or not? Wish .. i called soh brothers, was told can fit leh .... Link to post Share on other sites More sharing options...
Pokyman 1st Gear August 5, 2011 Author Share August 5, 2011 Go for it man.. Wish on 15" looks wimpy.. If yr 15" is stock rim, it should be very heavy. As long as 18" rim is light weight less than 8 kg, tyre width not wider than 225 mm, if 205 or 215, then fc wouldn't affect much. But 18" tyres quite ex.. Cheapest $170.. All the way to $300+.. Way higher than $70-$130 for 15" haha ya .... i am thinking of the change coz yes, 15" looks wimpy imho .. ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Replacing a 2yrs old tyre?
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
Someone's rims and tyres stolen at KSL carpark
