Howeytan20 Neutral Newbie August 6, 2011 Share August 6, 2011 Hi, will like to find out on a auto box. Will shifting gear from Park to neutral without the engine fired tp be harmful to the auto gearbox? And how abt starting/ warming up the car in the morning in neutral gear instead of park gear? Reason is tat i'm having some wiring/sensor issue with the auto gearbox and having problem starting the car in park gear. Waiting for sept school holiday so tat I could leave the car in the workshop to rectify the fault. Regards ↡ Advertisement Link to post Share on other sites More sharing options...
Razer_Blaze 2nd Gear August 6, 2011 Share August 6, 2011 It will not harm your engine or the transmission if you start the engine at neutral. The difference between the Park and Neutral position is in the Park position, it will prevent the transmission gear from rotating while the Neutral position will disconnect the transmission from the wheels. Both positions allow the engine to start. So no worries about damaging the transmission. Link to post Share on other sites More sharing options...
Bslong Neutral Newbie August 6, 2011 Share August 6, 2011 Do you guys shift the drive to neutral when waiting for traffic lights to turn green? or just leave it at D all the way thru your journey? Cos I heard that shifting your auto gears too frequently might not be good for auto transmission. Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 6, 2011 Share August 6, 2011 leave it in D to reduce wear n tear Link to post Share on other sites More sharing options...
5936 1st Gear August 6, 2011 Share August 6, 2011 Just leave it in D. That's what they are built for. Link to post Share on other sites More sharing options...
Friendstar Supercharged August 6, 2011 Share August 6, 2011 Just leave it to D unless u drive a sonata taxi Link to post Share on other sites More sharing options...
Jman888 Moderator August 6, 2011 Share August 6, 2011 It will not harm your engine or the transmission if you start the engine at neutral. The difference between the Park and Neutral position is in the Park position, it will prevent the transmission gear from rotating while the Neutral position will disconnect the transmission from the wheels. Both positions allow the engine to start. So no worries about damaging the transmission. I thought the car won't start if it is not in P ? Link to post Share on other sites More sharing options...
Razer_Blaze 2nd Gear August 6, 2011 Share August 6, 2011 (edited) I thought the car won't start if it is not in P ? I always leave at N and switch off the engine during car wash. Time to move off, I will turn on the engine, set to D and drive off. Edited August 6, 2011 by Razer_Blaze Link to post Share on other sites More sharing options...
Fastfive1 5th Gear August 6, 2011 Share August 6, 2011 Just leave it to D unless u drive a sonata taxi Why do they do that? The only reasons i can think of are they're lazy or they're used to driving a manual and have the tendency to do that. Link to post Share on other sites More sharing options...
13177 Hypersonic August 6, 2011 Share August 6, 2011 Just leave it to D unless u drive a sonata taxi Why sonata taxi cannot leave it to D? Link to post Share on other sites More sharing options...
Howeytan20 Neutral Newbie August 7, 2011 Author Share August 7, 2011 I thought the car won't start if it is not in P ? Engine can be start in either Park or Neutral gear. Only thing that the car key couldn't be remove from the car if the gear in neutral. Regards Link to post Share on other sites More sharing options...
Howeytan20 Neutral Newbie August 7, 2011 Author Share August 7, 2011 It will not harm your engine or the transmission if you start the engine at neutral. The difference between the Park and Neutral position is in the Park position, it will prevent the transmission gear from rotating while the Neutral position will disconnect the transmission from the wheels. Both positions allow the engine to start. So no worries about damaging the transmission. Actually, my concern is about shifting out from the park gear to neutral gear without the engine running(transmission fluid isn't circulating) causing any extra wearing problem to the auto gear. Thk u Link to post Share on other sites More sharing options...
Zze121 3rd Gear August 7, 2011 Share August 7, 2011 (edited) Some at red light push to P n their reason is N not safe n incase ppl rear end u it will damage the gb if it on D. If it's CVT I will leave it at D, rear ended just claim the entire gb. Edited August 7, 2011 by Zze121 Link to post Share on other sites More sharing options...
Meanmachine Supercharged August 7, 2011 Share August 7, 2011 my experience tells me to leave @ D when stationary mode or traffic light on Red, ' N ' mode not only wear down the g/b, left idling for a mere 45sec to 60sec has consequences effect on gear compartment. Refer to car manual for best advise, as diff cars has slightly diff tips. Link to post Share on other sites More sharing options...
Timex1441 1st Gear August 7, 2011 Share August 7, 2011 Engine can be start in either Park or Neutral gear. Only thing that the car key couldn't be remove from the car if the gear in neutral. Regards not true....maybe in newer cars, need to be in D to remove key....but in older cars, parking in N is no problem, sure can remove key. Link to post Share on other sites More sharing options...
5936 1st Gear August 7, 2011 Share August 7, 2011 I noticed that too. They have the old habits of shifting gears during the Manual gear days. Link to post Share on other sites More sharing options...
Friendstar Supercharged August 7, 2011 Share August 7, 2011 Why do they do that? The only reasons i can think of are they're lazy or they're used to driving a manual and have the tendency to do that. jackpot! and taxi drivers love to "stress test" the cars they drive. and often u can get honest reviews from them. Link to post Share on other sites More sharing options...
Friendstar Supercharged August 7, 2011 Share August 7, 2011 not true....maybe in newer cars, need to be in D to remove key....but in older cars, parking in N is no problem, sure can remove key. huh? need to be in D to remove key? ↡ Advertisement Link to post Share on other sites More sharing options...
