Hondavvvtec 1st Gear September 4, 2011 Share September 4, 2011 Hi, Need some experts'help. This water heater (w/o water tank type) which my parents are using is not working fine. Sometimes hot, sometimes totally gone case, cold water only. to make it work, sometimes i have to on and off the tap several times, then can have hot water. Recently even worse, must on off on avg 20-30 times then can work. Dont know whats wrong with it ↡ Advertisement Link to post Share on other sites More sharing options...
Mustank Hypersonic September 4, 2011 Share September 4, 2011 Bo pian Buy new one lor sometime hot sometime cold very hard to endure Link to post Share on other sites More sharing options...
Fcw75 Hypersonic September 4, 2011 Share September 4, 2011 Change one. Very cheap nowadays. Panasonic one only $129. Link to post Share on other sites More sharing options...
5936 1st Gear September 4, 2011 Share September 4, 2011 If it's not the storage water tank type, then it must be the instant heating type. Did you notice if the ON light or click sound when tap is turn on? When you get only cold water, and no ON light or click sound, the flow switch at the inlet line may not be working. When you turn on tap, it senses water flow, and flow switch triggers heating element. The same on the reverse. It cost more on repairs and labour cost, especially the instant type which is between $100-$200. I bought my replacements from shops at Sungei Road, and install myself. Link to post Share on other sites More sharing options...
Hide Neutral Newbie September 4, 2011 Share September 4, 2011 might be faulty flow switch as the heating element will only turn on when water flow is detected... Link to post Share on other sites More sharing options...
13177 Hypersonic September 4, 2011 Share September 4, 2011 Wondering is there a lifespan on water heater? If the water heater is still in working condition but have used for more than 10 years plus, need to change? Link to post Share on other sites More sharing options...
Hondavvvtec 1st Gear September 4, 2011 Author Share September 4, 2011 yes, the red light that indicates the heater should be on is no working anymore, still got water so when i turn on the tap, the heater will have a soft "tuck"sound, so the sympton is as what most of you guys mention. So, i just need to buy flow switch? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 14, 2013 Share February 14, 2013 If it's not the storage water tank type, then it must be the instant heating type. Did you notice if the ON light or click sound when tap is turn on? When you get only cold water, and no ON light or click sound, the flow switch at the inlet line may not be working. When you turn on tap, it senses water flow, and flow switch triggers heating element. The same on the reverse. It cost more on repairs and labour cost, especially the instant type which is between $100-$200. I bought my replacements from shops at Sungei Road, and install myself. Bro, which shop along sungei road? Link to post Share on other sites More sharing options...
5936 1st Gear February 15, 2013 Share February 15, 2013 hi bro, no particular shop preferred.there are several shops along main road, ask around to compare prices. Link to post Share on other sites More sharing options...
Dafansu Turbocharged February 15, 2013 Share February 15, 2013 Poh Seng hardware near Jln Besar Hawker. Facing ah boy motor shop. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 15, 2013 Share February 15, 2013 hi bro, no particular shop preferred.there are several shops along main road, ask around to compare prices. ok i've asked; too bad they sell only. asked me go back agent; how i know what agent when even google oso cannot get the details... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 15, 2013 Share February 15, 2013 Poh Seng hardware near Jln Besar Hawker. Facing ah boy motor shop. tks bro! Link to post Share on other sites More sharing options...
Jtb 6th Gear February 15, 2013 Share February 15, 2013 Bro, which shop along sungei road? Show me or what is the brand of the heater? May hv few type kept around my office. Please replace heater if u can afford. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 15, 2013 Share February 15, 2013 Show me or what is the brand of the heater? May hv few type kept around my office. Please replace heater if u can afford. Will replace but just seeing have spare part cos heater element still working fine. Don't mind u can refer to instant water heater thread. Tks bro. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 15, 2013 Share February 15, 2013 Show me or what is the brand of the heater? May hv few type kept around my office. Please replace heater if u can afford. Missed ur middle sentence. U mean u have the regulator assembly? I'm not trying to scrimp, jus find it wasteful to discard it when the main component is still in good working order. What was defective was just a simple assembly. In fact, if gasket n thimble can be replaced alone, the heater can work as normal already. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 15, 2013 Share February 15, 2013 I simply cannot believe I have to discard everything when just 2 plastic / synthetic components failed, just like I have to scrap a car when the cooling system failed. Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 15, 2013 Share February 15, 2013 Bo pian Buy new one lor sometime hot sometime cold very hard to endure Yes that true. Very hard to endure. My wife is like that. Sometime hot sometime cold. Link to post Share on other sites More sharing options...
Mustank Hypersonic February 15, 2013 Share February 15, 2013 Buy new one lor ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
