Spiderman302 2nd Gear September 22, 2011 Share September 22, 2011 As above. New tyre size same as the old one. Any expert can explain? ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic September 22, 2011 Share September 22, 2011 Isn't that good? What brand and model? Is it Bridgestone Earth? Link to post Share on other sites More sharing options...
Happily1986 5th Gear September 22, 2011 Share September 22, 2011 hold your horses till your tires are properly scrubbed in. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear September 22, 2011 Share September 22, 2011 As above. New tyre size same as the old one. Any expert can explain? wear new shows, of course your car is happy mah! so happy that your car want to play(run) more and forget to drink! joke aside. i guess your old tyres are either "botak" or insufficient pressure and thus, there is somehow drag that caused more horses to move. if it is related to the pressure, do at least monthly check else the new ones will also be the same after some time. Happily1986 bro is right. drive safely till your tyres are properly seasoned. cheers. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear September 22, 2011 Share September 22, 2011 BTW, just curious, what does Spiderman302 mean? something that i remember that relates to 3O2. Link to post Share on other sites More sharing options...
Ithunk 1st Gear September 22, 2011 Share September 22, 2011 i like TS avatar Link to post Share on other sites More sharing options...
Mecontle 1st Gear September 22, 2011 Share September 22, 2011 i think when new, roll resist is low, later will bk to sq 1 Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear September 22, 2011 Author Share September 22, 2011 BTW, just curious, what does Spiderman302 mean? something that i remember that relates to 3O2. No specific meaning. When register, I typed spiderman but got rejected. Just keep trying different numbers until I got it. BTW, what you remember 302 as ? share leh. Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear September 22, 2011 Author Share September 22, 2011 wear new shows, of course your car is happy mah! so happy that your car want to play(run) more and forget to drink! joke aside. i guess your old tyres are either "botak" or insufficient pressure and thus, there is somehow drag that caused more horses to move. if it is related to the pressure, do at least monthly check else the new ones will also be the same after some time. Happily1986 bro is right. drive safely till your tyres are properly seasoned. cheers. Definately no pressure. Cos I always check tyre pressure. I always pump 235. I am not sure its due to tyre diameter. Old one worn out. Smaller diameter. New tyre diameter slightly larger than the old one cos its new. Link to post Share on other sites More sharing options...
Grix17 Clutched September 23, 2011 Share September 23, 2011 Definately no pressure. Cos I always check tyre pressure. I always pump 235. I am not sure its due to tyre diameter. Old one worn out. Smaller diameter. New tyre diameter slightly larger than the old one cos its new. Perhaps the tyres are not run in and the effectiveness of the thread has not kicked in yet. Less friction, higher effort on the part of the car to generate the same force against the road. Link to post Share on other sites More sharing options...
Mrel 1st Gear September 23, 2011 Share September 23, 2011 WTF. Totally opposite of my situation. Hahaha. http://www.mycarforum.com/index.php?showto...p;#entry4016765 Link to post Share on other sites More sharing options...
MrWeiwei Neutral Newbie September 23, 2011 Share September 23, 2011 Sorry to hijack. izzit effective to pump front tyres higher pressure than the rear tyres? high fuel consumption? Link to post Share on other sites More sharing options...
Tinydog Clutched September 23, 2011 Share September 23, 2011 Fuel consumption improved because of the weather now la. Cold ma, engine work better, use less petrol. Link to post Share on other sites More sharing options...
Tinydog Clutched September 23, 2011 Share September 23, 2011 Sorry to hijack. izzit effective to pump front tyres higher pressure than the rear tyres? high fuel consumption? Hi, front tyres are usually pumped higher pressure than rear due to the weight of the engine. too low a pressure will increase fuel consumption due to larger contact area/resistance with ground. but pump too high and u get a safety issue. Follow manual guideline... Cheers. Link to post Share on other sites More sharing options...
Dldm Neutral Newbie September 23, 2011 Share September 23, 2011 cos new tyre is 99.999% rounded. after sometime become 99.9, then become 99. tats y u need to rotate n balance ur tyres often. but as tyre botak, more surface will contact the ground is another reason due to the moulding concepts, tis 1 contribute abit too. Link to post Share on other sites More sharing options...
F2006 Neutral Newbie September 23, 2011 Share September 23, 2011 As above. New tyre size same as the old one. Any expert can explain? "fuel saving tyres" like Michellin XM1 or Bridgestone Earth does have an effect on FC due to it's low rolling resistance. When i changed from performance directional tyres to XM1, i have improved FC of about 10% consistently. Link to post Share on other sites More sharing options...
MrWeiwei Neutral Newbie September 23, 2011 Share September 23, 2011 Hi, front tyres are usually pumped higher pressure than rear due to the weight of the engine. too low a pressure will increase fuel consumption due to larger contact area/resistance with ground. but pump too high and u get a safety issue. Follow manual guideline... Cheers. swee. will go check and pump accordingly tml. Thanks! Link to post Share on other sites More sharing options...
GoodCar 4th Gear September 23, 2011 Share September 23, 2011 Do you know how much pressure the tyre shop pump in when they change the tyre? Thus may be the answer ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Any recommended tyre shop
Tyre puncture
Tyre puncture
