Hamburger Hypersonic October 25, 2011 Author Share October 25, 2011 considering going SLS for a walk about, feel like taking train...................but wait dont even know which station to drop off.... ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator October 25, 2011 Share October 25, 2011 considering going SLS for a walk about, feel like taking train...................but wait dont even know which station to drop off.... Bugis Junction, cut through the Bugis village Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 25, 2011 Author Share October 25, 2011 Bugis Junction, cut through the Bugis village 10mins walk....................maybe should bring my folding bike along Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 25, 2011 Author Share October 25, 2011 mustafa got IT stuff?? or SLS is still cheaper..... Link to post Share on other sites More sharing options...
Baphomet 3rd Gear October 25, 2011 Share October 25, 2011 (edited) How many PCs you got? Only 1 PC. Wireless will be use for that PC and also IPAD/Iphones What is the broadband connection speed you have or aiming to get in long run? (If you go fibre, it makes a helluva difference in throughput) Currently using Starhub maxonline 16Mbps. Hoping to get ard the same.. I won't be going into fibre soon as still under contract.. Do you transfer files between computer to computer frequently? Nope..seldom if not never What is your budget? Erm..I don't know..maybe ard 500 bucks? Seriously I do not know what to expect for the price. What is your tolerance threshold for setup hassle? (Simple? Configuration here and there but mostly set and forget? troublesome ie getting contractors to lay cat6 cable?) Something simple will do.. Do you plan to use wireless mainly? Do you mind using cat5/cat6 cable for desktop computers e.g.? I will be using wireless mainly. Sorry...I don't know what is cat5/cat6 cable.. Currently PC is placed near to the set up box and modem due to wiring all there. I do not want to have wiring lying ard nor want to go thru hassle of getting contractors to do it up.. so tot of having a wireless router so that I can shift my PC position to another location. Usage will not be that heavy..mainly watching movies online and some light surfing. Internet required only for 1 PC(no wifi function so need to get a wifi receiver?) and Ipad. Thanks Bro! Edited October 25, 2011 by Baphomet Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 25, 2011 Share October 25, 2011 Currently PC is placed near to the set up box and modem due to wiring all there. I do not want to have wiring lying ard nor want to go thru hassle of getting contractors to do it up.. so tot of having a wireless router so that I can shift my PC position to another location. Usage will not be that heavy..mainly watching movies online and some light surfing. Internet required only for 1 PC(no wifi function so need to get a wifi receiver?) and Ipad. Thanks Bro! I dont know where your modem and PC is currently located. Assuming they are centrally located, i suggest to get a wireless router which is rated for N 300Mbps. There is three standards for wifi N. 1.) Pre draft N (don't buy this, i don't think can find anymore) 2.) Draft N 1.0 or 150Mbps 3.) Draft N 2.0 or 300Mbps (Get this one) Since you mentioned the com is located next to modem and the router, i advise you connect the com straight to the LAN port of the router for cabled connections. Wired vs Wireless, Wired win almost everyday. The wireless capability of router means that your ipad can be used anywhere in house. Some info 1.) Visualise the wireless coverage as a donut. You want the donut to cover as much as the house as possible hence the central location. 2.) I recommend you to get a router which have external antenna because it is a modular design and you can swap the antennas for better ones if need be 3.) I really don't want you to get the high gain antennas (meaning the so called better antennas) when you get the router. Just use the stock antennas first. Why? Antennas are rated for their gain. Stock antennas are rated at 2dBi mostly. While high gain antennas usually 7dBi or 15dBi for home use, seem good. They have an issue. The vertical wireless coverage of high gain antennas is much lesser. Remember the donut? The donut is thinner. Yes the vertical position of your computer and your computer and/or ipad actuall does make a difference. So the issue is if you change to high gain antennas and if say your router's height and your ipad's height for some reason is too far apart vertically then it MAY affect wireless performance. 4.) the connection is as follows Starhub cable point -> Cable Modem Motorola Surfboard -> Router -> (Wireless + ethernet cable to your computer) So all you need to get is a router thats all. And because your broadband plan is a cable plan, this makes configuration very easy. Just configure the router to DHCP mode. Configuration of the router is another story. Post here again if you need help for router configuration. My personal recommendations for router 1.) Sub $100 to $150 Engenius ESR9850 2.) $150 to $200 Asus RT56U (This one got no antenna but has gotten alot of solid reviews, overseas and locally) Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 25, 2011 Share October 25, 2011 Wow now internet technology so advanced liao ah I still using my Linksys WRT54G with DD-WRT on a bridged Alcatel-Thomson modem (router?) running Singnet 3mbps But recently my dial up connections are dropping.. got a feeling my router is going to conk out soon Link to post Share on other sites More sharing options...
Baphomet 3rd Gear October 25, 2011 Share October 25, 2011 I dont know where your modem and PC is currently located. Assuming they are centrally located, i suggest to get a wireless router which is rated for N 300Mbps. There is three standards for wifi N. 1.) Pre draft N (don't buy this, i don't think can find anymore) 2.) Draft N 1.0 or 150Mbps 3.) Draft N 2.0 or 300Mbps (Get this one) Since you mentioned the com is located next to modem and the router, i advise you connect the com straight to the LAN port of the router for cabled connections. Wired vs Wireless, Wired win almost everyday. The wireless capability of router means that your ipad can be used anywhere in house. Some info 1.) Visualise the wireless coverage as a donut. You want the donut to cover as much as the house as possible hence the central location. 2.) I recommend you to get a router which have external antenna because it is a modular design and you can swap the antennas for better ones if need be 3.) I really don't want you to get the high gain antennas (meaning the so called better antennas) when you get the router. Just use the stock antennas first. Why? Antennas are rated for their gain. Stock antennas are rated at 2dBi mostly. While high gain antennas usually 7dBi or 15dBi for home use, seem good. They have an issue. The vertical wireless coverage of high gain antennas is much lesser. Remember the donut? The donut is thinner. Yes the vertical position of your computer and your computer and/or ipad actuall does make a difference. So the issue is if you change to high gain antennas and if say your router's height and your ipad's height for some reason is too far apart vertically then it MAY affect wireless performance. 4.) the connection is as follows Starhub cable point -> Cable Modem Motorola Surfboard -> Router -> (Wireless + ethernet cable to your computer) So all you need to get is a router thats all. And because your broadband plan is a cable plan, this makes configuration very easy. Just configure the router to DHCP mode. Configuration of the router is another story. Post here again if you need help for router configuration. My personal recommendations for router 1.) Sub $100 to $150 Engenius ESR9850 2.) $150 to $200 Asus RT56U (This one got no antenna but has gotten alot of solid reviews, overseas and locally) Wow..thanks bro for the detailed explanation. I will print this and bring with me when I go buy router. :) I understand that wired will definitely be better.. but the problem is..my modem is connected to the setup box, the setup box is connected to the TV..so my computer is currently near the TV in the living room..I do not want to have my PC there and thought of moving it to another loacation further back. But i do not want to have wires lying ard...Don't mind sacrificing abit of speed..so tot of having wireless router. How much speed will i loose if I use wireless router? as long as I can still watch movie streaming smoothly..its fine with me. omg..still have configuration.....i tot is plug and play...okie.. will post back here again once I get the router. Thanks a million! :) Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 25, 2011 Author Share October 25, 2011 and i thought i am the only noob here..... , isn't it good to ask when we dont know Link to post Share on other sites More sharing options...
Baphomet 3rd Gear October 25, 2011 Share October 25, 2011 and i thought i am the only noob here..... , isn't it good to ask when we dont know haha yup! especially when there are helpful ppl ard willing to help! Link to post Share on other sites More sharing options...
Jman888 Moderator October 25, 2011 Share October 25, 2011 Wow..thanks bro for the detailed explanation. I will print this and bring with me when I go buy router. :) I understand that wired will definitely be better.. but the problem is..my modem is connected to the setup box, the setup box is connected to the TV..so my computer is currently near the TV in the living room..I do not want to have my PC there and thought of moving it to another loacation further back. But i do not want to have wires lying ard...Don't mind sacrificing abit of speed..so tot of having wireless router. How much speed will i loose if I use wireless router? as long as I can still watch movie streaming smoothly..its fine with me. omg..still have configuration.....i tot is plug and play...okie.. will post back here again once I get the router. Thanks a million! :) i think it can still be plug and play if you dun set security, mean all your neighbour can tap on your network Link to post Share on other sites More sharing options...
Jman888 Moderator October 25, 2011 Share October 25, 2011 i like to ask a better router is mainly for better coverage or can it share among more devices with better throughput? i have 8-9 pieces of devices currently using wifi at home (though not all at the same time but about 4-5!), the mio 2wire N (on FO) still serving us fine. Link to post Share on other sites More sharing options...
Baphomet 3rd Gear October 25, 2011 Share October 25, 2011 i think it can still be plug and play if you dun set security, mean all your neighbour can tap on your network haha Thanks lor! Link to post Share on other sites More sharing options...
Mllcg 3rd Gear October 25, 2011 Share October 25, 2011 i think it can still be plug and play if you dun set security, mean all your neighbour can tap on your network dont use WEP lor. use WPA2. Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 25, 2011 Share October 25, 2011 i like to ask a better router is mainly for better coverage or can it share among more devices with better throughput? i have 8-9 pieces of devices currently using wifi at home (though not all at the same time but about 4-5!), the mio 2wire N (on FO) still serving us fine. I'm not the tech pro like Happily1986 But basically the better routers can handle more devices and connections (especially BT) better. But practically speaking for most average users the basic Wireless N routers r good enough. Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 25, 2011 Author Share October 25, 2011 WARNING!!!!!!!! just now i plugged in another 2wire into another phone wall socket......BIG FAT mistake the whole broadand has to be reconfigure as internet was down. Called ST and took quite awhile to address the problem. kudos to that ST technicain on line, he even changed the frequency of the wifi to see any improvement in connectivity. Tried but only slight improvement. He adviced me to get a signal booster to improve things. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 25, 2011 Share October 25, 2011 My experience in my home is to use a mixture of all connection methods. My router is the same one from Huawei they got me for the NBN. My laptop is direct connection to the router. Got one out from router to Homeplug. Wife's wired laptop in the bedroom connects through Homeplug and so does the kids 2 netbooks. All our phones us the WLAN of the router. Wife and I do not plug our phones to transfer data but use Filezilla. We both use Android phones. Connected to the router is the Iomega iConnect via Wifi but it can be used as a NAS if you plug in the USB HDDs. Don't trust Wifi for data but I use it as a print server. Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 25, 2011 Author Share October 25, 2011 moral of it................... kiang can already, dont gei kiang..... ↡ Advertisement Link to post Share on other sites More sharing options...
Better router or wifi extender
Turning a Router into a Bridge
EA8100 router
EA8100 router
Would changing to 802.11n router increase speed of 1MB?
Any router that can use sim card?
How long can a wireless router last?
WiFi Router
WiFi Router
Modem + Router problem
