Satria_neo Clutched October 24, 2011 Share October 24, 2011 What do you think? We install chaff in our cars to prevent speed cams from capturing..... ↡ Advertisement Link to post Share on other sites More sharing options...
Darthrevan Supercharged October 24, 2011 Share October 24, 2011 why not install missiles to take out the cams? Link to post Share on other sites More sharing options...
The_Bear Turbocharged October 24, 2011 Share October 24, 2011 why not install missiles to take out the cams? While you are at it, please throw in the Gatling Gun and flares. Link to post Share on other sites More sharing options...
Acieed 1st Gear October 24, 2011 Share October 24, 2011 http://mythbustersresults.com/episode18 Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged October 24, 2011 Share October 24, 2011 Driving without license plate: Fine $70.... Speeding - more than $70... Vedict: If that you want to speed, remove plate... Link to post Share on other sites More sharing options...
Chrispie 5th Gear October 24, 2011 Share October 24, 2011 Driving without license plate: Fine $70.... Speeding - more than $70... Vedict: If that you want to speed, remove plate... sounds like a good idea.. Only that being caught without a no plate has a much higher probability than being caught for speeding. So the expectancies of loss is actually higher. Link to post Share on other sites More sharing options...
Takumi21 2nd Gear October 24, 2011 Share October 24, 2011 install miror beside e number to reflect the light back.. Link to post Share on other sites More sharing options...
Maxus-MIFA9 Supersonic October 24, 2011 Share October 24, 2011 What do you think? We install chaff in our cars to prevent speed cams from capturing..... Look for 'Eagle Eye' (last night channel 5 movie), distort all images from CAM .... Link to post Share on other sites More sharing options...
Satria_neo Clutched October 24, 2011 Author Share October 24, 2011 http://mythbustersresults.com/episode18 The mythbuster one didn't work because its just using bits of tin foil. I was thinking what if we using chaff that are meant for used in planes as counter measures one. Then perhaps it could work. Of course another possibility is to use smoke. Just inject kerosene into exhaust manifold. The heat will vaporise and cause alot of smoke. Then smoke screen!! Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 24, 2011 Share October 24, 2011 The mythbuster one didn't work because its just using bits of tin foil. I was thinking what if we using chaff that are meant for used in planes as counter measures one. Then perhaps it could wor Of course another possibility is to use smoke. Just inject kerosene into exhaust manifold. The heat will vaporise and cause alot of smoke. Then smoke screen!! Sounds complicated. I have a special device to fool speed cameras wired in my car. I just need to tap the middle paddle with my foot to activate it. So far works everytime. Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged October 24, 2011 Share October 24, 2011 Sounds complicated. I have a special device to fool speed cameras wired in my car. I just need to tap the middle paddle with my foot to activate it. So far works everytime. Or drive one car with broken piston will also do the job. Link to post Share on other sites More sharing options...
LoverofCar 6th Gear October 24, 2011 Share October 24, 2011 (edited) Use one of this ...... Edited October 24, 2011 by LoverofCar Link to post Share on other sites More sharing options...
Acieed 1st Gear October 24, 2011 Share October 24, 2011 Fortunately, all my cars come stock with this device. But sometimes upgrade to advanced versions. Sounds complicated. I have a special device to fool speed cameras wired in my car. I just need to tap the middle paddle with my foot to activate it. So far works everytime. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear October 24, 2011 Share October 24, 2011 Water a mask. Link to post Share on other sites More sharing options...
Takumi21 2nd Gear October 24, 2011 Share October 24, 2011 slow down car speed? Link to post Share on other sites More sharing options...
Vega Turbocharged October 24, 2011 Share October 24, 2011 Can someone organise a group buy.. Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged October 24, 2011 Share October 24, 2011 sounds like a good idea.. Only that being caught without a no plate has a much higher probability than being caught for speeding. So the expectancies of loss is actually higher. I dont think so.... Where got so many law enforcer nowadays? And also, many downgrade so not consider crime.... Link to post Share on other sites More sharing options...
KARTer 2nd Gear October 24, 2011 Share October 24, 2011 sounds like a good idea.. Only that being caught without a no plate has a much higher probability than being caught for speeding. So the expectancies of loss is actually higher. install a spring-loaded flipping gadget to flip the number plate down using a remote 'release' button when you need to avoid being captured by spd cams.... then quickly turn behind the nearest petrol station and flip it up. aka 007 James Bond ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Jun 2026
Is Singapore Safe From Earthquakes ?
Total asset vs car price affordability
Xiaomi EV is Coming
Xiaomi EV is Coming
