Mawaflight Clutched February 7, 2012 Share February 7, 2012 So for the Honda Odyssey Absolute (facelift model with different tail lamp) - how do I play DVD on the roof DVD player? Is it the disc is inserted in the roof DVD player direct and the audio is switch by switching to AUX in the factory audio? What I can remember from using my friend's ODC. Slot direct in from the roof DVD player (take note is aftermarket, only the CD player is from factory) . ↡ Advertisement Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear February 7, 2012 Share February 7, 2012 (edited) have you done that before or guessing??? I travel NSE to K.L/Lumut very often. And tried it a number of time . Well, many review on car performance can be shown in ODC MY forum and some in SHC , can just pop in and read it. Edited February 7, 2012 by Wishxsr Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 7, 2012 Share February 7, 2012 i guess its a slope that helps or yours is not that stock.... Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear February 7, 2012 Share February 7, 2012 What is the normal odyssey compared to this absolute variant? More power? For the Odyssey Absolute(JDM), it comes in the form of a higher-powered version of the base engine - a 200ps K24A that revs to 7000+rpm in place of the standard 160ps K24A revving to 6300rpm. The speedo of course stops at just over 180kph as Absolutes are JDM-spec vehicles parallel imported from Japan. Other than that, the Absolute really does not project a much different look compared to the standard version. Specs for JDM ABSOLUTE: Engine K24A 2.4l DOHC i-VTEC Displacement 2354 c.c. Bore X Stroke 87.0mm X 99.0mm CR 10.5 Max Power 147kW/200ps at 6,800rpm Max Torque 232Nm/23.7kgm (193 Nm) at 4,500rpm RedLine 7,100rpm Steering System EPS Transmission 5-speed Automatic with Sequential Shifter Gear Ratios 2.651, 1.516, 1,081, 0.772, 0.566, R=2.000 Final Drive 4.437 Kerb Weight 1,700 kg Dimentions (LXWXH) 4,770 X 1,800 X 1,550 (mm) Wheel Base 2,830 mm Wheel Size 225/45R18 91W Brakes (F) Ventilated disc ® Solid Disc Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear February 7, 2012 Share February 7, 2012 i guess its a slope that helps or yours is not that stock.... My in stock condition, well i just share some experience here.Anyway i dont find it is fast for a 2.4l or to challenge anyone here. Link to post Share on other sites More sharing options...
Rosicky Neutral Newbie March 23, 2012 Share March 23, 2012 Quoted 68k for an dec'07 odyssey absolute, but high mileage of 160k. Gearbox need repair by 200k. Otherwise condition v good. Worth? Take into consideration that the repair will cost 3-4k. Link to post Share on other sites More sharing options...
Cracker 1st Gear September 4, 2012 Share September 4, 2012 digging up an old thread... does the 2008 and 2009 version use the same engine ? I knew there r some cosmetic difference...the rear lights are different...and the 2009 version has the HU unit isn't from alpine (I am refering to the one sold by Kah Motor).. Looking at getting an oddy based on 80k or slightly more budget.... those from 2007 are in the 70 to 80k...while those from 2008 are in the mid 80ks. those from 2009 are > 100k.... what are the big difference between Absolute (2008) and EKV (2009) beside the rear light and the HU unit ? Link to post Share on other sites More sharing options...
ER-3682 Twincharged September 4, 2012 Share September 4, 2012 Most Japanese cars used their engines for about 10 years, only change a bit of 'software',like ECU programming ,My 2003 2L engine has the same engine & gearbox[4 speeds] the the current model. Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 5, 2012 Share September 5, 2012 don't waste time on kah motor absolute. get the jdm absolute with 200 horses Link to post Share on other sites More sharing options...
Typhoonz 4th Gear September 5, 2012 Share September 5, 2012 don't waste time on kah motor absolute. get the jdm absolute with 200 horses Eh hear say you want to change car ah? Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 5, 2012 Share September 5, 2012 Eh hear say you want to change car ah? change tyre you mean............ Link to post Share on other sites More sharing options...
Typhoonz 4th Gear September 5, 2012 Share September 5, 2012 change tyre you mean............ No leh... Had lunch with the reliable source yesterday... Link to post Share on other sites More sharing options...
Darevil 3rd Gear June 21, 2017 Share June 21, 2017 Wow, rare find !!! 200 horsessss. http://www.sgcarmart.com/used_cars/info.php?ID=658544&DL=2524 Link to post Share on other sites More sharing options...
Scholesy 4th Gear June 21, 2017 Share June 21, 2017 A waste to renew only 5 yrs. Link to post Share on other sites More sharing options...
Notsogoodman 4th Gear June 22, 2017 Share June 22, 2017 A waste to renew only 5 yrs.Probably not renewed yet, dealer looking for a buyer so as not to scrap the car and get back pittance ↡ Advertisement Link to post Share on other sites More sharing options...
[Concept] Honda 0 Series EVs
2022 Toyota GR Corolla
Battery for Honda Vezel
