Switch from Iphone to Galaxy Notes??
Billcoke
http://support.google.com/mobile/bin/answe...p;answer=138740
I've set up google contact to sync with Iphone, but how to activate the sync?
Must click on sync contact to google lo.. On itunes, click on ur phone's name on the left menu.. Drop down should show outlook.. U will see google contacts when u click on the drop down box.. Click on the box beside "sync contacts with..." den cick apply on bottom right..
If ur note already has ur gmail account in it.. It will auto sync ur google contacts once they are synced over from ur iphone..
Thanks, it works, but I notice that everytime I do a direct Google Sync, my Iphone contacts will show as double or triple? is there a limitation to Google Sync?
For phone's OS upgrade, Iphone uses Itune, what about Galaxy Note, what software do they use? and also as for your contact, calendar, would that be restored after the upgrade, or you need to sync with Google again? Apps will be restored too, right?
Last time I had bad experience with my Samsung Omnia, which I lost all the data after the OS upgrade, it basically flush my Omnia phone clean. [:(]
Upgrade can be done thru the phone itself or using Samsung's software thru USB cable
You're advised to backup all your data before upgrading software, but so far, the 2 times i update firmware, all my stuff are still there..
i kenna this, just do this settings for outgoing:
SMTP SERVER - bbom-smtp.stm.com.sg
Security type - None
Port - 25
UNTICK require sign in
i tried bbom-smtp.stm.com.sg and mail.singnet.com.sg both port 25 and it does not work to send outgoing email from singnet..... i installed K9 and it does not solve my outbound issue as well......
Hmm.. I didnt have this problem.. So I'm not very sure man.. Maybe someone else can advise u?
To all Note users, how often do you use your S Pen? I hardly take it out.. Hahaha..
My wifey lost her 1 week back, she did not put back properly so the S/pen drop off, $70.00 gone [bigcry]
I also have this problem on my samsung notes.
cant even setup singnet email.
im using starhub line.
used the htc (starhub line) for almost 1 year and recently, got problem using singnet email.
kept on saying wrong setup. knn, damn tulan.
go to singtel, they say back to starhub since using starhub line.
go to starhub, they say singtel email, go back to singtel.
CCB, these two carriers.
if need be, try searching for it in either gmarket or eBay. shouldn't be that expensive to replace.
That is good news. I almost write-off Samsung phone after the previous bad experience, now I'm considering their Samsung Note.
so far my Samsung all cannot update thru the phone itself leh.. only thru kies.
