Kezg1 5th Gear June 12, 2012 Share June 12, 2012 Anyone can recommend me a honest plumber? My toilet bowl choked. Last time i got a plumber, i kenna carrot head Only if choke with paper...no problem If your water supply is quite powerful....connect a hose to tap, (those with thread and transparent type) make sure u clip...then put inside the toilet bowl...turn ON tap and jiggle..the hose I done it with all my chokage problem...even floor trap with thick slug.. If choke with plaster cement....then you have to go hardware shop and by chemical...pour in, leave it overnight.....will solve the problem ↡ Advertisement Link to post Share on other sites More sharing options...
Throttle2 Supersonic June 12, 2012 Share June 12, 2012 You kena stalk, newbie also know table wiper [rolleyes] yup and thats how to tell this person is not a newbie. Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 12, 2012 Share June 12, 2012 If u had done a search on MCF for plumber, u would have come across this wonderful plumber : AH Soon 98550906 http://www.mycarforum.com/index.php?act=Se...ite=%2Bplumber* He is really honest and charge reasonable rates. Used him once for my my mum's place. Kitchen sink drainage pipe corroded n toilet bowl rubber sleeve to tank leaking. He charge a total of S$80 to replace the drain pipe with s-trap to pvc and new rubber sleeve. Link to post Share on other sites More sharing options...
Panerex77 1st Gear June 12, 2012 Share June 12, 2012 riding on this topic of plumber, any recommended chemical solution or detergent that i can use to get rid of foul smell coming out from my toilet sink drainage? thanks Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 12, 2012 Share June 12, 2012 riding on this topic of plumber, any recommended chemical solution or detergent that i can use to get rid of foul smell coming out from my toilet sink drainage? thanks Before any inspection, we used to pour the liquid type of air freshener down the toilet bowl n sink. Whole toilets smells very nice. U can try it. We use the liquid air freshener to mop the floor too. Confirm whole toilet "pang pang". Link to post Share on other sites More sharing options...
Panerex77 1st Gear June 12, 2012 Share June 12, 2012 Before any inspection, we used to pour the liquid type of air freshener down the toilet bowl n sink. Whole toilets smells very nice. U can try it. We use the liquid air freshener to mop the floor too. Confirm whole toilet "pang pang". any recommendation for this liquid air freshener and where to get it? Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 12, 2012 Share June 12, 2012 any recommendation for this liquid air freshener and where to get it? Any brand should do. Just open the bottle and pour in half bottle : Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 12, 2012 Share June 12, 2012 If u had done a search on MCF for plumber, u would have come across this wonderful plumber : AH Soon 98550906 http://www.mycarforum.com/index.php?act=Se...ite=%2Bplumber* He is really honest and charge reasonable rates. Used him once for my my mum's place. Kitchen sink drainage pipe corroded n toilet bowl rubber sleeve to tank leaking. He charge a total of S$80 to replace the drain pipe with s-trap to pvc and new rubber sleeve. Thanks for sharing, I believe it will be very useful for all families upon home sewerage issues. Cheers. Link to post Share on other sites More sharing options...
13177 Hypersonic May 17, 2013 Share May 17, 2013 Anyone know roughly how much? Water leaking under the basic pipes? Link to post Share on other sites More sharing options...
LoverofCar 6th Gear May 17, 2013 Share May 17, 2013 (edited) Anyone know roughly how much? Water leaking under the basic pipes? you mean under the basin? the U pipe? call his number and tell them the problem. Ask for a quote on the phone.....I replace the full set of pipe under my kitchen basin (two basin type so two set of pipes) and also the two basin drainage from Ceremic type to stainless steel type for around $250. I'm quite happy with the workmanship....if they come for survey and quoted too high...just reject them... http://www.24hrsingaporeplumber.com/ Edited May 17, 2013 by LoverofCar Link to post Share on other sites More sharing options...
Mcf777 Turbocharged May 17, 2013 Share May 17, 2013 Aunty Lucy plumber chop head (carrot too small to cut). Just be aware what is the market price. Im quite familar with the parts prices. Just lazy to DIY without any equipment and tools. They came to my house (new house, without any pipe) , quoted S$400+. I asked them is it that they dont know how to lay the pipe, that's why quote so high just to get the transport fee (I think is S$15) and run road? Fxxing useless shitt. His name is Mr Aw @ AMK area. Mobile ends with 2236. Next day, look for another plumber (not from lucy), quoted S$220 and ask them to start work immediately. Settled within 2hrs. Link to post Share on other sites More sharing options...
Robin 4th Gear May 17, 2013 Share May 17, 2013 Anyone can recommend me a honest plumber? My toilet bowl choked. Last time i got a plumber, i kenna carrot head see if u can identify the problem and diy my toilet bowl also choke a few times so i just take those toliet bursh u shove a few times then flush heng... it worked Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 17, 2013 Share May 17, 2013 Solve the problem at the root cause. Eat more prunes. Link to post Share on other sites More sharing options...
13177 Hypersonic May 17, 2013 Share May 17, 2013 you mean under the basin? the U pipe? call his number and tell them the problem. Ask for a quote on the phone.....I replace the full set of pipe under my kitchen basin (two basin type so two set of pipes) and also the two basin drainage from Ceremic type to stainless steel type for around $250. I'm quite happy with the workmanship....if they come for survey and quoted too high...just reject them... http://www.24hrsingaporeplumber.com/ They provide Free On-Site Assessment? Sounds pretty good? Usually heard if they come down, default must pay for transport fees and plus repair costs. Link to post Share on other sites More sharing options...
Opel17 6th Gear May 17, 2013 Share May 17, 2013 Anyone know roughly how much? Water leaking under the basic pipes? Would you be able to show some pictures, so that we can advise further. Link to post Share on other sites More sharing options...
13177 Hypersonic May 17, 2013 Share May 17, 2013 Would you be able to show some pictures, so that we can advise further. Pai seh, no pictures. The pipes that is connected under the kitchen basic lo, when i use the basic the water will leak from the pipe. Link to post Share on other sites More sharing options...
Opel17 6th Gear May 17, 2013 Share May 17, 2013 see if u can identify the problem and diy my toilet bowl also choke a few times so i just take those toliet bursh u shove a few times then flush heng... it worked You are lucky, able to clear the choke so easily. Our toilet bowl in common toilet choked during the recent CNY. Tried using the rubber pump, chemicals, wire snake. Jialat, all the "golden pieces" floating in the bowl, almost overflowing. Had to keep the common toilet closed, and CNY guests had to use the master bedroom toilet. Let the liquid drained off slowly through the clog after several days. Removed the water tank, removed the toilet bowl, straightaway saw the reason for the clog : a scrubber brush [commonly called coconut brush] was stuck at the outlet of the toilet bowl. * after cleaning the floor during CNY spring-cleaning, I must had pour the dirty water together with the scrubber brush into the toilet bowl. * subsequently toilet papers got entangled with the scrubber brush to choked almost 99% of the outlet of the toilet bowl. Link to post Share on other sites More sharing options...
13177 Hypersonic May 17, 2013 Share May 17, 2013 Scrubber brush also can flushed into the toilet bowl, so powerful?! Heard before even if you flushed your hairs into toilet bowl, eventually it might chocked the toilet bowl. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
RAM/MicroSD issues
RAM/MicroSD issues
