Mkl22 Supersonic November 9, 2023 Share November 9, 2023 On 11/7/2023 at 9:48 PM, Beregond said: rear shock can diy easily, no need take out spring for alot of cars. 2 nuts take out can replace already Only for cheap cars with Torison beam. ↡ Advertisement Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 9, 2023 Share November 9, 2023 On 11/7/2023 at 9:48 PM, Beregond said: rear shock can diy easily, no need take out spring for alot of cars. 2 nuts take out can replace already Wont the setup be sprung... meaning once take out shock it will spring in... may be dangerous How about alignment? Link to post Share on other sites More sharing options...
Volvobrick Hypersonic November 9, 2023 Share November 9, 2023 On 11/9/2023 at 8:43 AM, t0y0ta said: Wont the setup be sprung... meaning once take out shock it will spring in... may be dangerous How about alignment? When you jack up the rear, the spring (separated from the shocks type) will be extended and thus not exerting force on the arms. I DIY before (semi trailing arm suspension) for rear. Easy only 3 bolts each side in the wheel well. 3 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 9, 2023 Share November 9, 2023 On 11/9/2023 at 8:43 AM, t0y0ta said: Wont the setup be sprung... meaning once take out shock it will spring in... may be dangerous How about alignment? What you described is MacPherson Strut. There are rear suspension that split spring and shock. I don't think alignment is required especially FWD car 2 Link to post Share on other sites More sharing options...
Beregond Supersonic November 9, 2023 Share November 9, 2023 On 11/9/2023 at 8:43 AM, t0y0ta said: Wont the setup be sprung... meaning once take out shock it will spring in... may be dangerous How about alignment? . Alignment wont be out. Cos all the nuts and bolt positions is fix. There is nothing to adjust. Even if u want 😅 Actually for front absorber. The alignment also wont go out for most car. Cos u never touch the tie rod or rack end. Most ppl do is just in case. And the small mm of nuts movements ↡ Advertisement 1 Link to post Share on other sites More sharing options...
What do you really spend on and how much?
