Porsche
Throttle2
Any panamera owner can advise me how to change the setup so audio will not auto start when the key is inserted? Also, what is the tire pressure for the standard 19 inches tires? Read the manual, it suggested 34psi on all 4? The front and rear are staggered, ok to same pressure? 34psi low compared to the recommened tire pressure on similar tire setup on BMW. Pls help. Thanks.
Edited by Panomatic
Thanks for the correction, I've not been keeping that current with the newer Scoobies. :D
Nah that's nothing. Anyway scoobs aren't as interesting as before now... Ever since the big T took over <_<
I think there should be a simple off switch for the audio system.
For tyre pressure, 34 sounds a bit low.
What are you tyre specs
Front 235/35/19
Rear 295/30/19
I believe you should do 37 for front and 39 for rear.
That would put the tyres somewhat midzone pressure.
34 i think is too low.
Front 235/35/19
Rear 295/30/19
Thanks. For the audio, I still cant find the setup to off the auto start (been trying for months). Also, can't make sport mode as default too. So must change to sport mode and change suspension every I take this ride. For the tire, I don't understand why the manual recommends low pressure for summer tires which should be the same for Singapore tires. I was also thinking of 35 & 37 setup to reduce tire wear. But worry whether it will make the ride too bouncy. Asked AD but the SA sounded not sure too. Thanks again for the advice.
Edited by Panomatic
Sport mode cannot be default.
Its the same for every other car with sports mode, i know.
In summer due to heat, pressures will rise an expand so no need to pump too much.
Forget about asking them anything lah, better you ask me! Haha
Thanks. Will try 37 & 39 and see how it goes. Not many 970 owners in this forum as most 970 onwers shld be older folks like me... Thanks and have a good evening.
I like the outer look of 991 especially the classic looking p o r s c h e at the back. Sadly, why do they change the interior centre console to Panamera look? It look so much like a family car now.
Family car???
Welcome, happy to help.
Cheers
Maybe in time to come i may also get a Panamera or a Cayenne but just cant see that yet for now.
So it is S vs Pana/Cay vs 7 series? How much time you have to settle down?
It all depends on if my family needs a second car or not
The panamera is nice to drive but parking and entry to certain car parks can be daunting. So it can be a family car that can be quite restrictive on venue I can drive to. I also take responsibility that the limitation is due my driving skill. Depending on the venue, my family may end up using the other smaller, narrower but more agile car.
Edited by Panomatic
Just a quick question, have the new boxster available already in Sinagpore. I seen it a few times (in Germany) looks really nice. A big step up over last gen in my view.
yes it is. TEsted aldy. Limited stocks..hv to wait a while to get car
Yup its a big car...but i think i'm ok.
My CLS was not exactly small either.
S far the Panamera still hasnt won my heart
If you can manage the CLS, you can manage panamera, albeit 970 spontaneous torque at low speed. I quite weak at judging turning radius, that why I can't park head in. Servotronic is a standard for me. With the porsche model you currently have, the 970 may be a disappointment. Also, the center console in the back seat scratches quite easily. Kinda painful for me as rear passengers tend to place their phone or hand carried stuffs there.
Edited by Panomatic
Yeah i can never understand why they use materials which biodegrade so quickly.
Same goes for BMw and Mercy. I guess Singapore climate especially the heat is bane to such materials.
My interior trim has been resprayed piano black so it no longer scratches or turn gooey.....hurray.
Perhaps thats one way of selling more carbon fiber trims? Haha
Checkout this website: http://www.suncoastparts.com/
Singapore weather heat & humIdity are quite damaging to the console. My frd maser console "melted" as it was regularly parked partially exposed to sunlight. Lucky, Hong Seh changed the console as it was still under warranty. Now he parked it at an underground carpark. Also, he seldom drives the maser. Smtimes, things spoil bec under use. Doubt Porsche SG covers "sticky" console under its warranty program. Anyway, have a good evening.
Edited by Panomatic
