My engine after 150,000 kms
Ncp91
5 hours ago, shutterbox said:
if open to the engine top change parts, will 1 time change as much consumables as possible
not much to change for this - head cover and spark plugs gasket, valve adjustments and maybe spark plugs, if never change before.
11 hours ago, shutterbox said:
Hi guys,
sorry for digging this up.
bought a COE Allion. 1NZ-FE engine.
cold start in morning will get rattling/hammering sound when accelerating.
after car warm up, sound seem to go away.
any workshop to recommend to do some troubleshooting and parts change?
from my own experience
it is the sign of engine and gearbox mountings hardening
  • Praise 2
Unlikely.  if it is mountings then the rattles and noises would more likely go away with less vibrations when accelerating (revving)
Do we know where the noise or rattle is coming directly from?
open the bonnet and listen to what te engine bay is saying.
it could be due to many reasons, I was pointing out one of the possibilities that is cheapest to fix 😁
my ex W204 will made a low thumping sound when the engine is cold and it went away once warm up
I believe the engine mountings rubber are harder when cold and soften up once the engine heat transferred to it after a while
I used that behaviour/sound to gauge the timing of engine mounts replacement
once replace, the sound disappear until 40,000km ~ 60,000km later depending on my luck
I see.
Its fairly easy to tell when its time for engine mounts to be replaced.
once you feel your engine block shuddering at idle, its about time
that rattling sounds like metallic sound, so i doubt its anything to do with rubber hardening
rev more, rattling louder
drive for 10mins, sound is leseen.
search on youtube.
prime suspects are VVT actuator pin or timing chain. guess these are cheaper fixes? (but seriously i dunno how cheap/expensive 😁). both of which involves opening the engine cover?
another could be valve/cylinder koyak?
search on youtube.
I guess u already check your oil level? and its full.
No ppl is going to open your engine top and change 1 pin or a timing chain. it will be a top overhaul min.
EO changed.
sound still there.
I could call up a few workshops to ask, but as a ballpark (and not be cheated), how much are we look at to do a engine top overhaul? 😞
9 minutes ago, shutterbox said:
EO changed.
sound still there.
What oil did you use. Go for some good detergent oil. Might be able to free up the stuck pin.
also how long do you intend to drive it for.
Mobile 1 EO.
COE last for another 7yrs.
Apart from this sound, im quite OK with all this allion drives.
Just dun want a problem to snowball into something that costs alot more to deal with.
34 minutes ago, shutterbox said:
EO changed.
sound still there.
japanese car about 3k+- depend how atas the ws, and how many parts replace.
but from what u say only morning when cold start got problem. it would be crazy to do a overhaul for it, unless your pocket very deep or u really buay tahan. maybe change to a thicker oil like 5w50 or some addictive. morning have some patience let the engine idle 1 min before driving off.
A allion 1.6 used engine imported from japan plus replacement also cost u about 3k+- only . those engine normally still very very good condition.
u can drive till your engine burst replace whole engine at 3k. why go overhaul for abit of sound now😅
  • Praise 3
True also la.
If remove engine top, change out the wearable parts, also 3k?
14 minutes ago, shutterbox said:
True also la.
depend alot on ws😅
  • Haha! 1
1 hour ago, shutterbox said:
Mobile 1 EO.
Then I would suggest 6-7k oil changes with mobil1. To “clean” the engine.
Using engine flush may help but then you run the risk of compromising the engine seals. Causing leaks.
the best way is to change out the oil more frequently for now to let it clean up the engine
  • Praise 2
search on youtube.
then it is likely the timing belt wheels.
Thanks guys.
I also realized that the sound only comes in when engaged to Drive.
Didnt seem to hear it when vehicle is in P/N n I tried revving it.
CVT Gear change was ok, didnt feel lost of power
Does that point to a different problem?
Edited by shutterbox
28 minutes ago, shutterbox said:
Thanks guys.
Then it’s transmission. Change the cvt fluid? That’s about the most you can do. And then drive till the cvt breaks then repair. No point touching it until it breaks. Since a rebuild will change most of the wear components. Rebuilding it earlier when it is still working is just a waste of money.
If it happens only when cold. Then maybe not enough fluid and it takes for that few seconds for the pump to circulate the fluid. In any case a change of fluid will help. Make sure you use the correct fluid. It’s either atf-ws or cvt-fe. Make sure it is right one. And only use original fluid.
Edited by Mkl22
  • Praise 2
