Roh96 6th Gear April 18, 2013 Author Share April 18, 2013 Sometimes it doesnt give signs, i remember the radiator hose give way and breaks and the radiator just dry up and by the time the sign show, it is already 'overheated'! Agree, some parts will fail without giving signs. Unlike weak battery, oil leak etc, where there are warning signs and sufficient time for me to respond. ↡ Advertisement Link to post Share on other sites More sharing options...
Roh96 6th Gear April 18, 2013 Author Share April 18, 2013 later tio lemon then lppl Tio lemon is machiam like tio 4D. Consider heng lor. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 18, 2013 Share April 18, 2013 Change the brake fluid and pads. Link to post Share on other sites More sharing options...
Roh96 6th Gear April 18, 2013 Author Share April 18, 2013 Change the brake fluid and pads. Is this mean to be a joke? Brake fluid and pads are quite lasting leh. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 18, 2013 Share April 18, 2013 Is this mean to be a joke? Brake fluid and pads are quite lasting leh. After 8 years and 130k? No its not meant to be a joke. Brake fluid is hydroscopic, that means it absorbs water from the air and becomes less efficient. So I hope TS has changed brake fluid more than once over the last 8 years. Anyway thank you for your question, brake fluid renewal is often neglected as most people over look it. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 18, 2013 Share April 18, 2013 If TS has not renewed his brake fluid and pads over 8 years, please don't drive to close behind any silver Getz. Thanks Link to post Share on other sites More sharing options...
Hshs 5th Gear April 18, 2013 Share April 18, 2013 Is this mean to be a joke? Brake fluid and pads are quite lasting leh. Yeah, then follow by power steering fluid,coolant,wiper rubber, ATF oil,tires, motor and aircon cooling fan, engine mounting, shock absorber, upper/lower arm drive shaft, wheel bearing, brake caliper/disk, door regulator etc etc..... :D Never end. IMHO, just drive if find something wrong then change. Normal servicing is good enough. If worry too much then change new car Link to post Share on other sites More sharing options...
Tcx607 4th Gear April 18, 2013 Share April 18, 2013 >Roh96, yes you can change the parts before breakdown such as water pump, aircon compressor, brake hose etc. Since your ride is already 8yrs and you want keep it in good health. Do your calculation if you want to keep the car beyond 10yrs. Else, scraping the car on 10yrs COE expiry is a waste. I believe your Toyota is Japan made based on the age (8yrs old). This should be very reliable and can go beyond 10yrs. You may get your spare parts from MingGhee (near Boon Keng industrial area towards Eminent plaza) Link to post Share on other sites More sharing options...
Mysportwish 1st Gear April 18, 2013 Share April 18, 2013 no amount of preventive maintenance can deter a issue from happening/surfacing. what is important is a back-up plan, pls call this number if need urgent services - 6552 1111 (http://www.cdgtaxi.com.sg/commuters_services_booking.mvn) Link to post Share on other sites More sharing options...
Fuelsaver Supercharged April 18, 2013 Share April 18, 2013 Nothing beats the new car smell. N u being the first to enjoy it! Link to post Share on other sites More sharing options...
Kangadrool Supersonic April 18, 2013 Share April 18, 2013 N u being the first to enjoy it! Actually the car jockeys enjoyed whacking it first. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged April 18, 2013 Share April 18, 2013 Tio lemon is machiam like tio 4D. Consider heng lor. Choy! No need this kinda hengness. Link to post Share on other sites More sharing options...
Yuan 6th Gear April 19, 2013 Share April 19, 2013 (edited) After 8 years and 130k? No its not meant to be a joke. Brake fluid is hydroscopic, that means it absorbs water from the air and becomes less efficient. So I hope TS has changed brake fluid more than once over the last 8 years. Anyway thank you for your question, brake fluid renewal is often neglected as most people over look it. I agree. Brake fluid should be changed almost once every 2 years due to our tropical and hot weather and start stop traffic conditions in Singapore. I changed mine regularly. It is an essential part of the brake system. Edited April 19, 2013 by Yuan Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 19, 2013 Share April 19, 2013 I agree. Brake fluid should be changed almost once every 2 years due to our tropical and hot weather and start stop traffic conditions in Singapore. I changed mine regularly. It is an essential part of the brake system. The best thing its also cheap to do. I pay $6 for a bottle of brake fluid and get it changed in JB for RM20. Hope more people read our post and change their brake fluid regularly. Especially those driving behind me. Link to post Share on other sites More sharing options...
Timex1441 1st Gear April 19, 2013 Share April 19, 2013 DIY lo belt not that difficult chain than headache no lah, i'm not confident with such stuff....at most i can change light bulbs....but dun want to touch anything tat can risk the engine... Link to post Share on other sites More sharing options...
Wira 1st Gear April 19, 2013 Share April 19, 2013 find a reliable motor workshop and send for servicing every 10,000 km. that should be quite sufficient since Toyota is quite reliable. usually brake disc and pads will need to change every 1-2 years depending on usage. Link to post Share on other sites More sharing options...
13177 Hypersonic April 19, 2013 Share April 19, 2013 Agree, some parts will fail without giving signs. Unlike weak battery, oil leak etc, where there are warning signs and sufficient time for me to respond. Battery flat sometimes also no warning sign. Link to post Share on other sites More sharing options...
13177 Hypersonic April 19, 2013 Share April 19, 2013 I agree. Brake fluid should be changed almost once every 2 years due to our tropical and hot weather and start stop traffic conditions in Singapore. I changed mine regularly. It is an essential part of the brake system. Can ask the mechanic to check during your servicing whether it is necessary to change the brake fluid etc. ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Coolant question
Coolant question
Car repair and maintenance
Extending COE for Toyota Wish (2008)
Ho Hup Seng......Some good info for our Brudders
Maintenance Tips For Beginners/First Time Car Owners
