Chucky2007 Turbocharged October 1, 2016 Share October 1, 2016 LS at kaki...aka L....SeCan check with you how much is your 19" Michelin latitude3 at Leong Seng? And what the tyre size? ↡ Advertisement Link to post Share on other sites More sharing options...
Mb1802003 Neutral Newbie October 1, 2016 Share October 1, 2016 Can check with you how much is your 19" Michelin latitude3 at Leong Seng? And what the tyre size?I bought together with grams lights rims. Each rim approx 680 list price. Though all in all I top up 2750. So I can't say he charge me exactly hope much for the tires. It possibly depends what rims you getting from them . Guess you need the rim to upsize anywayCan check with you how much is your 19" Michelin latitude3 at Leong Seng? And what the tyre size?235 55 r19 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 1, 2016 Share October 1, 2016 Very good deal at $2750 for 19" rays with latitude3 tyres Link to post Share on other sites More sharing options...
Panerex77 1st Gear October 2, 2016 Share October 2, 2016 any idea how much would it cost to change the stock antenna to shark fin? Also, for the dunlop grandtek 18 inch stock tyres, do you inflate above the recommended PSI/kPA to improve fuel efficiency? Link to post Share on other sites More sharing options...
Jl25 1st Gear October 3, 2016 Share October 3, 2016 How did you guys run in the car? Not more than 2rpm and not exceeding 100km/hr for the first 1000km? The car manual does suggest a break in schedule (pg 5-3) for the first 1600km. Link to post Share on other sites More sharing options...
Panerex77 1st Gear October 3, 2016 Share October 3, 2016 The car manual does suggest a break in schedule (pg 5-3) for the first 1600km.Thanks I have a hard time looking through the manual. I cannot even find the minimum Ron in the manual. Is there a PDF version out there? Link to post Share on other sites More sharing options...
Jl25 1st Gear October 4, 2016 Share October 4, 2016 Thanks I have a hard time looking through the manual. I cannot even find the minimum Ron in the manual. Is there a PDF version out there? The minimum petrol grade is 91Ron (p9-5). Xtrail engine model is MR20DD. See last para for the petrol grade. Link to post Share on other sites More sharing options...
Tyjs2005 Neutral Newbie October 4, 2016 Share October 4, 2016 (edited) Thanks I have a hard time looking through the manual. I cannot even find the minimum Ron in the manual. Is there a PDF version out there? Hi Panerex77 have downloaded this manual sometime back and hopefully it helps sorry... file too big for upload. please use below link which will only be available for 7 days only. https://we.tl/dPWrMHdWg8 Edited October 4, 2016 by Tyjs2005 Link to post Share on other sites More sharing options...
Panerex77 1st Gear October 4, 2016 Share October 4, 2016 Thanks this is helpful! Another question, when you start your new car in the morning, how long do you let the engine warm up before driving off? 1 min? Or wait till the temp needle moves? Link to post Share on other sites More sharing options...
Chrispie 5th Gear October 4, 2016 Share October 4, 2016 Thanks this is helpful! Another question, when you start your new car in the morning, how long do you let the engine warm up before driving off? 1 min? Or wait till the temp needle moves? Don't over react because it's a new car. There's no need to warm up. Just crank and drive. Link to post Share on other sites More sharing options...
Little_prince Supersonic October 4, 2016 Share October 4, 2016 Thanks this is helpful! Another question, when you start your new car in the morning, how long do you let the engine warm up before driving off? 1 min? Or wait till the temp needle moves? lol. warm up is so 1970s bro. Link to post Share on other sites More sharing options...
Jl25 1st Gear October 4, 2016 Share October 4, 2016 lol. warm up is so 1970s bro. I had the same thought too at the beginning but still check on the manual to double confirm, and found out the manual did suggest to let the engine warm up for 30 sec. Link to post Share on other sites More sharing options...
Panerex77 1st Gear October 4, 2016 Share October 4, 2016 I had the same thought too at the beginning but still check on the manual to double confirm, and found out the manual did suggest to let the engine warm up for 30 sec.Wow, you really study the Manual by hard! Kudos to that. Link to post Share on other sites More sharing options...
Pocy Hypersonic October 4, 2016 Share October 4, 2016 I had the same thought too at the beginning but still check on the manual to double confirm, and found out the manual did suggest to let the engine warm up for 30 sec.It's good practice to let your engine lubricated before shifting to any gear. Cheers! Link to post Share on other sites More sharing options...
Karu 6th Gear October 4, 2016 Share October 4, 2016 Anyone sending car to external workshops for svc? Used up all the free svc after 10k. Will probably use outside ws for 20k. Link to post Share on other sites More sharing options...
Pocy Hypersonic October 4, 2016 Share October 4, 2016 Anyone sending car to external workshops for svc? Used up all the free svc after 10k. Will probably use outside ws for 20k.Did you check with TC whether it will void warranty? Link to post Share on other sites More sharing options...
Panerex77 1st Gear October 4, 2016 Share October 4, 2016 I find the arm rest compartment to deep and difficult to store things orderly. Any recommendation for a compartment tray to split the space into 2 layers of storage? Link to post Share on other sites More sharing options...
gorilla_chow 2nd Gear October 5, 2016 Share October 5, 2016 I find the arm rest compartment to deep and difficult to store things orderly. Any recommendation for a compartment tray to split the space into 2 layers of storage? hi there you can buy the attached tray from TB, ebay or aliexpress. I fine it is a good buy, you may wanna consider. ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Nissan QashQai 2014 Part 2
Thomas Cup 2014/2018
future of mitsubishi?
