Snowman16 1st Gear June 13, 2017 Share June 13, 2017 Hi bros, My civic has sound on the rear wheel when i am driving at higher speed like may be from 60 or 70km/h onwards.. it will go louder when i drive faster. Is it because i need to do wheel rotation n alignment? Anyone can help me with this? Many thanks in advance I had the same problem too with my old ride and it got louder as i go faster.Bring it to my mechanics to check and discovered wheel bearing damaged and because of this it spoil the brake disc as well. In the end got to replace both. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Franwilliam 1st Gear June 13, 2017 Share June 13, 2017 wow..ok then i will do that..any workshop that you guys can recommend? Link to post Share on other sites More sharing options...
Snowman16 1st Gear June 13, 2017 Share June 13, 2017 wow..ok then i will do that..any workshop that you guys can recommend? You can just bring back to your usual workshop if you have one else i can recommend you mine.Just PM me. Link to post Share on other sites More sharing options...
Bluepica 4th Gear November 2, 2017 Share November 2, 2017 Riding on this thread. Old car, new tire, need to do alignment, but what about new car, change new tire, need to do alignment? or the general rule of thumb, change tire, must do alignment ? thanks Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 2, 2017 Share November 2, 2017 Riding on this thread. Old car, new tire, need to do alignment, but what about new car, change new tire, need to do alignment? or the general rule of thumb, change tire, must do alignment ? thanks Alignment is independant of change tyre. https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=4 1 Link to post Share on other sites More sharing options...
Kurty Supercharged November 2, 2017 Share November 2, 2017 if change rear suspension, need to do alignment too? was told by workshop, as long it's drum brake rear, need not to. Link to post Share on other sites More sharing options...
Bluepica 4th Gear November 2, 2017 Share November 2, 2017 if change rear suspension, need to do alignment too? was told by workshop, as long it's drum brake rear, need not to. but i was told if change suspension, it's must ... cos I changed before 1 Link to post Share on other sites More sharing options...
Kurty Supercharged November 2, 2017 Share November 2, 2017 but i was told if change suspension, it's must ... cos I changed before yeah, if yours is using a rear disc brake system. for drum type, need not to. Sorry if i got this wrongly, thats what the workshop told me. Link to post Share on other sites More sharing options...
Cypher 4th Gear November 2, 2017 Share November 2, 2017 yeah, if yours is using a rear disc brake system. for drum type, need not to. Sorry if i got this wrongly, thats what the workshop told me. I believe it depends on the suspension setup and not dependent on the type of brake configuration. Multi link suspension I believe is adjustable. 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged November 2, 2017 Share November 2, 2017 (edited) if change rear suspension, need to do alignment too? was told by workshop, as long it's drum brake rear, need not to. FWD? Some FWD cars cannot do rear alignment as they uses torsion beam at the rear. Edited November 2, 2017 by Stratovarius Link to post Share on other sites More sharing options...
Stratovarius Turbocharged November 2, 2017 Share November 2, 2017 Riding on this thread. Old car, new tire, need to do alignment, but what about new car, change new tire, need to do alignment? or the general rule of thumb, change tire, must do alignment ? thanks Regardless of old or new car. Change tire no need. Change suspension def need. I do alignment once or twice a year regardless of changing suspension as my alignments tends to go out quite easily. Maybe due to the coilovers. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic November 2, 2017 Share November 2, 2017 Riding on this thread. Old car, new tire, need to do alignment, but what about new car, change new tire, need to do alignment? or the general rule of thumb, change tire, must do alignment ? thanks see how your old set of tyres wear if got 1 sided ( inside or outside wear alot ). can do 1 alignment check to see any things out. if nothing wrong 4 pcs old tyres all wear evenly then dun backside itchy go ajust , wait extra problem come out or after u replace new tyres. if your steering is slanted to 1 side, then also confirm must do. Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 2, 2017 Share November 2, 2017 FWD? Some FWD cars cannot do rear alignment as they uses torsion beam at the rear. My Mini rear suspension is multi-link. There is limited adjustment that can be done. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged November 2, 2017 Share November 2, 2017 My Mini rear suspension is multi-link. There is limited adjustment that can be done. Not sure of the design of multilink for the mini. But mutltilink should have the luxury of space for the adjustment of links. Quite surprise that there is limited adjustment. Link to post Share on other sites More sharing options...
Lmws214 Turbocharged December 16, 2017 Share December 16, 2017 good info,thanks! but i was told if change suspension, it's must ... cos I changed before Link to post Share on other sites More sharing options...
Freak 1st Gear December 28, 2017 Share December 28, 2017 can I check why are both my front tyres only balding at the outside while the inner side are still ok. is it cos of alignment? or something to do with lower arm? advise pls. thanks Link to post Share on other sites More sharing options...
dcb Turbocharged December 28, 2017 Share December 28, 2017 (edited) Camber. It's on the positive side. can I check why are both my front tyres only balding at the outside while the inner side are still ok. is it cos of alignment? or something to do with lower arm? advise pls. thanks Edited December 28, 2017 by dcb Link to post Share on other sites More sharing options...
Cypher 4th Gear December 28, 2017 Share December 28, 2017 Can be also due to Toe wear too.. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Nissan Preventive Maintenance Programme
Nissan QashQai 2014 Part 2
