Daniel0606 2nd Gear January 17, 2018 Share January 17, 2018 Bringing up an old thread.....Anyone tried wheel alignment at Kian Teong Auto-care in Sin Ming ? What are their charges and skills ?Kian Teong used to be my regular ws before i changed to my new ride. Skill wise good but can be a little pricey. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
JinSherr January 23, 2018 Share January 23, 2018 (edited) Alignment - all your tires pointing the in the same direction and be as flat on the road as they can. It's something you should have checked about once a year anyway. Get a lifetime alignment package for your car, and have it checked periodically. I usually use Tech Drive workshop for this purpose. It's not expensive so don't worry so much. Edited January 23, 2018 by JinSherr Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear January 23, 2018 Share January 23, 2018 Kenny wheel alignment....heard he jack up the price from 50 to 70 Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 24, 2018 Share January 24, 2018 Kenny wheel alignment....heard he jack up the price from 50 to 70 probably he is too busy to cope with the demand, Proper wheel alignment require time to have them properly setup - test - adjust - test - test drive. $70 is still reasonable to me if they can do a Professional Job . Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 24, 2018 Share January 24, 2018 can I check why are both my front tyres only balding at the outside while the inner side are still ok. is it cos of alignment? or something to do with lower arm? advise pls. thanks is very common to have outerside balding especially the front 2 or front left, it is due to our Road condition and many cover carpark needs us to drive clockwise ramp which make our front left wheel working much harder than right side. I will say Wheel alignment doesn't fit this issue, and I personally don't see the point of spending money on this issue. we have worldclass road and which is so good that wheel alignment does not require when it is necessary. when do we need the service ? replacing any part is linked to your suspension system. any hard impact to your wheels any one can share your opinion here. And I personally usually do my own self test by testing on road that is long straight enough to let go my hand from steering wheel for just 2-5 second and so long my car moving straight or little veer to the left is normal due to surface made lightly tilted for water drainage. Is just my POV thanks Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 24, 2018 Share January 24, 2018 is very common to have outerside balding especially the front 2 or front left, it is due to our Road condition and many cover carpark needs us to drive clockwise ramp which make our front left wheel working much harder than right side. I will say Wheel alignment doesn't fit this issue, and I personally don't see the point of spending money on this issue. we have worldclass road and which is so good that wheel alignment does not require when it is necessary. when do we need the service ? replacing any part is linked to your suspension system. any hard impact to your wheels any one can share your opinion here. And I personally usually do my own self test by testing on road that is long straight enough to let go my hand from steering wheel for just 2-5 second and so long my car moving straight or little veer to the left is normal due to surface made lightly tilted for water drainage. Is just my POV thanks My Mini virgin alignment at 42k km. My previous BMW virgin alignment at 100k km Link to post Share on other sites More sharing options...
Beregond Supersonic January 24, 2018 Share January 24, 2018 is very common to have outerside balding especially the front 2 or front left, it is due to our Road condition and many cover carpark needs us to drive clockwise ramp which make our front left wheel working much harder than right side. I will say Wheel alignment doesn't fit this issue, and I personally don't see the point of spending money on this issue. we have worldclass road and which is so good that wheel alignment does not require when it is necessary. when do we need the service ? replacing any part is linked to your suspension system. any hard impact to your wheels any one can share your opinion here. And I personally usually do my own self test by testing on road that is long straight enough to let go my hand from steering wheel for just 2-5 second and so long my car moving straight or little veer to the left is normal due to surface made lightly tilted for water drainage. Is just my POV thanks 3d alignment is very useful, it let us see the caster camber toes reading of our car front n rear. the only problem is alot of workshop dun know how to read the data and analysis the problem properly. like u mention the car veer to 1 side, ( pulling effect when let go of hand ) its never the toe in/out problem Link to post Share on other sites More sharing options...
flashbang Turbocharged January 24, 2018 Share January 24, 2018 is very common to have outerside balding especially the front 2 or front left, it is due to our Road condition and many cover carpark needs us to drive clockwise ramp which make our front left wheel working much harder than right side. I will say Wheel alignment doesn't fit this issue, and I personally don't see the point of spending money on this issue. we have worldclass road and which is so good that wheel alignment does not require when it is necessary. when do we need the service ? replacing any part is linked to your suspension system. any hard impact to your wheels any one can share your opinion here. And I personally usually do my own self test by testing on road that is long straight enough to let go my hand from steering wheel for just 2-5 second and so long my car moving straight or little veer to the left is normal due to surface made lightly tilted for water drainage. Is just my POV thanks Good to go for an alignment before inspection, else if fail side slip, have to waste time go align then go back to test. Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 25, 2018 Share January 25, 2018 Good to go for an alignment before inspection, else if fail side slip, have to waste time go align then go back to test. percentages fail the sideslip during the inspection is very low , it is Good to do so before Inspection if you are willing spend some money there but do remember to Inform them you are sending the car for Inspection because the adjustment is slight vary from Standard alignment. Anyway can share what is Side slip test for ? Link to post Share on other sites More sharing options...
flashbang Turbocharged January 26, 2018 Share January 26, 2018 percentages fail the sideslip during the inspection is very low , it is Good to do so before Inspection if you are willing spend some money there but do remember to Inform them you are sending the car for Inspection because the adjustment is slight vary from Standard alignment. Anyway can share what is Side slip test for ? Side slip test is for checking the alignment lor.... Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 26, 2018 Share January 26, 2018 Side slip test is for checking the alignment lor.... sideslip test is just part of the alignment. still wondering Why the Vehicle Test Center only test Sideslip ? Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear January 26, 2018 Share January 26, 2018 sideslip test is just part of the alignment. still wondering Why the Vehicle Test Center only test Sideslip ? If check other things, inspection cost will go up Link to post Share on other sites More sharing options...
Freak 1st Gear January 26, 2018 Share January 26, 2018 can I check why are both my front tyres only balding at the outside while the inner side are still ok. is it cos of alignment? or something to do with lower arm? advise pls. thanks I just changed the front 2 tyres just now as they are balding very fast especially the front left almost 2/3 already bald. left the most inner side still good. the workshop said its most probably camber. they say to go jb and change the camber bolt. is it necessary or can any tyre shop "re-aligned" the camber so that the balding wont happen? and when they tightened the nut there is a "click-click" sound which they mentioned is my lower arm. can I just change the bushing on the arm or must I change the whole arm? Need advise. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan QashQai 2014 Part 2
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
