flikmy 2nd Gear March 25, 2017 Share March 25, 2017 What freebies did you get? What's a CS3? Managed to get solar film, 2ch car camera, gps and 2yr free servicing. ↡ Advertisement Link to post Share on other sites More sharing options...
Carhorn 5th Gear March 25, 2017 Share March 25, 2017 That sounds like asking me to loot gao gao :). Tech says dun go pass 3k during run in period. MI mechs know shit. they told me led boot and cabin lights are the cause and are bad for my car battery as they drained more than normal bulbs when my car batt need replacement after 6 mths. they also told me that by installing sti strut bar on my own will void my suspension warranty unless install by their mechs. lol Link to post Share on other sites More sharing options...
Tohto Hypersonic March 25, 2017 Share March 25, 2017 That sounds like asking me to loot gao gao :). Tech says dun go pass 3k during run in period. Read your owner manual. It definitely more than that. Subaru engineer should know better than those tech. Link to post Share on other sites More sharing options...
shutterbox 3rd Gear March 25, 2017 Share March 25, 2017 I'm curious how u guys loot 3k rpm? I hit 120kph w Ard 2300 rpm nia. Or need to switch to S/S# mode then can? Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic March 26, 2017 Share March 26, 2017 I'm curious how u guys loot 3k rpm? I hit 120kph w Ard 2300 rpm nia. Or need to switch to S/S# mode then can? Aiyo, when traffic light turns green, just step on the throttle fully and don't release, you will pass 3000 liao ma. It doesn't have to be cruising to be at 3000. Link to post Share on other sites More sharing options...
Kopicup71 Neutral Newbie March 26, 2017 Share March 26, 2017 Managed to get solar film, 2ch car camera, gps and 2yr free servicing.Can recommend your SE to me? So far I was offered solar film and window visors only. Still considering...... Link to post Share on other sites More sharing options...
Carhorn 5th Gear March 26, 2017 Share March 26, 2017 Can recommend your SE to me? So far I was offered solar film and window visors only. Still considering...... Wat sort of freebies u are getting depends on the loan amount and tenure. The same SE can gives different stuff based on these 2 areas. Link to post Share on other sites More sharing options...
Kopicup71 Neutral Newbie March 26, 2017 Share March 26, 2017 Wat sort of freebies u are getting depends on the loan amount and tenure. The same SE can gives different stuff based on these 2 areas.I planning 60% loan for FXT over 5 years. Will nego with SE for more freebies.... Link to post Share on other sites More sharing options...
Tohto Hypersonic March 26, 2017 Share March 26, 2017 I'm curious how u guys loot 3k rpm? I hit 120kph w Ard 2300 rpm nia. Or need to switch to S/S# mode then can? Overly light food easy to cause carbon build up in the engine. Can recommend your SE to me? So far I was offered solar film and window visors only. Still considering...... Solar film standard on all Subaru. Don't kana bluff.Send the solar film they installed is lousy quality. The IR and UV rejection is very low. Link to post Share on other sites More sharing options...
Pocy Hypersonic March 26, 2017 Share March 26, 2017 Overly light food easy to cause carbon build up in the engine. Solar film standard on all Subaru. Don't kana bluff. Send the solar film they installed is lousy quality. The IR and UV rejection is very low. You meant carbon built up also resulting in higher petrol consumption? Link to post Share on other sites More sharing options...
flikmy 2nd Gear March 26, 2017 Share March 26, 2017 Can recommend your SE to me? So far I was offered solar film and window visors only. Still considering...... The freebies I got were part of the standard package. I didn't really get much additional freebies as loan I took on was the bare minimum. As for the solar film quality, I don't think it's that bad. However, what I find useful is the window shades that I bought from MI. Does help cut the heat quite a bit and my children don't really complain of the glaring sun in the mornings. Link to post Share on other sites More sharing options...
DC1977 3rd Gear March 26, 2017 Share March 26, 2017 Overly light food easy to cause carbon build up in the engine. Solar film standard on all Subaru. Don't kana bluff. Send the solar film they installed is lousy quality. The IR and UV rejection is very low. agreed!!!! floor the pedal once a while...to clear the carbon!!! no need run above the speed limit.... You meant carbon built up also resulting in higher petrol consumption? confirm la....engine will not be healthy in long term also....just like human body lo.... Link to post Share on other sites More sharing options...
Kentz Neutral Newbie March 27, 2017 Share March 27, 2017 Collected my FNA just 2 days ago, now the car has got stop & start, anyway to permanently disable it or make the system disable as default? Also my SE mentioned that MI now has 2 types of door lock for Forester, 1 is will locked when stepping on brake before moving off, cost around $180. The other is speed lock, above 20km/h then will lock, cost around $300++, sorry cannot remember the exact figure. Link to post Share on other sites More sharing options...
Shox87 4th Gear March 27, 2017 Share March 27, 2017 Collected my FNA just 2 days ago, now the car has got stop & start, anyway to permanently disable it or make the system disable as default? Also my SE mentioned that MI now has 2 types of door lock for Forester, 1 is will locked when stepping on brake before moving off, cost around $180. The other is speed lock, above 20km/h then will lock, cost around $300++, sorry cannot remember the exact figure. the forester now comes with start-stop technology? My FXT is less than 3 months old. At that time, ours do not come with start-stop. It would be much cheaper to do the door lock module outside compared to MI. Link to post Share on other sites More sharing options...
mrhan1982 4th Gear March 27, 2017 Share March 27, 2017 the forester now comes with start-stop technology? My FXT is less than 3 months old. At that time, ours do not come with start-stop. It would be much cheaper to do the door lock module outside compared to MI. Stop start can be quite irritating. My fren's BMW 320 has it and he always have to switch it off as the sudden jerk is quite irritating. I personally feel that stop start is quite a gimmick. For a higher performing car such as fxt, is there a need to save that bit of fuel? I rather get a 8 speed gear box than stop start. Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear March 27, 2017 Share March 27, 2017 lol.... save fuel so that you can pay for replacement starter motor Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic March 27, 2017 Share March 27, 2017 I wish mine doesn't come with the ASS (Automatic Start Stop) I always have to switch it off manually before I drive and many times I still forget. 1 Link to post Share on other sites More sharing options...
flikmy 2nd Gear March 27, 2017 Share March 27, 2017 the forester now comes with start-stop technology? My FXT is less than 3 months old. At that time, ours do not come with start-stop. It would be much cheaper to do the door lock module outside compared to MI. Same here, my FXT was registered late Jan. Not really sure if I would like the start-stop mechanism. Hearing most other drivers just turn it off when they start the car. As for the lock module, wouldn't doing it outside void the warranty? Not sure if it's worth the difference in price especially since we already spend quite a bit more on servicing with MI already. I guess, if we're not concerned about the warranty, then doing the lock module outside would make more sense. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
