Tohto Hypersonic March 18, 2017 Share March 18, 2017 Yes, I noticed that as well, though I rarely engaged in S#. However, surprisingly, the FC is about the same despite that the RPM is higher in S mode. Why is that so?At S mode engine is keep in best power band around 2k rpm. You hardly need to hit hard on the accelerator to get it move fast. Just slight tap will do. So engine is always at a constant keep which is good for FC. ↡ Advertisement Link to post Share on other sites More sharing options...
Savvy777 1st Gear March 18, 2017 Share March 18, 2017 Just to clarify any misconception based on some follow up comment by bros. Forester originally comes with fog light and can be used under the right condition - extreme low visibility situation. Who says there isn't this type of situation in Singapore ? I am sure many brothers use the fog light before, one time or the other in the course of driving over the years when situation warrants it.I would put it in another angle, we can live without fog light in Singapore unless the ice age returns (pun intended :) For now, the fog light is just a piece of ornamental hardware to me. Solely, IMO. Link to post Share on other sites More sharing options...
kermitfm 4th Gear March 18, 2017 Share March 18, 2017 I would put it in another angle, we can live without fog light in Singapore unless the ice age returns (pun intended :) For now, the fog light is just a piece of ornamental hardware to me. Solely, IMO. I agree. What we experience in Singapore is mist. The difference between mist and fog is visibility (fog has lower visibility). Using normal headlamps in a fog will make visibility much lower because the height is higher and the throw more directional towards the front. This cause back scatter which lowers the visibility. Fog lights are mounted lower and the spread is wider. This reduce the forward throw and lowers the back scatter. More importantly, it spreads wider so the driver can see the the side of the roads better. And this is the reason why it is illegal to drive with fog lights on when the weather is good. Since the spread is wider, it causes more glare to on-coming traffic which is on the side. The main headlamp, because it is more directional, does not spill over to the other lane. A fog lioght does. 7 Link to post Share on other sites More sharing options...
ChristopherChia 4th Gear March 18, 2017 Share March 18, 2017 The Forester's back brake light is small. Anyone converted the rear reflector to brake light ones? Link to post Share on other sites More sharing options...
Sarion 4th Gear March 18, 2017 Share March 18, 2017 >>>> - Followed a BMW 5 series and a Lexus RX at one stage, and was travelling at 160+ km/h for a while without realizing how fast I was going, the engine was not straining at all, and it still felt very stable. So if you are brave/stupid enough to try on Malaysian highways, and probably need better tyres than the stock ones, I think 200+ km/h is easily achievable the car will go to almost where the speedo stops and that's > 200km/h. old legacy owners have proven that it can go to 260km/h before, so I am quite sure FA20DIT will do the same too. I changed my fog lights with a set of LED bulbs. Purchased a set from AliExpres which costs around US$8 with delivery. It fitted perfectly into the fog light slot. Make sure u choose the H11 base bulb which will fit exactly the 2016 Forester. The bulb comes with a socket base ( just like the stock bulb) and u just plug to the car's wire connector for it to work. It emits very strong & bright light that make your car very visible to every motorist around you LEDs are high heat devices... u sure u wanna trust a no reputation US$8 unit near the engine bay? sometimes there's a reason why bulbs like Philips, PIAA cost so much, cos' there is $ spent in R&D to ensure they don't burn up in the car and destroy something else or the whole car. have experienced cheapo pole LED die very fast in my car due to heat besides a HID reflector unit, but changed to Philips and lasted over 3yr now still no issue. 1 Link to post Share on other sites More sharing options...
Wahtk 2nd Gear March 18, 2017 Share March 18, 2017 At S mode engine is keep in best power band around 2k rpm. You hardly need to hit hard on the accelerator to get it move fast. Just slight tap will do. So engine is always at a constant keep which is good for FC. First off, don't know how you guys get such good mileage, in Singapore I barely manage 9 km/l, maybe it's my driving style and/route. Interesting on the use of I vs S mode, on the highway cruising at a steady speed, in S mode I definitely got worse mileage, but been driving on S recently and although the revs seem to be higher at corresponding speeds, at the end of the trip the mileage per trip seems to be better?????? I'm wondering if the type and brand of petrol makes a difference too, as I recently switched from Shell to Mobil. Link to post Share on other sites More sharing options...
Alexleech 1st Gear March 18, 2017 Share March 18, 2017 the car will go to almost where the speedo stops and that's > 200km/h. old legacy owners have proven that it can go to 260km/h before, so I am quite sure FA20DIT will do the same too. LEDs are high heat devices... u sure u wanna trust a no reputation US$8 unit near the engine bay? sometimes there's a reason why bulbs like Philips, PIAA cost so much, cos' there is $ spent in R&D to ensure they don't burn up in the car and destroy something else or the whole car. have experienced cheapo pole LED die very fast in my car due to heat besides a HID reflector unit, but changed to Philips and lasted over 3yr now still no issue. Thanks bro for highlighting possible over heating hazard Anyway, so far I haven't use the fog lights in Singapore and probably only use it when driving in Malaysia under poor visibility condition Link to post Share on other sites More sharing options...
ECONOMIC 4th Gear March 19, 2017 Share March 19, 2017 Just back from MI today for my 10K servicing. I enquired about maintenance package and I sign up for the existing 2 years / 4 services package @ $1355 . SE said new maintenance package not out yet but likely to be more costly. It will replace the existing package very soon .SE told me that MI has surge of sales in recent 1 year, mainly forester. Their servicing workload suddenly increase and can't handle well. So they are increasing their servicing fees.those who haven't buy pls be aware. Those who bought can wait to see how much increase. Normal servicing outside won't void warranty right? Anyone knows? If will void, aren't we tied to MI servicing for 5 years, even if they increase servicing fee? Link to post Share on other sites More sharing options...
BenTong Turbocharged March 19, 2017 Share March 19, 2017 SE told me that MI has surge of sales in recent 1 year, mainly forester. Their servicing workload suddenly increase and can't handle well. So they are increasing their servicing fees.those who haven't buy pls be aware. Those who bought can wait to see how much increase. Normal servicing outside won't void warranty right? Anyone knows? If will void, aren't we tied to MI servicing for 5 years, even if they increase servicing fee? Confirmz void if service outside..for all ADs and even PIs if they give .. Link to post Share on other sites More sharing options...
ECONOMIC 4th Gear March 19, 2017 Share March 19, 2017 Confirmz void if service outside..for all ADs and even PIs if they give ..But car already buy from them. If they increase servicing price too much, i may just have to let go the warranty. Made in japan suppose to be reliable right? Ha ha... this is stupid. Anyway see increase how much first Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic March 19, 2017 Share March 19, 2017 the car will go to almost where the speedo stops and that's > 200km/h. old legacy owners have proven that it can go to 260km/h before, so I am quite sure FA20DIT will do the same too. LEDs are high heat devices... u sure u wanna trust a no reputation US$8 unit near the engine bay? sometimes there's a reason why bulbs like Philips, PIAA cost so much, cos' there is $ spent in R&D to ensure they don't burn up in the car and destroy something else or the whole car. have experienced cheapo pole LED die very fast in my car due to heat besides a HID reflector unit, but changed to Philips and lasted over 3yr now still no issue. Me too. Bought cheap LEDs with heat sink some more for my ex car to use as license plate lights. It blew in about 3 weeks. The heat dissipation is comparable to halogen. I thought LEDs are supposed to be cooler? Link to post Share on other sites More sharing options...
Tohto Hypersonic March 19, 2017 Share March 19, 2017 Me too. Bought cheap LEDs with heat sink some more for my ex car to use as license plate lights. It blew in about 3 weeks. The heat dissipation is comparable to halogen. I thought LEDs are supposed to be cooler? You already mention the reason, cheap. 1 Link to post Share on other sites More sharing options...
Bluemice 2nd Gear March 19, 2017 Share March 19, 2017 I thought LEDs are supposed to be cooler? Hi, the heat dissipation for halogen is forward, towards the light direction. while for LED is towards the rear (i.e. housing side) which explains for the heat sinks. So for a poorly designed LED bulb, its the housing that starts to melt first, something unheard of in halogens. 1 Link to post Share on other sites More sharing options...
Ghui Neutral Newbie March 19, 2017 Share March 19, 2017 Collected my ride last week. Just found out that I am unable to wind down the window for the front passenger window from my driver side. But the control over at front passenger side is able to. Gonna send it in tmr.. anybody experienced it ? Link to post Share on other sites More sharing options...
leehock13828 2nd Gear March 19, 2017 Share March 19, 2017 But car already buy from them. If they increase servicing price too much, i may just have to let go the warranty. Made in japan suppose to be reliable right? Ha ha... this is stupid. Anyway see increase how much firstIn the old days, made in Japan is reliable. Nowadays this statement makes me think twice Link to post Share on other sites More sharing options...
therock Supersonic March 19, 2017 Share March 19, 2017 In the old days, made in Japan is reliable. Nowadays this statement makes me think twice Mr Lee I notice that you have been all over the forum, dissing one car after another, giving less than cheerful replies to your fellow newbie.. What gives bro? Just curious to know.. 1 Link to post Share on other sites More sharing options...
Hoseyboh Twincharged March 19, 2017 Share March 19, 2017 Collected my ride last week. Just found out that I am unable to wind down the window for the front passenger window from my driver side. But the control over at front passenger side is able to. Gonna send it in tmr.. anybody experienced it ? Bro, I think they forgot to preset the power window for you. 5 mins job. Cheers Link to post Share on other sites More sharing options...
Tianmo Hypersonic March 19, 2017 Share March 19, 2017 In the old days, made in Japan is reliable. Nowadays this statement makes me think twice Welcome back!!!. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
