DACH Supersonic September 17, 2018 Share September 17, 2018 @RadX Issue Russian passport ↡ Advertisement 1 Link to post Share on other sites More sharing options...
RCTP 6th Gear September 17, 2018 Share September 17, 2018 “Dasvidaniya” “That means goodbye” ~Transformers 1 Link to post Share on other sites More sharing options...
Salnts 2nd Gear September 18, 2018 Share September 18, 2018 Yup, I had sticked it to the car door frame. Door can close with no issue. Wind noise is reduced. Now at 100km/h very little wind noise. I go for I design type which is 2mm thick. The H and D design I never buy coz they are thicker, scared stick that door cannot close properly. sketch-1536938581761.png wait... you peel off the original black seals? 1 Link to post Share on other sites More sharing options...
Yewheng Twincharged September 18, 2018 Share September 18, 2018 (edited) wait... you peel off the original black seals?Nope. Mine honda shuttle door frame no seal. Only the car chassis there for the door to close go seal. So I stick that rubber strip to door frame for better seal. Edited September 18, 2018 by Yewheng Link to post Share on other sites More sharing options...
Ivan_06 5th Gear September 18, 2018 Share September 18, 2018 Nope. Mine honda shuttle door frame no seal. Only the car chassis there for the door to close go seal. So I stick that rubber strip to door frame for better seal.Wah how come so jialat one. Link to post Share on other sites More sharing options...
Yewheng Twincharged September 18, 2018 Share September 18, 2018 (edited) Wah how come so jialat one. Don't know stock honda shuttle door no seal. Of coz the chassis side got seal. So still okay. I find that outside still got noise and wind sound when travel at 100km/h. So I decide to DIY stick the rubber seal to the door side lor. Edited September 18, 2018 by Yewheng Link to post Share on other sites More sharing options...
Jci1035 Neutral Newbie September 21, 2018 Share September 21, 2018 hi everyone i wanted to ask, did your face suspension too soft? 1 Link to post Share on other sites More sharing options...
Tkseah Turbocharged September 21, 2018 Share September 21, 2018 hi everyone i wanted to ask, did your face suspension too soft?Yup, especially the rear suspension 1 Link to post Share on other sites More sharing options...
StrikeX 1st Gear September 21, 2018 Share September 21, 2018 That what's claim to be. However as others have pointed out in the forum, it will void the C&C's warranty.Is it hard to install?This one https://www.google.com.sg/search?q=nitro+obd2&oq=nitro+obd&aqs=chrome.1.69i57j0l3.4700j0j7&client=ms-android-xiaomi&sourceid=chrome-mobile&ie=UTF-8 Nitro obd2 claim can save fuel by just plugging in to thr obd port. Really will help so easily? Hi, Has anyone tried fuel catalyst like Broquet on the Attrage? Can share your experience? Thanks Whata that bro? Care to share? 2 Link to post Share on other sites More sharing options...
auto1701 2nd Gear September 21, 2018 Share September 21, 2018 Hi guys. I did some research and it seems the keyless entry system does not include an alarm. Is it possible to install an alarm ? If can, since there is no key slot, how do you disable the alarm without the remote ? For older cars, we just turn on the ignition and then press the disable button. Thanks in advance! 2 Link to post Share on other sites More sharing options...
auto1701 2nd Gear September 22, 2018 Share September 22, 2018 hi everyone i wanted to ask, did your face suspension too soft? I like it when the suspension is soft as I always drive through humps without stopping. Also, the ride is much more comfortable. However, if you tend to drive and corner hard at high speed, there will be alot of roll. Hence whether you feel the suspension is hard or soft depends on your driving style. Link to post Share on other sites More sharing options...
Icecube7 1st Gear September 23, 2018 Share September 23, 2018 Yup, especially the rear suspensionIf suspension issue.. Put spring buffers.. If handling issue.. Put strut bar and anti roll bars. Definate improvement 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear September 23, 2018 Share September 23, 2018 If suspension issue.. Put spring buffers.. If handling issue.. Put strut bar and anti roll bars. Definate improvement That's not solving the root cause . Link to post Share on other sites More sharing options...
Icecube7 1st Gear September 23, 2018 Share September 23, 2018 That's not solving the root cause .What would you suggest? 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear September 23, 2018 Share September 23, 2018 What would you suggest?Go back cnc 3 Link to post Share on other sites More sharing options...
Icecube7 1st Gear September 23, 2018 Share September 23, 2018 Go back cncDo u own an attrage or driven one? 1 Link to post Share on other sites More sharing options...
auto1701 2nd Gear September 23, 2018 Share September 23, 2018 How soft or hard a suspension is depends on the spring ad shock absorbers. Hence it is part of the design. If you need a harder ride, then the option is to replace the spring or absorbers with an after market one that is harder. And maybe you need an anti-rolling bar too. Cornering would be better but then your side will not be as comfortable. But that would probably defeat the purpose of getting a cheap, family oriented car. The Attrage is not meant to be driven hard, I think. 2 Link to post Share on other sites More sharing options...
DicksonLeeWangLong 1st Gear September 23, 2018 Share September 23, 2018 Guys I just replaced my break pad.. Cost around 179 done it in cnc.. So ex lol. Should had just do it outside.. But the funny thing is 20k only already ran out.. I asked them they say its normal.. So far have you guys change the breakpad? And how long does your break pad last? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Recommendations for car respraying/fixing of minor scratches and dents
Mitsubishi Outlander
2020 Mitsubishi Attrage (Part 2)
Mitsubishi to suspend sales in Singapore as revised emissions scheme set to downgrade some new cars
2018 Mitsubishi Eclipse Cross
