Qtm550 Neutral Newbie March 11, 2021 Share March 11, 2021 hi , i started to notice fuel smell inside my car whenever i start my engine and this happened recently. After driving for 1 min , the fuel smell goes away. My ride is less than 1 year old. Any idea what could be cause ? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic March 11, 2021 Share March 11, 2021 55 minutes ago, Qtm550 said: hi , i started to notice fuel smell inside my car whenever i start my engine and this happened recently. After driving for 1 min , the fuel smell goes away. My ride is less than 1 year old. Any idea what could be cause ? Thanks. Better send in & check ASAP..don't delay. Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 11, 2021 Share March 11, 2021 1 hour ago, Qtm550 said: hi , i started to notice fuel smell inside my car whenever i start my engine and this happened recently. After driving for 1 min , the fuel smell goes away. My ride is less than 1 year old. Any idea what could be cause ? Thanks. The smell might still be there but you do not feel it because you have gotten use to the smell after 1 min. Dont try to use lighter or smoke in your car until you have it checked. One of the many possibilities could be a leak around the fuel pump assembly, likely under the passenger seat but i could be wrong. Link to post Share on other sites More sharing options...
Chimy Neutral Newbie May 24, 2021 Share May 24, 2021 Hi, any recommendation where to fix right rear door cannot open from inside and outside. Thanks. Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 3, 2021 Share June 3, 2021 5 hours ago, MarosSVK said: Passat B8 is such a cool car. When DSG fail,it is not ''Cool'' anymore.🤬 Link to post Share on other sites More sharing options...
Acromage Neutral Newbie June 4, 2021 Share June 4, 2021 Been driving a B8 since 2018 and love the drive and power. HP per dollar this is one of the best in the market. Regarding DSG I get the concern, and I'm equally concerned about this, but as a 3yo owner, I feel some gearbox vibrations on the tail end of servicing cycle, but otherwise this should be a non issue so long as you adhere to maintenance cycles. Take note that VW maintenance cycles are 15k instead of japanese cars @ 7k. My only concern is the battery runout. Do take note that Passat battery is mounted at the front, and heat exposure can severely shorten the battery lifespan. Have changed my battery twice in 3 years of ownership. That is the only black mark (other than a small unhappiness in paint quality) that I have of the car. For those considering, do a test drive and you'll know what I mean. Link to post Share on other sites More sharing options...
cth_ Clutched June 4, 2021 Share June 4, 2021 Hi all, I would like to know if anyone has done up solar tinting for their B8 Passat and the estimated cost for doing all of the windows with heat rejection film. Thanks! Link to post Share on other sites More sharing options...
Matoonia 6th Gear June 4, 2021 Share June 4, 2021 4 hours ago, cth_ said: Hi all, I would like to know if anyone has done up solar tinting for their B8 Passat and the estimated cost for doing all of the windows with heat rejection film. Thanks! I recently did my sunroof with DS Specialty. Can see my review here https://www.sgcarmart.com/directory/merchant.php?MID=10320 1 Link to post Share on other sites More sharing options...
Matoonia 6th Gear June 4, 2021 Share June 4, 2021 I'm driving CC R line. I've read that can do VAGCOM programming for easy entry for the car seat. I.e when open driver car door, seat goes back. When ignition on, seat moves forward to your preset memory. Anyone knows who is able to do this? Link to post Share on other sites More sharing options...
cth_ Clutched June 6, 2021 Share June 6, 2021 Hi again, recently tried to open the bonnet of my car but found out that the gas strut was faulty as such the bonnet would not stand up. If I bring it back to VW, can I claim it under warranty? Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged June 6, 2021 Share June 6, 2021 8 hours ago, cth_ said: Hi again, recently tried to open the bonnet of my car but found out that the gas strut was faulty as such the bonnet would not stand up. If I bring it back to VW, can I claim it under warranty? Should be wear and tear item.. Chance is rare to claim unless you car is relatively new. Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 6, 2021 Share June 6, 2021 How many times you Open/Close your Bonnet in a Month.?So fast the Gas Strut wear out.? Link to post Share on other sites More sharing options...
cth_ Clutched June 7, 2021 Share June 7, 2021 @ER-3682 Haven't opened the bonnet in months, was washing the car and decided to open it but found out the strut wasn't working. Not sure what caused it. Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 7, 2021 Share June 7, 2021 I feel it should be replaced FOC. Don't seems like a wear and tear item to me. Do keep us updated if you may. 1 Link to post Share on other sites More sharing options...
cth_ Clutched June 26, 2021 Share June 26, 2021 Hi all, just to update, went for servicing yesterday at VCS and they replaced the strut for free as it is under warranty. 3 Link to post Share on other sites More sharing options...
Yang_man Neutral Newbie June 28, 2021 Share June 28, 2021 @cth_ Don't think this is covered by warranty, of course you can make enough noise for them to replace it "out of goodwill" Failing which, you can always go and buy one from AliExpress which will definitely be must cheaper that VW Distributor price. Just make sure you have the same model for your Passat B7 /B8 etc 1 Link to post Share on other sites More sharing options...
Yang_man Neutral Newbie June 28, 2021 Share June 28, 2021 @cth_ good to know, I had similar problem with my previous Passat and was told that it was not covered. Anyway, if the part if too expensive, you can also go Taobao or Aliexpress, plenty of passat in China 1 Link to post Share on other sites More sharing options...
SyedMohamedAlkaff Neutral Newbie July 5, 2021 Share July 5, 2021 hey guys! noob question - just wanna confirm that this is a passat b8 and not b7 right? thanks in advance! ↡ Advertisement Link to post Share on other sites More sharing options...
Xpeng is Coming to Town
2022 Volkswagen ID. Buzz
Volkswagen Sharan..
Volkswagen Sharan..
2022 Toyota GR Corolla
2021 8th Generation VW Golf
🚗 Sgcarmart: MCF HangOut x Volkswagen – 24 August 2024, Volkswagen Boutique 🚙
