Lala81 Hypersonic October 28, 2016 Share October 28, 2016 Try one and you'll know the difference. With manual brushing, your hands will get tired brushing up and down for all your teeth. With electric, you just guide the brush, and you can do 2 min (recommended) brushing easily. More important is to brush your teeth and your gums softly with a toothbrush with the soft bristles. I thought dental care in Singapore is blardy expensive, 3 out of 10 elderly can't afford it. actually i think many people just don't take care of their teeth. I see so many people with bad teeth everyday. Before i did this line of work, i used to think only my parent's generation will have bad teeth... ↡ Advertisement Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 28, 2016 Share October 28, 2016 BEFORE or AFTER the BJ poor @sp4wn can get stuck between teeth....kekekekeke hmmmm toothpick he become 1 1 Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 28, 2016 Share October 28, 2016 More important is to brush your teeth and your gums softly with a toothbrush with the soft bristles. actually i think many people just don't take care of their teeth. I see so many people with bad teeth everyday. Before i did this line of work, i used to think only my parent's generation will have bad teeth... because dental charge is not cheap ..... 1 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 28, 2016 Share October 28, 2016 I thought dental care in Singapore is blardy expensive, 3 out of 10 elderly can't afford it.Yes implant one tooth can cost up to $4k Imagine whole teeth need implant, at least need $30-40k More important is to brush your teeth and your gums softly with a toothbrush with the soft bristles. actually i think many people just don't take care of their teeth. I see so many people with bad teeth everyday. Before i did this line of work, i used to think only my parent's generation will have bad teeth... I do ok every year go cleaning. Yah last time my doc also said that to me, when u brush teeth, don't forget to massage the gum so allow better blood flow 1 Link to post Share on other sites More sharing options...
Celicar Turbocharged October 28, 2016 Share October 28, 2016 More important is to brush your teeth and your gums softly with a toothbrush with the soft bristles. actually i think many people just don't take care of their teeth. I see so many people with bad teeth everyday. Before i did this line of work, i used to think only my parent's generation will have bad teeth... Most important is to be a good person, if despicable then will have no teeth, because 卑鄙 ——> 无齿 2 Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 28, 2016 Share October 28, 2016 Most important is to be a good person, if despicable then will have no teeth, because 卑鄙 ——> 无齿 3 Link to post Share on other sites More sharing options...
Sosaria Twincharged October 28, 2016 Share October 28, 2016 In the past dentists never advise us to use soft bristle toothbrush to brush near the gum-line and avoid damaging the gums. This seems to be the standard advice these days. Then i wonder the medium and hard bristle brush is for what nowadays?? Soft bristle brush does not remove trapped food particles or plaque so thoroughly so must always follow by flossing. 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 28, 2016 Share October 28, 2016 hard bristles brush softer, soft bristles brush harder can anot? of cos if can test then find the proper ones would be best. Try one and you'll know the difference. With manual brushing, your hands will get tired brushing up and down for all your teeth. With electric, you just guide the brush, and you can do 2 min (recommended) brushing easily. ok la bro.. 2mins wouldn't cause tiredness in hand / wrist; no need brush super hard. i change to left hand nowadays as certain angle on one side of teeth feels more natural for wrist movement when brushing up n down.. also use opportunity to train left hand to be more adept at brushing teeth.. 1 Link to post Share on other sites More sharing options...
Neutrino Supercharged October 28, 2016 Share October 28, 2016 And floss regularly. In UK they've recently stated that flossing does no use whatsoever. I use a Power Flosser myself http://www.philips.co.uk/c-m-pe/philips-sonicare-airfloss/dental-flosser It amazes me how much food it removes from the spaces between my teeth even when I've used interdental brushes similar to I wish this sort of thing had been available when I was young. I'd still have a full set of teeth. Link to post Share on other sites More sharing options...
Leinad8919 Turbocharged October 28, 2016 Share October 28, 2016 because dental charge is not cheap ..... This is one dentist we don't mind going 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic October 29, 2016 Share October 29, 2016 ppl gargle youi drink......now we know why you sumtingwong sometime back i read somewhere that listerine got alcohol content...... not sure now. ↡ Advertisement Link to post Share on other sites More sharing options...
If only our CASE and CCCS is so on the ball. . .
16 yr old detained by ISA for planning attacks
SG's 1st confirmed case of Monkeypox
Corruption Case at CPIB PArt 2
Top Gear Satire
Top Gear Satire
Chris Rock made fun of Will Smith's wife and was smacked by Will Smith on Oscar stage
A Joke A Day Keeps The Doctor Away
VOLTSwagen?
VOLTSwagen?
