Shawrac Neutral Newbie July 8, 2018 Share July 8, 2018 Can Anyone VW car owners, advise if u had such experience code? The code came out but it goes away after some distance. But this had been coming back a few time already. As no error code when I drive to workshop. They can’t check for me!!! Don’t feel comfortable. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Sdf4786k Twincharged July 8, 2018 Share July 8, 2018 Can Anyone VW car owners, advise if u had such experience code? The code came out but it goes away after some distance. But this had been coming back a few time already. As no error code when I drive to workshop. They can’t check for me!!! Don’t feel comfortable. Thanks select the car pic.. the error should be there till you switch off the car Link to post Share on other sites More sharing options...
Watwheels Supersonic July 9, 2018 Share July 9, 2018 Don't the mechanics check for cracked vacuum hose when some intermittent "brake servo failure" code occurs? Link to post Share on other sites More sharing options...
Shawrac Neutral Newbie July 9, 2018 Author Share July 9, 2018 Cracked vacuum hose. Wow. This sound bad!! Will look into it Don't want to be in bad shape then found the problem Link to post Share on other sites More sharing options...
Beregond Supersonic July 9, 2018 Share July 9, 2018 Can Anyone VW car owners, advise if u had such experience code? The code came out but it goes away after some distance. But this had been coming back a few time already. As no error code when I drive to workshop. They can’t check for me!!! Don’t feel comfortable. Thanks check if your car brake fluid low or not. if low just top up and monitor a while first before doing any major stuff Link to post Share on other sites More sharing options...
Shawrac Neutral Newbie July 9, 2018 Author Share July 9, 2018 check if your car brake fluid low or not. if low just top up and monitor a while first before doing any major stuffGood advise. Something that I had outlook Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 9, 2018 Share July 9, 2018 I thought mechanic is able to dump out error code from OBD? Link to post Share on other sites More sharing options...
Keithchue 5th Gear July 10, 2018 Share July 10, 2018 all codes are stored in the ODB, just need a scanner for reading them out. all pro VAG cars are built this way Link to post Share on other sites More sharing options...
Shawrac Neutral Newbie July 10, 2018 Author Share July 10, 2018 all codes are stored in the ODB, just need a scanner for reading them out. all pro VAG cars are built this way Thanks for the advice! I thought mechanic is able to dump out error code from OBD? Cos when I went down, the error code is gone after travelling a while But it comes on & off. So when I am at the workshop, don't see the error code so cant track! Link to post Share on other sites More sharing options...
Shawrac Neutral Newbie July 13, 2018 Author Share July 13, 2018 Seem like it is good that not much VW owner got this issues. Cos till date seem like no one have gotten this issues before. Cos no actual case reply. Hahahaha Link to post Share on other sites More sharing options...
takeiteasy_ Clutched July 24, 2018 Share July 24, 2018 had been in this situation before with a scirocco, send to w/s and check and was a faulty wire connecting to ABS that causes these fault code. change the wire for $120 and no more error. Link to post Share on other sites More sharing options...
Gavin0202 Neutral Newbie January 15, 2020 Share January 15, 2020 Hi I have brake servo failure for months and same as all it comes and goes. So have went to have a check at Servo Autowerkz. As usual they use OBD to detect the errors and found out that it is the vacuum pipe sensor. Cost below $250 including labour. :) hope it helps to all VW owners. Link to post Share on other sites More sharing options...
Cyfer33 Neutral Newbie August 17, 2020 Share August 17, 2020 On 1/15/2020 at 4:03 PM, Gavin0202 said: Hi I have brake servo failure for months and same as all it comes and goes. So have went to have a check at Servo Autowerkz. As usual they use OBD to detect the errors and found out that it is the vacuum pipe sensor. Cost below $250 including labour. 🙂 hope it helps to all VW owners. Just wonderimg, problem solved after changing the vacuum sensor? Link to post Share on other sites More sharing options...
Kriipso Neutral Newbie April 20, 2021 Share April 20, 2021 I have a passat b7 1.4 twincharger and I have the exact same problem. Engine light comes on, brake servo failure. It comes on and off. When it says brake servo failure, the engine does not work properly and gearbox doesn't change properly. When the problem dissappears, everything works fine. I have changed the vacuum pipe sensor, but the problem is still there. At the workshop they can't see any fault codes when the car works fine. Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 16, 2022 Share March 16, 2022 1 hour ago, vwradiocodess said: We are specialists in decoding radio’s and have decoded many radios and navigation systems in the past. We give a 100 percent satisfaction guarantee. Can you help break this radio code? My fren in Ukraine, let's just call him Z is asking. We want to hear what is being said and where the general talking is hiding. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Code of conduct for pedestrians
My quest for finding the perfect MPV for my family
Renal failure on the rise
Brake squeak every morning
