Dehumidifier recommendations
Stratovarius
6 hours ago, BabyBlade said:
I've been using a local brand LifePro DH12 for a few months now. Got it from Shopee for around SGD150+ after discounts. Lowest I've seen it priced was $130+. The more powerful one is the DH24 which is priced around SGD300+. But I'm pleased with the one I have so far. May consider upgrading to the bigger one if there's a need for it. Easy to use, easy to wheel around, not too noisy, cool down the air a fair bit also. I turn it on before work and set it to RH 40 or 45 and by the time I get home in the evening, just nice collect about full tank and room is cool, almost like the aircon is switched on. Only use it in the day since using aircon at night.
https://shopee.sg/【English-Panel】LifePro-DH12-12L-Day-Dehumidifier-with-Compressor-Up-to-12-month-SG-Warranty-3-pin-SG-Plug-i.10233884.9902588023
1336833094_62c6e4b8440e51e76b1b95b437e02da5(1).thumb.jpg.0c2f3a2dad7071a3115e14c97fc64f14.jpg
I also considered the Deerma Dehumidifier before deciding on LifePro since they are priced around the same. Just gotta make sure yours is from a local seller with the three pin plug and English menu. Why I decided on LifePro, reviews pretty even so local brand it shall be.
Great. Ya I have this in my Lazada app. Might give this a try. Hopefully can last.
2 hours ago, Volvobrick said:
Then got to solve the root cause and seal up the vents. No point trying to dry the entire neighbourhood.
Sealing will make it worse. I got one side sealed though. Rh in the air will be the same regardless of air flow. Some air flow might be good to prevent molds as air in storeroom is usually quite still and mold will start to build up.
Internal Moderator
7 hours ago, Jamesc said:
Almost full tank?
They should put a filter in the water tank so can drink the water.
Singapore is so short of water we don't have to buy so much water from Msia and stop all their complaining.
:D
That's what I told my mum actually. Next time Malaysia cut off our water supply we will have to drink water from our dehumidifier. 😆
  • Haha! 5
Internal Moderator
7 hours ago, Evo5sg said:
Not sure if possible.
mine has bubbles in the water. Wife said may be bacteria inside.
No bubbles for mine. Looks very clear and clean.
Water taken from the air is the cleanest water.
Can even use as battery water if don't dare to drink.
:D
If no need battery water put in the radiator.
The radiator won't rust.
Internal Moderator
5 hours ago, badlammy said:
I wanted to get Novita too cuz mold building up on my blockout curtain but wife said $499 so ex.
She said better for me to wipe it on weekly basis 🙃
Should definitely get a dehumidifier to prevent mold from growing. It's hard to get rid of mold spores and it'll just keep coming back. Don't have to get a high end one. There are those lesser than 200 that I feel does a pretty good job too. Investing on a is one of my best purchase for 2021. I got it because of a booklice/mold issue that I had.
  • Praise 4
Supersonic
Take note that the Dehumidifier also consumes quite some amount of power. Novita specs show approx 740W. Which is the same as an split unit 9000btu on low/mid power setting. Might as well switch on the Aircon in this case.
  • Praise 4
  • Haha! 2
My dehumidifier don’t run all the time even though it is in a bed room.
It starts running when humidity exceed 60%.
It stops running when humidity hit 50%.
I have a Tanita Hygrometer to cross check
Edited by inlinesix
@Watwheels
17 hours ago, Watwheels said:
I remember seeing it in different lengths. DEHUMIDIFIER ROD. You may install one or two depending on the size of your storeroom. It is cheap.
https://www.horme.com.sg/product.aspx?id=1580
I bought a long one for my store room but it did nothing about the dampness and mold smell. A store room with porous plaster walls/ceiling is too big to be adequately heated by such rods. Those rods works best inside a small wardrobe. The best solution is to get a dehumidifier (using thermoelectric) that can remove about 1 liter of water every few days. consumes negligible electricity. Easy to service one, usually just requires a replacement of the fan inside if spoilt.
Edited by Joe_X123
  • Praise 2
18 hours ago, Stratovarius said:
I'm looking to install a dehumidifier in my storeroom. Anyone doing the same? if so what brand and model is good? My budget is less than 200 bucks so no Novita please. TIA.
I buy this
Think less than $60 with doorstep delivery.
  • Praise 4
:D
Water from one of these dehumidifier condenses on aluminum cooling blocks. I think the distilled water collected would have too much metal in it for human consumption. So best avoided. We all know what aluminum can do to our brains.
Edited by Joe_X123
  • Praise 2
6 hours ago, Stratovarius said:
oh, where u bought it from?
I bought directly from taobao, in fact I bought 3.
Other local platforms also sell but most of them are just taobao resellers so prices are marked up quite a bit.
  • Praise 3
Internal Moderator
For this one I read the reviews that the RH value is not accurate and cannot go below a certain level. Any problem for yours @Windwaver?
Internal Moderator
The Yangzi dehumidifier is available on Shopee as well for less than SGD60 but there are quite a few reviews saying it doesn't do much to lower humidity and can only bring RH down to about 60+ though on paper it says you can set it to lower. Do read a lot of reviews before deciding on one. If your budget is 200, I think you can afford to go for a more reliable one which can bring the RH down to 30, 40, 50 range.
Too bad they stop making this.
Best for small office, gift for new homes, family use. Hyflux - The exclusive Aquovator, also known as dragon-fly, is an effective stand alone water generator that provides membrane filtered, ultraviolet (UV) purified, treated ambient water without the inconvenience of buying water refills, storing used and unused bottled water bottles and troublesome piping.
Convenient and portable, dragon-fly lets you enjoy freshly aquovated water at just the push of a button. It is also economical and easy to maintain as it requires no external piping, water refills and bottle storage.
The machine simply takes its source from the atmosphere, generating clean and natural water everyday. A recirculation process keeps aquovated water constantly fresh while in storage, cutting out the potential risk of bacterial build up which may arise in bottled water.
  • Haha! 2
Internal Moderator
When I just saw the first photo, I tot is a nesspresso coffee machine leh. Then I wondering why @Jamesc wanna do with a coffee machine for a dehumidifier.
Then when I read finish the post, haha. a legit dehumidifier. hahahahahha.
  • Haha! 1
