Jman888 Moderator November 27, 2024 Share November 27, 2024 On 11/27/2024 at 11:19 AM, Tianmo said: After doing some research, went for the LifePro DH50, supposedly the biggest in the line up for home use (cover up to 130m2) . Specifically can draw 50L or 30L of water a day(24 hrs) with a 8L tank. Come with H11 HEPA filter as an air purifier, can produce negative ions, and can dry clothes. dun on for too long later you become 干尸 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 27, 2024 Share November 27, 2024 On 11/27/2024 at 11:27 AM, Jman888 said: dun on for too long later you become 干尸 I set to 45%, sld be not so 干. 2 Link to post Share on other sites More sharing options...
Genes 6th Gear November 27, 2024 Share November 27, 2024 On 11/27/2024 at 11:26 AM, Tianmo said: Yah bought a cheap 1L capacity one last week, waste time, which is what tiggered me to look for an actual one. So bought a DH50 from LifePro, and tested last night. On for 3 hrs, and collected 5L of water, but only managed to take humidity from 85% to 66%. I think this is because I left it in the living hall with all the room doors opened. Very good effect all things considered. 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 29, 2024 Share November 29, 2024 After playing with it for a few days, finally understand how to use it probably. This morning WFH, so let it run, collected one full tank in 5 hrs, and my tank is a big 8L tank. This is with the H11 filter installed, I think if I remove the H11, flow rate will be even faster. After that move it to individual rooms, and took only one hr to bring RH down to 50% in the rooms. 2 Link to post Share on other sites More sharing options...
Tohto Hypersonic November 29, 2024 Share November 29, 2024 On 11/29/2024 at 2:32 PM, Tianmo said: After playing with it for a few days, finally understand how to use it probably. This morning WFH, so let it run, collected one full tank in 5 hrs, and my tank is a big 8L tank. This is with the H11 filter installed, I think if I remove the H11, flow rate will be even faster. After that move it to individual rooms, and took only one hr to bring RH down to 50% in the rooms. Water can be used for watering plants, mop floors.. that's what I do. 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 29, 2024 Share November 29, 2024 On 11/29/2024 at 2:45 PM, Tohto said: Water can be used for watering plants, mop floors.. that's what I do. Going to do it later when my antibacterial filters come, then can use the filtered water to do some stuffs. Meanwhile, I just pour it away first. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 29, 2024 Share November 29, 2024 On 11/29/2024 at 2:50 PM, Tianmo said: Going to do it later when my antibacterial filters come, then can use the filtered water to do some stuffs. Meanwhile, I just pour it away first. I use it for toilet after pang jio 2 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 29, 2024 Share November 29, 2024 On 11/29/2024 at 3:49 PM, inlinesix said: I use it for toilet after pang jio I am going to remove the tank and attach the pipe to my 25L pail later, and let it run until tomorrow morning. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 2, 2024 Share December 2, 2024 On 11/29/2024 at 3:49 PM, inlinesix said: I use it for toilet after pang jio Same. hahahaha. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 2, 2024 Share December 2, 2024 I am using the china brand deye for humidifier. Apparently, i think Novita also use their dehumidifier and rebadge it. The shape and the spec are the same. being with me for 4 years liao. Still work like a beast. 2 Link to post Share on other sites More sharing options...
Tianmo Hypersonic December 2, 2024 Share December 2, 2024 So, what is the constant RH you guys with dehumidifiers are getting? Like, SG's RH is constantly between 82-85 almost year round, what are you guys getting? Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 2, 2024 Share December 2, 2024 On 12/2/2024 at 10:55 PM, Tianmo said: So, what is the constant RH you guys with dehumidifiers are getting? Like, SG's RH is constantly between 82-85 almost year round, what are you guys getting? Tanita thermometer shows btw 65% and 75%. This is sitting in my living room 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 2, 2024 Share December 2, 2024 Wah the dehumidifier power consumption is not small, 600w. Close to a 9k btu at nominal. Link to post Share on other sites More sharing options...
Tianmo Hypersonic December 3, 2024 Share December 3, 2024 On 12/2/2024 at 10:59 PM, inlinesix said: Tanita thermometer shows btw 65% and 75%. This is sitting in my living room So it looks like 70% is quite normal in our conditions. In my living room, it's now about 67-68% in the days and 70-72% in the early early mornings Some rooms stay about 68-70%, some rooms stay ard 70-72%. All except one read above 85% when I first took their readings with the few cheap hydrometers (bought 6, one in each room), the MR read 90%. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Aircon oil renewal necessary?
Home Aircon
Home Aircon
Car air-con
Car air-con
