Kklim Supercharged February 25, 2022 Share February 25, 2022 Been having this intermittent problem with my 12-year-old Sylphy: Gearbox seems to take a longer time to engage when moving off in D mode. Happens only at start of journey after the car has been parked for a while; don't have this problem when moving off at traffic lights in the middle of a journey. Sometimes have to get around it by putting tranny in 2 or 1 mode and then shifting to D. Reverse mode is ok. ATF and filter were changed almost two years ago. What could be causing this? Thanks for any help. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic February 25, 2022 Share February 25, 2022 (edited) 9 minutes ago, Kklim said: Been having this intermittent problem with my 12-year-old Sylphy: Gearbox seems to take a longer time to engage when moving off in D mode. Happens only at start of journey after the car has been parked for a while; don't have this problem when moving off at traffic lights in the middle of a journey. Sometimes have to get around it by putting tranny in 2 or 1 mode and then shifting to D. Reverse mode is ok. ATF and filter were changed almost two years ago. What could be causing this? Thanks for any help. what is the mileage? Order of checking. seems to point to 1st point as it happens only when cold. ATF expands quite a bit when warmed up. 1. check fluid level 2. try to change ATF again 3. overhaul gearbox looks like the solenoids or seals in the valve body. https://www.sundevilauto.com/what-causes-delayed-engagement-in-transmission/ Edited February 25, 2022 by Mkl22 Link to post Share on other sites More sharing options...
Kklim Supercharged February 25, 2022 Author Share February 25, 2022 (edited) Mileage is under 180K km. ATF volume within range. Will check again. Edited February 25, 2022 by Kklim Link to post Share on other sites More sharing options...
Watwheels Supersonic February 25, 2022 Share February 25, 2022 Likely to be the fluid pump that is faulty in the torque converter. FYI cvt gearbox also uses a torque converter. Link to post Share on other sites More sharing options...
Ct3833 Supersonic February 25, 2022 Share February 25, 2022 (edited) there is a possiblity that the trans needs a service, about 2k to 3k, downtime 3 days . go get a transmission specialist shop for assessment, they would be able to tell . Otherwise, this problem may get more and more severe, till the car will not change gear at times till completely unable to drive. Edited February 25, 2022 by Ct3833 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged February 25, 2022 Share February 25, 2022 1 hour ago, Kklim said: Been having this intermittent problem with my 12-year-old Sylphy: Gearbox seems to take a longer time to engage when moving off in D mode. Happens only at start of journey after the car has been parked for a while; don't have this problem when moving off at traffic lights in the middle of a journey. Sometimes have to get around it by putting tranny in 2 or 1 mode and then shifting to D. Reverse mode is ok. ATF and filter were changed almost two years ago. What could be causing this? Thanks for any help. @KklimIs there any abnormal sound from the engine bay? Sort of like a mechanical grinding noise? Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator February 25, 2022 Share February 25, 2022 1 hour ago, Kklim said: Been having this intermittent problem with my 12-year-old Sylphy: Gearbox seems to take a longer time to engage when moving off in D mode. Happens only at start of journey after the car has been parked for a while; don't have this problem when moving off at traffic lights in the middle of a journey. Sometimes have to get around it by putting tranny in 2 or 1 mode and then shifting to D. Reverse mode is ok. ATF and filter were changed almost two years ago. What could be causing this? Thanks for any help. 2 year is a long time. 🙂 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic February 25, 2022 Share February 25, 2022 Jatco gearbox..near end of its life. 2 Link to post Share on other sites More sharing options...
Kklim Supercharged February 25, 2022 Author Share February 25, 2022 2 hours ago, Watwheels said: Likely to be the fluid pump that is faulty in the torque converter. FYI cvt gearbox also uses a torque converter. Mine is auto, not CVT. Link to post Share on other sites More sharing options...
Kklim Supercharged February 25, 2022 Author Share February 25, 2022 1 hour ago, DOBIEMKZ said: @KklimIs there any abnormal sound from the engine bay? Sort of like a mechanical grinding noise? Engine has been louder since top overhead (top gasket blew) 2 years ago. 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged February 25, 2022 Share February 25, 2022 10 minutes ago, Kklim said: Engine has been louder since top overhead (top gasket blew) 2 years ago. @KklimIf not abnormal (kind of grinding/rattling) sound, then hopefully the cvt transmission should still be alright, and most likely some kind of connecter to activate the mode worn. Because my 13 yrs Nissan Latio on cvt some months ago last year its gearbox spoilt and I so I de-registered the car. Initially I heard that afore-mentioned grinding noise from the engine bay area that got sound the faster I drove. Even in N mode the sound was audible but low. Car was serviced on schedule. After a few months the sound became too intrusive and unbearable. Bought the car to workshop for diagnosis and it pin-pointed that it was the cvt gearbox and that the bearings were probable broken. Replacement set (re-conditioned unit from Japan) would cost between $2500 to $3500 estd. Ultimately decided to scrap the veh. Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged February 25, 2022 Share February 25, 2022 24 minutes ago, Kklim said: Mine is auto, not CVT. If yours is Auto AT then quite robust, probably won't be the reason I posted earlier. Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged February 25, 2022 Share February 25, 2022 5 minutes ago, mikk123 said: sylphy made in Thailand right? reaching life limit already. Made in Japan worth renewing COE. I think his Sylphy was a made in Japan. Link to post Share on other sites More sharing options...
Kklim Supercharged February 25, 2022 Author Share February 25, 2022 21 minutes ago, mikk123 said: sylphy made in Thailand right? reaching life limit already. Made in Japan worth renewing COE. Mine from Japan. Newer ones from Thailand Link to post Share on other sites More sharing options...
ER-3682 Supersonic February 25, 2022 Share February 25, 2022 1 hour ago, Kklim said: Mine is auto, not CVT. Still made by JATCO..1 of the poorly made Gearbox..you got 180,000Km already very good..just spend on a Recon Unit from Japan.. 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic February 25, 2022 Share February 25, 2022 6 minutes ago, ER-3682 said: Still made by JATCO..1 of the poorly made Gearbox..you got 180,000Km already very good..just spend on a Recon Unit from Japan.. Yeah have to admit jatco is the crappiest auto box manufacturer in Japan. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 25, 2022 Share February 25, 2022 Wait till you use mitsubishi autotrans, then you know what longevity is. 1 Link to post Share on other sites More sharing options...
Atonchia Supersonic February 25, 2022 Share February 25, 2022 54 minutes ago, Hamburger said: Wait till you use mitsubishi autotrans, then you know what longevity is. Mitsubishi gear box also bad? I also heard many complains on VW and Audi ones ↡ Advertisement Link to post Share on other sites More sharing options...
