teomingern Supercharged October 26, 2023 Share October 26, 2023 (edited) Yup correct... total bill is $3000+, got to change everything... whole shock absorber assembly plus power steering rack (reconditioned) plus lower control arm plus drive shaft... plus bonnet support struts... all original parts... Enough to pay for a family holiday somewhere... Edited October 26, 2023 by teomingern ↡ Advertisement 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 26, 2023 Share October 26, 2023 On 10/24/2023 at 8:27 PM, teomingern said: Anyone can recommend a good workshop west side? Maybe within the Toh Guan area? My car developed a clunking sound on the right front wheel. I suspect it's a suspension problem. I brought it to an AutoServ workshop at the Shell nearest my place and the mechanic hoisted the car, use his mobile phone torch and looked around. Then he came to me and said just change the entire front suspension. Quoted me $1540 for both sides, shocks, mounting, bumper, cover, link, etc. And he also said cos the car is wet, he can't really tell if the shock was leaking. So I said I come again tomorrow to let you check cos I was not willing to change everything if only 1 part is spoiled. He said ok can just change the link and see if it helps. So eh... does this smell fishy? Or is this standard for workshops? I used to have a trusted mechanic who will diagnose and just replace the worn part but he's retired... so have to look for somewhere trustworthy... I don't mind paying but I don't want to just change if the mechanic doesn't really do any checking... just visual... Let me know if you have any recommendations or any thoughts on the encounter above... I have very little experience with workshops cos I always used my old mechanic... so a little handicapped here... Thanks in advance! Torch light plus eye power...liddat I also can be a TCM lokun...aga aga try this and that to see if it helps...oh oh...remember to drink more water... 😁 1 2 Link to post Share on other sites More sharing options...
teomingern Supercharged October 27, 2023 Share October 27, 2023 Got my car back... waited over an hour cos the boss was determined to sort out a clunking sound which he attributed to the new steering rack installed (reconditioned)... didn't manage to sort it out today... so he asked for me to bring the car back to sort it out... 1 Link to post Share on other sites More sharing options...
taracarroll Neutral Newbie January 4, 2024 Share January 4, 2024 Choosing a workshop for your car repair and maintenance work is a very tricky thing, I believe in the mouth of words - if we ask several people and according to their experience, they suggest the same name of workshop then I can choose it. You also need to choose a company-specific workshop so that you can easily complain in case of bad repair work about it and raise your issues which can tackle. Next, you can also choose Workshop according to your insurance provider company so that there are two parties involved and you don't need to bear extra pain for all of your repair works. Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 2, 2024 Share March 2, 2024 This simple mechanic tool will at least help to narrow down the noise generating source . Low investment with high return. Link to post Share on other sites More sharing options...
goostakekk Neutral Newbie March 11, 2024 Share March 11, 2024 Car Repair and Maintenance: Regular maintenance and timely repairs are essential for keeping your car in top shape. Whether you drive an SUV, convertible, or hatchback, certain tasks are crucial. Here are some key aspects of car care: Tires: Regularly check tire pressure and tread depth. Consider all-weather tires for versatile conditions. Oil Changes: Follow the manufacturer’s recommended intervals for oil changes. High-quality synthetic oils can prolong engine life. Brakes: Monitor brake pads and replace them when needed. Properly functioning brakes are critical for safety. Battery: Inspect the battery for corrosion and ensure proper connections. Learn how to jump-start your car if needed. Body Work: Address dents and dings promptly. Car window tinting can also be a good idea. Tools: Familiarize yourself with car jacks, torque wrenches, and other essential tools. Remember, a well-maintained vehicle lasts longer, performs better, and uses less fuel. Don’t ignore warning lights or recommended maintenance schedules. For quality American auto parts and accessories, you can explore the All American Parts online shop https://allamerican-parts.com/de . Keep your ride running smoothly! Link to post Share on other sites More sharing options...
MT1972 Neutral Newbie January 14, 2025 Share January 14, 2025 Sent my 7 years old BMW G30 for servicing and engine mount replacements. Car went to workshop with no errors or engine check light. Car was running fine. After 3 days, Workshop owner called me saying engine check light is on after replacing engine mountings. Took him another 3 days to remap the ECU which he charges me $480. Says engine check light is on and need me to replace coolant tank as level sensor is faulty. I had a low coolant level warning a month ago, so sensor was working fine before!. Had to replace radiator flaps (which was faulty for more than 3 years, stayed open and never registered any engine check light. All in all lost usage of my car for 1 week, additional bill of $1400 for this "engine check light" that was non existence when i sent in my car. I seriously believe their mechanic messed up or they are just taking me for sucker! Experts, please comment. Greatly appreciate your thoughts.... Link to post Share on other sites More sharing options...
yorixoj Neutral Newbie April 12, 2025 Share April 12, 2025 Skipping service can lead to costly issues, and it may impact resale value. Whether it’s an oil change, brake check, or annual maintenance, don’t cut corners. Always go to an authorized Ferrari service center. Link to post Share on other sites More sharing options...
2clean Neutral Newbie May 16, 2025 Share May 16, 2025 @oppyouknowme ✨ Bring Your Car’s Shine Back to Life! ✨ Looking for the ultimate paint correction services in Calgary? 🚗 2Clean Inc. offers professional-grade Paint Correction and Paint Protection Film (PPF) services that restore your vehicle’s finish to a showroom shine — and keep it that way! 🔧 What We Offer: ✅ Multi-stage Paint Correction – removes swirl marks, scratches, & oxidation ✅ Paint Protection Film (PPF) – long-term defense against rock chips, road salt & UV rays ✅ Custom detailing packages tailored to your car’s condition 💎 Protect your investment and boost resale value with expert detailing trusted by Calgary car owners. 🔗 Book Your Service or Learn More 📍 Located in Calgary | Trusted. Professional. Passionate. Let your car reflect who you are — spotless, sharp, and stunning! Link to post Share on other sites More sharing options...
WAKE Neutral Newbie May 29, 2025 Share May 29, 2025 Simple repairs may only require an OBD2 scanner to easily find the fault. For example, if your check engine light is on or you need to reset the oil change light after changing the oil yourself, an OBD2 scanner can help you find the cause of the fault. For more information about the problem of the check engine light coming on, you can read this article. I hope it is useful. Link to post Share on other sites More sharing options...
ValuationNinja Internal Moderator May 29, 2025 Share May 29, 2025 Hey everyone! Just wanted to share about Sgcarmart Car Care for your car maintenance needs. If you need car servicing (engine oil change), petrol discount or towing (Singapore & Malaysia), this package has got you covered 😎 All these for only $99 (before GST) ➡️ Discover more details on this page! https://www.mycarforum.com/index.php?app=sponsoredevent&ev=sgcarmartcarcare Link to post Share on other sites More sharing options...
Beregond Supersonic July 3, 2025 Share July 3, 2025 Dun believe too much on reviews🤣 https://www.channelnewsasia.com/singapore/sgcarmart-fake-5star-reviews-ai-chatgpt-lambency-detailing-cccs-5217806 Car detailing firm admits to posting fake AI-generated 5-star reviews on Sgcarmart in first such case Quantum Globe, the owner and operator of Lambency Detailing, admitted to submitting the ChatGPT-written reviews using their customers' information without their knowledge and consent. “This is the second fake review case that CCCS has uncovered, and the first case involving both a third-party platform and the use of AI to create these fake reviews," said CCCS chief executive Alvin Koh. 1 1 Link to post Share on other sites More sharing options...
Kklim Supercharged November 18, 2025 Share November 18, 2025 Just had lower control arms and steering rack bushes replaced in Malaysia. Fewer klok klok sounds from undercarriage and car handles better 2 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear December 4, 2025 Share December 4, 2025 My regular workshop recommended to replace my front lower control arms at next service due to bushings wear. Should I also replace other front suspension components during the same job? E.g. shock absorbers, toe arms and/or other linkages? 1 Link to post Share on other sites More sharing options...
Beregond Supersonic December 4, 2025 Share December 4, 2025 On 12/4/2025 at 9:47 AM, boonhat_91 said: My regular workshop recommended to replace my front lower control arms at next service due to bushings wear. Should I also replace other front suspension components during the same job? E.g. shock absorbers, toe arms and/or other linkages? If your car is old. All those stuff never change before. And u still intent to drive many years. Then 1 shot go loh Absorber mount and bearing. Plus absorber. Stabiliser link and stabiliser Bush. Plus lower arm and ball joint if have. That's about it. 2 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear December 4, 2025 Share December 4, 2025 On 12/4/2025 at 10:21 AM, Beregond said: If your car is old. All those stuff never change before. And u still intent to drive many years. Then 1 shot go loh Absorber mount and bearing. Plus absorber. Stabiliser link and stabiliser Bush. Plus lower arm and ball joint if have. That's about it. 7.5 years 130k km considered old? If I minimally intend to drive until coe ends (renew if wallet allows) it should be still worthwhile to change all those I suppose. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Sin Heng Long Motor Work: High-quality Accident Repair & Respray, Customised Spray Painting service at Reasonable Price and Minimun downtime From Professional Mechanics & Automotive Experts
Catalyst converter issue
Free Service & Repair Manuals for Users of myCARFORUM
