13177 Hypersonic May 29 Share May 29 On 5/29/2026 at 7:51 AM, Tkseah said: Car servicing doesn't have to be great lah.. but I wan AD that will honour the warranty if something spoils, rather than finding excuses claiming this and that is wear and tear not covered by warranty etc... This is why now AD can offers 7-10 years warranty also no scare, cause whether can claim or not, they cannot confirm. ↡ Advertisement Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 2 Share June 2 Not sure if this is something most owners knew about. My family members were irritated by the constant beeping of the seatbelt warning for the back seas. So, they just plug in the seatbelt to silent it. Then I get this notification on the dashboard on power hold and SOC 10% thing. Without truly understand it, I acknowledged. When I got out of the car, although the car lock, the Aircon and media continue to run. After doing some research, the 'Power hold' was meant for if driver leaves the car and passengers continue to stay inside, the Aircon and media can be switched on till battery reached 10%. Although my back seats were empty, due to the seatbelt, the car recognize them as seated. So need to watch out this. Hope it helps. 1 4 Link to post Share on other sites More sharing options...
Ake109 Supercharged June 2 Share June 2 On 6/2/2026 at 1:14 PM, Victor68 said: Not sure if this is something most owners knew about. My family members were irritated by the constant beeping of the seatbelt warning for the back seas. So, they just plug in the seatbelt to silent it. Then I get this notification on the dashboard on power hold and SOC 10% thing. Without truly understand it, I acknowledged. When I got out of the car, although the car lock, the Aircon and media continue to run. After doing some research, the 'Power hold' was meant for if driver leaves the car and passengers continue to stay inside, the Aircon and media can be switched on till battery reached 10%. Although my back seats were empty, due to the seatbelt, the car recognize them as seated. So need to watch out this. Hope it helps. Similar issue on my Sealion. I plug in the rear belts permanently to disable the beep, but if the car detects the rear belt clipped in, will disable the easy-access feature where it moves the driver seat back for easier access when you unlock. Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 2 Share June 2 (edited) On 6/2/2026 at 1:52 PM, Ake109 said: Similar issue on my Sealion. I plug in the rear belts permanently to disable the beep, but if the car detects the rear belt clipped in, will disable the easy-access feature where it moves the driver seat back for easier access when you unlock. Indeed need time to learn new technology and their thinking. 😆 Honestly, the ideas are there, just need to adapt and understand how to max them. This car is quite challenging turning tight older multi story car park ramp. Probably due to the width. Length wise doesn't seem that long but some car parks, I hard have much room for error. Edited June 2 by Victor68 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 2 Share June 2 On 5/29/2026 at 10:49 AM, inlinesix said: Mini is the best for warranty claims. At the end of 2nd year, I asked SA to check car battery. Car battery was replaced under warranty. but you pay huge markup. i think if i self import, and ownself warranty will still be cheaper. Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 2 Share June 2 On 6/2/2026 at 2:34 PM, Mkl22 said: but you pay huge markup. i think if i self import, and ownself warranty will still be cheaper. I bought "management unit" with 2k km (real or not i don't know). So far, i only know Porker self-import. Link to post Share on other sites More sharing options...
Lala81 Hypersonic June 2 Share June 2 On 6/2/2026 at 1:14 PM, Victor68 said: Not sure if this is something most owners knew about. My family members were irritated by the constant beeping of the seatbelt warning for the back seas. So, they just plug in the seatbelt to silent it. Then I get this notification on the dashboard on power hold and SOC 10% thing. Without truly understand it, I acknowledged. When I got out of the car, although the car lock, the Aircon and media continue to run. After doing some research, the 'Power hold' was meant for if driver leaves the car and passengers continue to stay inside, the Aircon and media can be switched on till battery reached 10%. Although my back seats were empty, due to the seatbelt, the car recognize them as seated. So need to watch out this. Hope it helps. Isn't this a good safety feature to have? How to get older folks to buckle up. I get my kids to help them do it. 1 Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 2 Share June 2 On 6/2/2026 at 2:51 PM, Lala81 said: Isn't this a good safety feature to have? How to get older folks to buckle up. I get my kids to help them do it. Indeed a good feature and we should make a point to practice it. It is just that sometimes, in our context, it is just less than 3 km from point A to B, we tends to feel unnecessary. Link to post Share on other sites More sharing options...
Tkseah Turbocharged June 2 Share June 2 On 6/2/2026 at 2:27 PM, Victor68 said: Indeed need time to learn new technology and their thinking. 😆 Honestly, the ideas are there, just need to adapt and understand how to max them. This car is quite challenging turning tight older multi story car park ramp. Probably due to the width. Length wise doesn't seem that long but some car parks, I hard have much room for error. Luckily u didn't get Sealion 7 which is even wider and longer than Aion V.. 3 Link to post Share on other sites More sharing options...
Ake109 Supercharged June 2 Share June 2 On 6/2/2026 at 3:23 PM, Tkseah said: Luckily u didn't get Sealion 7 which is even wider and longer than Aion V.. Lucky got the 360 camera lor. If not, some parking and tighter kerbs, I will also stress. Esp. since the rear visibility is KNS. 1 1 Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 2 Share June 2 On 6/2/2026 at 3:57 PM, Ake109 said: Lucky got the 360 camera lor. If not, some parking and tighter kerbs, I will also stress. Esp. since the rear visibility is KNS. Very true, I am virtually inches away for both the front and back. Either my turning angle/radius is wrong or it is just like that. The 360 provides me the guide to go forward. Link to post Share on other sites More sharing options...
Tkseah Turbocharged June 2 Share June 2 On 6/2/2026 at 3:57 PM, Ake109 said: Lucky got the 360 camera lor. If not, some parking and tighter kerbs, I will also stress. Esp. since the rear visibility is KNS. My BIL buying the im6 which is even wider and longer than sealion 7.. hopefully he didn't overestimate his driving skills.. 😆 5 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 2 Share June 2 On 6/2/2026 at 1:14 PM, Victor68 said: Not sure if this is something most owners knew about. My family members were irritated by the constant beeping of the seatbelt warning for the back seas. So, they just plug in the seatbelt to silent it. Then I get this notification on the dashboard on power hold and SOC 10% thing. Without truly understand it, I acknowledged. When I got out of the car, although the car lock, the Aircon and media continue to run. After doing some research, the 'Power hold' was meant for if driver leaves the car and passengers continue to stay inside, the Aircon and media can be switched on till battery reached 10%. Although my back seats were empty, due to the seatbelt, the car recognize them as seated. So need to watch out this. Hope it helps. Buy some seatbelt buckle clips/extenders and plug them in so that the system will think that seatbelt is put on. 1 1 Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 2 Share June 2 On 6/2/2026 at 6:27 PM, DOBIEMKZ said: Buy some seatbelt buckle clips/extenders and plug them in so that the system will think that seatbelt is put on. Yeah have thought of that too but currently just fasten the seatbelt also work the same. For distance driving, still better to buker-up 1 Link to post Share on other sites More sharing options...
13177 Hypersonic June 2 Share June 2 On 6/2/2026 at 4:09 PM, Tkseah said: My BIL buying the im6 which is even wider and longer than sealion 7.. hopefully he didn't overestimate his driving skills.. 😆 Many people buy first then see later if they can handle the car or not. Lol. Link to post Share on other sites More sharing options...
13177 Hypersonic June 2 Share June 2 On 6/2/2026 at 3:23 PM, Tkseah said: Luckily u didn't get Sealion 7 which is even wider and longer than Aion V.. Looks like Sealion 7 no problem for many people, since you see tons of Sealion 7 on the road. Link to post Share on other sites More sharing options...
13177 Hypersonic June 2 Share June 2 On 6/2/2026 at 2:27 PM, Victor68 said: Indeed need time to learn new technology and their thinking. 😆 Honestly, the ideas are there, just need to adapt and understand how to max them. This car is quite challenging turning tight older multi story car park ramp. Probably due to the width. Length wise doesn't seem that long but some car parks, I hard have much room for error. You are driving Aion V? Nowadays most cross over and SUV, They have wide width which indeed quite stressful to maneuver in some carparks. Your driving skills must be perfect, if just a little bit out, your car would get scratches or dents. Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 2 Share June 2 (edited) On 6/2/2026 at 9:04 PM, 13177 said: You are driving Aion V? Nowadays most cross over and SUV, They have wide width which indeed quite stressful to maneuver in some carparks. Your driving skills must be perfect, if just a little bit out, your car would get scratches or dents. Yes just got it recently. Length wise it is about the same as my previous one, Mazda 3. However, it is wider and higher. I think a little more practice to get use to. Older car park are generally narrower and parking space with columns including those with hose reel are to avoid. Edited June 2 by Victor68 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
