Yeobh 4th Gear February 14, 2008 Share February 14, 2008 Do you bring yr own mee, egg, oil etc to ask yr friendly neighbourhood hawker to cook for you. PS Do not forget your bring yr own plates spoon and fork.Mother of all cost cutting in actions. ↡ Advertisement Link to post Share on other sites More sharing options...
Jkcs Neutral Newbie February 15, 2008 Share February 15, 2008 When it comes to servicing, many MCForummers only mentioned abt changing of EO, EO filter (or spark plugs too) and labour charges. what abt other maintenance checks e.g. Check (23-point) * Engine, Drive Belts & Power Train * Cooling System * Electrical * Air-Conditioning * Steering & Chassis * Brake & Clutch * Exhaust this is a part from CDGE premium servicing package. I am neither advertising for them nor their employee I find their package also quite expensive but if they really do all the checks, I feel it's still worth it.. I jus feel that other checks are as impt as changing of EO etc. any views on this? Many thanks! Link to post Share on other sites More sharing options...
Mivec9 1st Gear February 15, 2008 Share February 15, 2008 $450 for Brake....this is . U shld burn down the shop. Most Brake pads + Fluid Bleeding + Services job under $165. but this workshop is recommended by u? a bit contradicting.....u with them or against them? Link to post Share on other sites More sharing options...
Mivec9 1st Gear February 15, 2008 Share February 15, 2008 If you bring your own oil to CAS, they will use the lowest service package $48 - $10 = $38. So if you buy oil from Trex101 and service at CAS, it is cheaper than using CAS supply M1 oil. is the lowest now 58 bucks in CAS? Link to post Share on other sites More sharing options...
Newsman 1st Gear February 16, 2008 Share February 16, 2008 Use them ONLY for $62 Cheapo Lub Service. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged February 16, 2008 Share February 16, 2008 I feel that, in most cases, those 23-point (or 100-point, etc) are useless....unless you know something about cars (in which case, you can do most of the check except for those undercarriage ones), or are there to see them do all the checks. In most case, they will just 'look-see' at best. Most will just tick all the check-box. I feel that, best to to find a reliable workshop and stick to it. The good ones will do the checks as part of the servicing. Link to post Share on other sites More sharing options...
Jkcs Neutral Newbie February 16, 2008 Share February 16, 2008 i do agree with u on the part whereby some WS mechanic will just look look see see then put a tick in the checklist. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 16, 2008 Share February 16, 2008 If you are not trained as a mechanic with inspection ability , you can try to look and see but you just see technically nothing is wrong.Simple Visual inspections can be done by any layman. Link to post Share on other sites More sharing options...
Droozy Neutral Newbie February 16, 2008 Share February 16, 2008 Then bro.. u hv any reliable workshop that you always go to for your servicings ? Can share with me . Thanks ! Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie February 16, 2008 Share February 16, 2008 (edited) Edited February 16, 2008 by Ahdi Link to post Share on other sites More sharing options...
Chihuahua Neutral Newbie February 16, 2008 Share February 16, 2008 If Bukit Merah area, I would recommend this Cheong Motors Tel 62709848 (Meng) Blk 1005 Bt Merah Lane 2 #01-14 S(159761) Give them a call to fix appt.... Link to post Share on other sites More sharing options...
Droozy Neutral Newbie February 16, 2008 Share February 16, 2008 oh thanks.. wat are the charges like ? Have to wait very long after fixing appt ? Link to post Share on other sites More sharing options...
Chihuahua Neutral Newbie February 16, 2008 Share February 16, 2008 If you buy or bring your parts then just fix the date/time...dont have to wait long one... But if you want them to supply the parts then let him (Meng) know your car model and type of oil etc you need.... his labour charge is "flexible" - last time I pay him like 20-40 bucks... Link to post Share on other sites More sharing options...
Droozy Neutral Newbie February 16, 2008 Share February 16, 2008 oh thanks bro for your lovely tips Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 17, 2008 Share February 17, 2008 When it comes to servicing, many MCForummers only mentioned abt changing of EO, EO filter (or spark plugs too) and labour charges. what abt other maintenance checks e.g. Check (23-point) * Engine, Drive Belts & Power Train * Cooling System * Electrical * Air-Conditioning * Steering & Chassis * Brake & Clutch * Exhaust this is a part from CDGE premium servicing package. I am neither advertising for them nor their employee I find their package also quite expensive but if they really do all the checks, I feel it's still worth it.. I jus feel that other checks are as impt as changing of EO etc. any views on this? Many thanks! If e basic knowledge of car maintenance is there, u can DIY all e above.Its not tat hard.cheers Link to post Share on other sites More sharing options...
Tohto Hypersonic February 19, 2008 Share February 19, 2008 (edited) If you bring your own oil to CAS, they will use the lowest service package $48 - $10 = $38. So if you buy oil from Trex101 and service at CAS, it is cheaper than using CAS supply M1 oil. is the lowest now 58 bucks in CAS? Ya, their servicing price had gone up already. My last service last Sep with them still $48. This morning check is $58 already . Now my car due for servicing again. How is Riverview in AMK? Anyone used this workshop? Edited February 19, 2008 by Tohto Link to post Share on other sites More sharing options...
Mivec9 1st Gear February 19, 2008 Share February 19, 2008 i also checked...58bucks is without plugs Thanks! Link to post Share on other sites More sharing options...
Decrez Neutral Newbie March 27, 2008 Share March 27, 2008 I have friend working in Comfortdelgo. have been doing there for quite sometime. I find them very efficient, work smart and most importantly proper system. But waiting can be a hassle. so you got to chose the non-peak hour. morning of monday and wednesday. changing of oil, oil filter, Nology plug from CHEZ REpulic(special request need) only at 199. if normal plug 99. workshop at ubi. BEST! ↡ Advertisement Link to post Share on other sites More sharing options...
Battery warranty , must we service with distributor?
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Any good private driving instructor to recommend?
