Tea3 Neutral Newbie December 29, 2004 Share December 29, 2004 Is it possible to lower the car without having to change the suspension? ↡ Advertisement Link to post Share on other sites More sharing options...
Silver_blade Turbocharged December 29, 2004 Share December 29, 2004 Yes, especially if your shocks are still new. But a set of matching shocks will give you car a better ride. Link to post Share on other sites More sharing options...
Tea3 Neutral Newbie December 29, 2004 Author Share December 29, 2004 Was thinking of cutting cost while cutting height of car too. Link to post Share on other sites More sharing options...
Soya Supersonic December 29, 2004 Share December 29, 2004 a set of eibachs will do the job nicely. Link to post Share on other sites More sharing options...
Tea3 Neutral Newbie December 29, 2004 Author Share December 29, 2004 Hmmm....how much is eibachs? What about sach? Link to post Share on other sites More sharing options...
Soya Supersonic December 29, 2004 Share December 29, 2004 sachs is a whole kit >$1k. eibachs will set u back abt $400-$500. generally changing the whole spring and damper is ideal but eibachs are pretty good on it's own. Link to post Share on other sites More sharing options...
Accordvtec 1st Gear December 29, 2004 Share December 29, 2004 Is it possible to lower the car without having to change the suspension? get lowering springs lor... Tein Espelir Eibach bear in mind that your camber will be out...tyres will have uneven wear.... Link to post Share on other sites More sharing options...
Assassin Clutched December 29, 2004 Share December 29, 2004 Just dont cut springs can liao. Link to post Share on other sites More sharing options...
Tea3 Neutral Newbie December 29, 2004 Author Share December 29, 2004 Watched Monster Garage on Discovery Channel & what the mechanic did was heat the suspension so hot & join a segment of the coil together. I don't think I can cut it lah. Link to post Share on other sites More sharing options...
Tea3 Neutral Newbie December 29, 2004 Author Share December 29, 2004 Oh... didn't know that lowering will cause the camber to be out... Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 29, 2004 Share December 29, 2004 a set of eibachs will do the job nicely. yap, best in the business Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 29, 2004 Share December 29, 2004 Just dont cut springs can liao. but some workshop still recommend that Link to post Share on other sites More sharing options...
Str2 Neutral Newbie December 29, 2004 Share December 29, 2004 Technically speaking, u cannot cut the springs as the first two coils of both ends are for seating the springs.There is a tendency for the springs to dislocate and it's a disaster waiting to happen depending what speed u r driving. It is a no-no.....U hv to get shorten springs. The workshop will tell u its Ok cos they will get money for cutting yr springs. Link to post Share on other sites More sharing options...
Evolve Neutral Newbie December 29, 2004 Share December 29, 2004 I'm interested to know why as well, since I'm considering lowering springs, not the shocks as well... by changing springs, camber would be out? How does that happen? Link to post Share on other sites More sharing options...
Accordvtec 1st Gear December 29, 2004 Share December 29, 2004 I just found out not too long ago...by lowering the springs,the camber angle will be out & tyres will eat inwards... Link to post Share on other sites More sharing options...
Genie47 1st Gear December 29, 2004 Share December 29, 2004 Now you know! Get camber bolts to adjust camber. I believe JB tire/wheel alignment shops have them depending on the popularity of your make. Else you can get very expensive ones from K-MAC. Link to post Share on other sites More sharing options...
Accordvtec 1st Gear December 29, 2004 Share December 29, 2004 got meh? tot must buy the camber kit @ $300++ think Kenny of Riverview said can modify current camber...@ $180 or so... Link to post Share on other sites More sharing options...
Genie47 1st Gear December 29, 2004 Share December 29, 2004 The freaking bolts are expensive. Unless you can find those that are manufactured in Malaysia. Usually costs MYR40-80 for one. If your car has suspension systems that require both front and back, more money needed. Cars with beam axle rear suspension need only the front set. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota wish 2017 lowering springs
Urgent advise needed on Lowering Spring + stock Spring setup
Lowering Spring
Lowering Spring
Lowering your ride? hmm....
Lowering Springs for SX4
Lowering land cost is like dipping into reserves: Mah
Coilover lowering based on whose finger?
ADVICE needed on lowering latio ride
