Lowering
Tea3
You drive Accord? If yes, front and back suspension needs them or else your tire wear is going to be uneven if you lower your ride plus use of low profile tires.
So does that mean one must spend more money for the camber kit after spending on, for example, eibachs? unimpressed.gif
If shorten springs are used, camber angle is changed very slightly and no serious uneven wear (height reduced in 25-30mm).Probably more pronounced tyre wear if height reduction in 60mm range and by then yr car becomes a dragster.
Camber Angle and Toe-In/Out are not the same thing.
My few peanuts worth.
Camber is tilting of the wheel when looking from front wheel, whereas toe is tilting (something like we humans who walk toe-in/out) when looking from top of car, right? tongue.gif
I know they are not the same thing. What I am saying is that all cars allow toe adjustment but not all cars allow camber adjustment. In fact most cars don't have camber adjustment.
Is it possible to lower the car without having to change the suspension? cool.gif
get lowering springs lor...
Tein
Espelir
Eibach
bear in mind that your camber will be out...tyres will have uneven wear....
i have a set of espelir on a lancer..... a whole world of difference from the original springs........tauter progressive springs and a nicer look...installation includes wheels alignment ..
Edited by Ohlins
used to....4 years back...
Technically speaking, u cannot cut the springs as the first two coils of both ends are for seating the springs.There is a tendency for the springs to dislocate and it's a disaster waiting to happen depending what speed u r driving.
It is a no-no.....U hv to get shorten springs.
The workshop will tell u its Ok cos they will get money for cutting yr springs.
yap, some workshop do that for $$$, I prefer to use Eibach Prokit thumbsup.gifthumbsup.gifthumbsup.gif
Oh, another thing I forgot to add is that when shorten springs are used, some folks recommend that shorten shocks absorbers need to be used for best performance.
(if not,standard OEM shocks will be 'pressed' down close to their bottom limit and sometimes bottoms-out under heavy load).
If u look at SACHS or BILSTEIN lowering boxed kits, the shorten springs and shocks come as a set).
Rgds/Str2
if budget is not a prb, the ideal way is to install a complete set of coil over dampers..... about 1k can get quite a good set......
however, spring lowering kits are about half the price....
many ppl have said life span of stock shocks will suffer when lower springs are used. not too sure about that as i have not experienced any bottoming since the springs are in...the springs are progressively wound.....offering a softer rate for a short travel while becoming stiffer as they are compressed more...
anyway, i would definitely at least going for the springs......so much better to drive...the stock springs are like.....really crap......far too soft..
yes, but if you are using those that only lowers about 20 to 30mm (as in Eibach Prokit), you still can use the stock shocks, that is if they are relatively new & not worn out yet, of course the life span of the stock shocks will be reduced wink.gifwink.gifwink.gif
however, if you are using those that lowers more than 30mm (as in Eibach Sportline) than you'll need to replace the stock shocks with those after market ones, ie Koni Yellow (sport). wink.gifwink.gifwink.gif
SACHS/BILSTEIN suspensions sets do comes with the springs & matching shocks, however, I have friends that find that the shocks of the SACHS Touring suspension kids to have very short life span sweatdrop.gifsweatdrop.gifsweatdrop.gif. OBTW, the springs in SACHS suspension sets are made by Eibach sly.gifPosted ImagePosted Image
