Review On E68
Genew
i've installed 1,hyundai accent02,it all depends on u,u wanna fly or just have a better pick up?my pickup improved after installing,tune the screw to a certain amount n it will show,but every few months must wash.sparkplug using iridium denso.if wanna fly then might as well change the whole car to F1.hehe!!!cheers!
It bypasses the intake sensor only. Whatever comes out from the exhaust is not bypassed. OBDII is designed for emissions controls. Whatever comes out that is different will send the signals to get the AFR back to what it is supposed to be.
Edited by Genie47
Mean? I've been giving out warning signals for snake oils don't tell me I have to give out warning to people to stay away from hallucinogens. laugh.gif Or is it that the side effect of snake oil is hallucinations of seeing your car turn into an F1 racer? laugh.gif
Maybe this is Singapore. Our automotive laws here are crippling. So crippling that people need to escape in the form of snake oils. Just like people need to escape from reality with mind altering drugs. So in the case of drivers using snake oil, perceived performance gains that are far from reality.
I think it is not religion anymore, maybe it is a "drug" to feed the masses and the peddlers are no different from drug pushers feeding on the weak-minded.
Edited by Genie47
Yep. Once AFR is correct for the extra air from E68, you should feel better power for the same throttle position. What can you ask for $150 and probably passes LTA?
$150 can buy petrol. How much better power? To get faster at the same throttle position? That is but a grand illusion to be better than the fine automotive engineering the manufacturer put into the automobile. That's the bottom line isn't, to be better than all the wonderful automotive engineers from Gottlieb Daimler till now. Plain vanity isn't it? The gain in power is just an illusion. The reason they pass LTA is because LTA knows they all cosmetic like spoilers. laugh.gif
Drivers got to realize that this is Singapore. It sucks. These devices suck to give you sucked up gains or worse, just plain suck.
The final argument for all these contraptions is this. Why didn't the fine automotive engineers put it into their automobiles?
Don't give me any silly conspiracy theories on this. If it really is a fuel saver or give more power they would have done it. It is American automotive policy to meet CAFE. It is their policy to meet emission standards. It is European policy to meet emission standards. So why didn't cars come with them in the first place?
all these "magic stones or snake oils" worked for older cars, but nowadays newer cars ECU will cancel out any fuel savings, so what u get is better throttle response which Genie termed as as "illusion". Well, this has effect on stock N.A. cars, but when performance mods are in, these gadgets have no or little effect. [:p]
the only reason LTA allows it to be sold is becos it does not add significantly to the power which most pple r seeking.
asides from this, u should b fully aware that such air bleeders actually introduces unfiltered air into the combustion chamber? a UOA will undoubtably show up more silica content.
no.. i am not comfortable with the fact that the so-called "filter" inside the E68/ AirMax is there, cos it is not made by a reputable firm tat has knowledge what a proper filter should do. for $150.... how much does an engine box cost?
if u want more air for the car, save the $150 and take out the air filter fr ur filterbox, remove the entire filter box. there's definitely more air coming thru the bigger hole. no point adding a little more air.
So any gadget that can yield extra power...LTA will not allowed. [shakehead]
Eg. Muffler(whether operated or non-approved one), remove cat, extractor, swap to bigger cc engine etc.
the word is "significant" power.
but if u r prepared to keep $500 in ur dashboard, u can lup a turbo also.
kena caught just pay fr dashboard lor.
Interesting to know from you LTA allow only non-performance gadgets. Seems you are not aware filter for E68 are already selling.
Perhaps, removing the resonator box suitable noisy cars if you know what I mean.
[shakehead]
Lets keep an open mind here.
E68 WORKS, no doubt about it.
- How ? By putting in extra air , bypassing the ECU reading, thus getting leaner A/F raito
E68 DOES NOT WORK LONG TIME in NEW CAR, no doubt about it.
- Why ? New cars have have sensor monitering the intake and exhaust, once the ECU detects that there is difference in the lambda reading, it'll try to adjust. So usually, after some time (5~10days), the ECU will have adapted and everything will be BACK to SQUARE 1.
So now,
How can you get E68 to work for a longer period of time?
- Simple, reset your ECU every now and then lor....until one day your ECU siao liao, and run close-loop forever.......
In my humble opionion, i rather save the money and put in V-POWER once in a while :P
