Genew Neutral Newbie January 22, 2005 Share January 22, 2005 Any one has installed E68 ? How does it work and how much benifits does it bring ? Reluctant to install products which have little or no effect.... ↡ Advertisement Link to post Share on other sites More sharing options...
XLR8 1st Gear January 22, 2005 Share January 22, 2005 Dont waste money. Link to post Share on other sites More sharing options...
Melvinch Neutral Newbie January 22, 2005 Share January 22, 2005 The E68 did improved my pickup a little on my Mondeo. Guess it depends on what car u driving. Link to post Share on other sites More sharing options...
Optra Neutral Newbie January 22, 2005 Share January 22, 2005 I have different view. why keep money to make yrself itchy ? $128 with installation at Mcwell ubi will solve yr itching. is just like buying 4d, got buy got chance no buy hopeless. if u have the buget, why not ? Link to post Share on other sites More sharing options...
Xavier Neutral Newbie January 22, 2005 Share January 22, 2005 I think it is subjective on different car. My honda seems to have no effect. Maybe its the tuning thingy. You got to check with fellow Aveo buddies whether is that any effect.. Link to post Share on other sites More sharing options...
Genew Neutral Newbie January 23, 2005 Author Share January 23, 2005 hmmmm....some claim that it works wonders but other claim it has absoultly no effect lehz.....how how.... pocket not very deep these few days.... Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 23, 2005 Share January 23, 2005 if pocket not very deep, then better done buy it, IMHO Link to post Share on other sites More sharing options...
Genie47 1st Gear January 23, 2005 Share January 23, 2005 (edited) If pocket not deep, don't buy. These things are what they call air bleeders. They bleed air into the intake manifold. In petrol combustion, you need 14.5 parts of air to 1 part of petrol. The ratio is measured by what most engineers call Lambda. Lambda > 1 = rich mixture. Lambda < 1 = lean mixture. Cars run very very well when using a 0.9Lambda which is 10% excess fuel. The excess fuel is basically wasted. Expelled as exhaust. The air flow sensor be it MAP or MAF measures this air coming in and adjusts the fuel needed accordingly. Now with a bleeder device like E68, this air coming in is not measured. So the combustion could run 10% leaner. Way back in the 70s when this came about, it really saved fuel but of course you can do the same if you have a carburetted car and you tune it to run lean. But now these devices are hopeless because of emission controls. Cars now are mostly OBDII. Has sensors at the intake and sensors in the exhaust. In the Aveo, 2 sensors. One at the exhaust manifold and the other after the cat converter. Now if the E68 adds in additional air into the combustion process, the exhaust will be different. Remember, what goes in must come out. The exhaust sensor senses the difference and gets the ECU to compensate. In the end, no difference. See this website for details: http://www.fuelsaving.info/air_bleed.htm So if your car is OBDI with no sensor at the exhaust and no cat converter (Toyota 1.6L GLi with its 4A-FE engine comes into my mind), these devices will work to a certain extent. I believe the older Mazda 323 is also OBDI. On the Aveo with GM's ETECII, forget it. BTW, you do know that the ETECH stands for Emissions TECH. Also you got to note that most engines have EGR. It means Exhaust Gas Recirculation. See the Technical Resources folder for more info. Basically, that 10% unburnt fuel is recycled back into the engine to be burned. Usually happens when you are on overdrive. Again the ECU compensates. Short of hacking the ECU, you cannot fool it. Edited January 23, 2005 by Genie47 Link to post Share on other sites More sharing options...
Apollo 1st Gear January 23, 2005 Share January 23, 2005 Reluctant to install products which have little or no effect.... Blush u already sum up the sentiments.. if it is good, car makers will put it as a standard for engine damn car they sell, cos that is a "plus" for customers who wants better fuel economy. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 23, 2005 Share January 23, 2005 No. If really got effect, I will hear black helicopters flying over my flat to the inventor's house and next day news, inventor mysteriously disappeared. Link to post Share on other sites More sharing options...
Hattee Neutral Newbie January 23, 2005 Share January 23, 2005 Not true for you said "Now if the E68 adds in additional air into the combustion process, the exhaust will be different. Remember, what goes in must come out. The exhaust sensor senses the difference and gets the ECU to compensate. In the end, no difference." With more air and corresponding more fuel after ECU correction - what is the output power for the same throttle position now? Link to post Share on other sites More sharing options...
Optra Neutral Newbie January 23, 2005 Share January 23, 2005 Soory.. end of the day worth to intall one ? Link to post Share on other sites More sharing options...
Melvinch Neutral Newbie January 23, 2005 Share January 23, 2005 Aiyah, install lah. End of the day u don't like it, lugi only $100+ what. I was also skeptical like u b4, but I cannot tahan the slow pickup from my Mondeo. So I say to myself what the heck go for it lah, LPPL what. Feel the throttle improved but wanted more, so added Supersprint exhaust and K&N 57i. Wah lagi shiok after that ! IMHO you need all the varous mods together to give u a significant improvement. BTW what car u driving ? Link to post Share on other sites More sharing options...
Optra Neutral Newbie January 23, 2005 Share January 23, 2005 (edited) That is the way bro ! Chevy Optra no mod yet. Edited January 23, 2005 by Optra Link to post Share on other sites More sharing options...
Genie47 1st Gear January 23, 2005 Share January 23, 2005 Remember, this only applies to OBDII and not OBDI. There will be changes in OBDI but OBDII cancels everything out. So for the same throttle position on OBDII, you get the same thing. Link to post Share on other sites More sharing options...
Genew Neutral Newbie January 23, 2005 Author Share January 23, 2005 Genie, what are the mods in the market that have been tested and proven ? I've installed grounding, volt stab, cone filter and nothing else..... Link to post Share on other sites More sharing options...
Genie47 1st Gear January 23, 2005 Share January 23, 2005 You want my honest opinion? 1. Displacement upgrade which means engine transplant. 2. Forced induction. The rest are hardly worth it. Just like cosmetic surgery. Breast creams don't get you anywhere. Only implants give noticeable gains. Go to any American or European or Australian forum. They don't talk about air bleeders or magnets. Grounding, yes because it helps electricals. It is always transplants or forced induction or some changes to gear ratio. This for most part unavailable to us because of laws. I've done the above route and the gains you can really feel immediately without a dyno and not some iffy "Uhm, a bit lah." Link to post Share on other sites More sharing options...
Apollo 1st Gear January 24, 2005 Share January 24, 2005 i hv the Specs-R magazine which they always includes a VCD of the taiwan version of PG street race. 2 upgrades r recommended.... TC and total engine blk displacement. ↡ Advertisement Link to post Share on other sites More sharing options...
CNA: S'pore Govt To Review Marriage & Parenthood Policies
M’sia Girl Asks Customer For Restaurant Review Before Entering, Patron Gives Feedback By Shaking Head
Alpina B7 biturbo review
Send in a review of your Subaru and get a Limited Edition Subaru Watch + Shell Car Wash Vouchers
Well played Tripadvisor?
Car reviews by SGCM
Car reviews by SGCM
2020 Top 5 Cars For First Time Buyers
