Fff0 Neutral Newbie October 12, 2006 Share October 12, 2006 err... how abt for new cars with old tech like hyundai accent 05? Heard it uses tech frm old mit engine.... true? ↡ Advertisement Link to post Share on other sites More sharing options...
Fff0 Neutral Newbie October 12, 2006 Share October 12, 2006 Or buy standard and gap every 10k. Throw away by 20-30k. whats gap? Link to post Share on other sites More sharing options...
Fff0 Neutral Newbie October 12, 2006 Share October 12, 2006 ......... Actually the difference is better idling. Plugs affect emissions a lot more than all out performance. For all out performance, Cu is better........ I need more pickup so a copper will be good? any brand and series to recommend? Link to post Share on other sites More sharing options...
Genie47 1st Gear October 13, 2006 Share October 13, 2006 Answer to your questions. Gap is the space between the tip and the ground electrode. As for Accent 05, you got to check. No recommendations. To me all the same but people have preference for NGK or Denso. Link to post Share on other sites More sharing options...
Spenz Neutral Newbie October 13, 2006 Share October 13, 2006 but my ride manualstates "only use iridium spark plugs" so how ???btw i used the SK series (stock iridium for toyota) and fuel consumption is higher and car pickup is sluggish... changed to the ik-20, and now pickup more responsiveand fuel consumption improves....just as good as ngk iridiums (non IX).....next time i order ngks from u ok ? I was considering them all yesterday.. was totally disappointed with the Denso IK16... end up swap back to stock copper ones for $13 for 4 pack.. and my engine is lively again !!!! Prob keep using copper from now.. can change fresh ones 4 times for the price of iridium !?? Link to post Share on other sites More sharing options...
Abba Neutral Newbie October 13, 2006 Share October 13, 2006 If I replace my ride's plugs with performance spark plugs such as NGK or Denso without changing the "sotong-chiu" aka power cables, will there be any difference in performance? Thanks. I stay with either Denso or NGK Platinium plugs, which ever is in stock. I dun find much diff between them but they are very good, consistent spark even for long drives at high speeds along HSHW Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 13, 2006 Share October 13, 2006 how often should one change spark plug cables? mine isn't the sotong head type. 2 cables, split into 2 each to connect to the 4 plugs Link to post Share on other sites More sharing options...
Genie47 1st Gear October 13, 2006 Share October 13, 2006 That is DIS. Theoretically, every 100k must replace. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear October 20, 2006 Share October 20, 2006 Ho bro, How much and where do you install these plugs? I am sending my IS200 for servicing next week. They quoted me $120 for the plugs. Dunno wat brand one leh? Every hoe many K need to change? Tks! Link to post Share on other sites More sharing options...
Crummytyre Neutral Newbie October 20, 2006 Share October 20, 2006 That is DIS. Theoretically, every 100k must replace. Why? Will the cables deteriorate? Link to post Share on other sites More sharing options...
Genie47 1st Gear October 20, 2006 Share October 20, 2006 Yes, they do deteriorate. That is why I am not in a rush to replace my cables when I got my car to high performance ones. When they deteriorate, they will leak current. Happened to me when I was driving the Starlet. Obviously the cables were not changed when I got them for God knows how long. The car was 18yo! Mechanic checked it and found one of the cables leaking current. I'm running at 86k mileage already. Most likely replace next year. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 20, 2006 Share October 20, 2006 so for my DIS type, i can only replace 2 of the cables? the 2 plastic connects directly to 2 of the plugs Link to post Share on other sites More sharing options...
Genie47 1st Gear October 20, 2006 Share October 20, 2006 (edited) Just replace the cable. Buy the cable and get some wiring sifu to re-use your connectors/boots. Of course if you want complete replacement some places sell the entire cable loom with the connectors/boots. It is up to you. FYI, bulk 8.0mm cable at forgot how many feet is just short of USD10. Suggest you look to Kingsborne. They also sell the Beru tools if you want to master the art and become spark plug cable sifu yourself. Edited October 20, 2006 by Genie47 Link to post Share on other sites More sharing options...
Crummytyre Neutral Newbie October 20, 2006 Share October 20, 2006 I'm hitting 100k soon too. So the starlet was using stock cables? 17 years x ave of 20k a year gives 340k of usage, assuming. So why the 100k theoretical reference? Also, does deterioration occur due to the wires, connections, or the rubber housing? Due to heat or vibrations? My apologies for so many questions. Just want to find out as someone posted an old article that shows old stock cables can last much longer than that. Link for the article is given below. http://asia.vtec.net/beystock/tuning/plugcable.html Link to post Share on other sites More sharing options...
Bluemice 2nd Gear October 20, 2006 Share October 20, 2006 hi bro, wats ur damage and can list more details. i m aiming for a chg in my sparkies too. 10s mice Link to post Share on other sites More sharing options...
Genie47 1st Gear October 20, 2006 Share October 20, 2006 Its the operation and the heat. Everything comes in. Yeah they can last longer but you want a potential failure in your hands when you drive? Stock wires are not expensive. Don't get expensive performance once. Stock will do just well. Link to post Share on other sites More sharing options...
Crummytyre Neutral Newbie October 20, 2006 Share October 20, 2006 Thanks for the clarifications. Think I'll hold for a while before replacing them. They still look good to me and still behaving fine. Link to post Share on other sites More sharing options...
Nullbig Clutched October 20, 2006 Share October 20, 2006 (edited) Me too!! Interested to change sparkies and cables too... Coming to 35K liao.. Bro, can PM me place and damage to wallet?? Edited October 20, 2006 by Nullbig ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
Changing of Spark Plugs
RS Chip Tuning
RS Chip Tuning
Tool to change Spark Plug
2023 Mercedes-AMG C63 S E Performance
Consolidation of useless modification (Performance parts)
Goodyear Eagle F1 Asymmetric 5
