Chewy Neutral Newbie September 27, 2006 Share September 27, 2006 Must say it does what it claims. Engine noise is softer, oil temp remains below 100 despite high revving, smooth acceleration all the way to high speeds (CVT, so can feel diff). All these are in comparison to my previous 40wt oil. Previous oil made louder engine noise, temp was hitting 100 most of the time, sometimes even over that mark when I rev a lot, acceleration was always jerky and can't hit high speeds unless high rpm all the way. I'm quite satisfied with the change. Just my personal review. Now waiting for my next servicing to see if this brand can last the 10k km and stay this way. Btw, mine is a TC vehicle so that's why had to use 50wt. ↡ Advertisement Link to post Share on other sites More sharing options...
Luckcent 4th Gear September 28, 2006 Share September 28, 2006 check your specs......30wt is also suitable . Link to post Share on other sites More sharing options...
Sunray Neutral Newbie September 28, 2006 Share September 28, 2006 Mine also a TC car but not CVT though. But my owner's manual stated min W30. W50 may affect your FC. Link to post Share on other sites More sharing options...
Atlantis_boi Clutched September 28, 2006 Share September 28, 2006 U may need an oil cooler to further reduce the temp of ur oil temp. Link to post Share on other sites More sharing options...
Laojiao 2nd Gear September 28, 2006 Share September 28, 2006 Not necessary ... Chewy's ride is using a light-pressure turbo ... that is unless he goes track every now and then! Link to post Share on other sites More sharing options...
Laojiao 2nd Gear September 28, 2006 Share September 28, 2006 Hey chewy Understand that you drive a Colt Plus Turbo? 50wt can also, but do try 30wt - no issues with Light pressure turbos unless u go to track every now and then! Want to find out how good the oil? Do a UOA (Used oil analysis) and you'll be assured how the oil performs IN your engine! Get the UOA kit! You can get it from Trex101 - PM him. cheers! Link to post Share on other sites More sharing options...
Chewy Neutral Newbie September 28, 2006 Author Share September 28, 2006 Ok thanks! Link to post Share on other sites More sharing options...
Chewy Neutral Newbie September 28, 2006 Author Share September 28, 2006 Ya! I think so too! My fuel needle falling faster and faster after I changed oil! Gosh! Will see how bad it is and assess "damage"! Thanks! Link to post Share on other sites More sharing options...
Chewy Neutral Newbie September 28, 2006 Author Share September 28, 2006 Think no need la! Mine ikan bilis turbo only! Never go track also! But may drive up to KL end of year! Still need cooler? Link to post Share on other sites More sharing options...
Chewy Neutral Newbie September 28, 2006 Author Share September 28, 2006 Yes yes! CPT for short! UOA? I not so detailed la! Just want to have a rough gauge can liao! Thanks for the heads up anyway! Btw how you know I drive CPT ah? I never mention in first post leh... Link to post Share on other sites More sharing options...
Georgecheng Neutral Newbie September 28, 2006 Share September 28, 2006 HI, mind sharing how much you got for the oil and where to get. Thanks Link to post Share on other sites More sharing options...
Lexl Neutral Newbie September 29, 2006 Share September 29, 2006 Good choice of brand but not sure if the 10W-50 is the best viscosity selection for your ride if yours is a LPT. I would say a 5W-30 or at most 5W-40 would be better. With a 10W-50 your FC would definitely suffer somewhat especially if you have been using a thinner oil. Based on my own experience with this Xrev brand for 2 oil changes now, the oil should last you 10,000km provided that the mechanic followed the instructions and gave the bottle a good shake before pouring the contents into the engine. This will ensure that all the good stuff (additives) gets into the engine Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear September 29, 2006 Share September 29, 2006 if the bottle needs a shake before it gets poured into the engine, all it means is trouble! if the so-called additives are not able to remain suspended, it'll just get stuck in the oil filter and/or settle right down in the oil sump when the engine is stopped. and when u start up again, the 'additives' are nowhere near critical engine parts, and would prob clog the oil filter. Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 29, 2006 Share September 29, 2006 I can't find X-Rev API license in the API directory... Is it API, ACEA or JASO certify ? btw do you know which company in USA manufacture this oil? Link to post Share on other sites More sharing options...
Atlantis_boi Clutched September 29, 2006 Share September 29, 2006 (edited) Think no need la! Mine ikan bilis turbo only! Never go track also! But may drive up to KL end of year! Still need cooler? I'm not sure how hot the oil wuld get when travelling for long distances at high speed. 1 of my friend told me he added an oil cooler to his Colt Plus Turbo & his oil temp is reduced frm 90+ degree to 70+ degree Edited September 29, 2006 by Atlantis_boi Link to post Share on other sites More sharing options...
Genie47 1st Gear September 29, 2006 Share September 29, 2006 (edited) Actually the oil cooler is not necessary when your car is not even modded even if it is turbocharged. BTW, oil is supposed to be "at home" at a temperature closer to 100 degC. The oil sump pan below is already a cooler by itself. Pretty good already. Even if you are concerned with the hot weather we have. For every 1 degC in ambient, the contribution to the oil temp is 0.3 degC assuming there is no cooler. Edited September 29, 2006 by Genie47 Link to post Share on other sites More sharing options...
Lexl Neutral Newbie September 29, 2006 Share September 29, 2006 I had initial concerns too. But when I checked up on this, it seems that the additives is fully liquid ie no suspension and therefor no possibility of clogging the oil filter. Just that it is heavier than the base oil, so it will settle. Once you get it into the engine, it bonds to the metal sufaces. I have noticed the difference when you do shake the bottle - the oil is thicker when the additives are well mixed. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear September 29, 2006 Share September 29, 2006 if the 'additives' are heavier than the base oil, then the chemistry is wrong. no engine oil should ever need to be shaken before being poured into the engine. ↡ Advertisement Link to post Share on other sites More sharing options...
LATEST!!! Just out dictionary for new bengs
Just passed my PPCDL, wats next???
Just for laughs
Just for laughs
Football is just not in Chinese's DNA
Severe headache after changed lens
I just did DIY oil change
Car tremble after battery changed!
Just came back from JB,is it cheap?
