My CNG conversion
Genie47
Compressed natural gas is not liquid. It can never be liquid. Only when frozen it becomes liquid but it will be called LNG.
OK. Cos I read that at the pumping station it is cooled till liquid for storage. That means it is in gaseous form in the car. Like that the amt able to store in the tank/s in the car wil b very limited.
If it's kept at 200bar, then the pressure is very high. [shocked] That means another problem is leaks or explosion if the tank is damaged in a crash or due to old age & wear & tear. [sweatdrop]
I think like that, petrol is a safer option then. [nod]
The way I feel is CNG is still very new & chances of things happening is higher then petrol or diesel. Maybe I'll consider it at a much later stage once all the bugs have been worked out.
Friend Diving gear also 200BAR lahhh ...
200BAR = 200ATM = 2,840psi????? [sweatdrop][sweatdrop][sweatdrop]
Petrol burns more readily actually. It is a liquid and will coalesce meaning form pools around.
One thing for gas is that you need an enclosed space. There was a horrible gas accident in Brazil I think. Some gas leaked out of a pipeline and into some building basement. Some gas engineers went to investigate and then kaboom.
So there was an investigation. They wanted to know if the gas was from a company's pipeline. The gas is synthetic town gas. Meaning it has propane in it. Propane is heavier. The other theory is that there is natural gas seaping out of the underground causing the explosion.
The explosion caused a beam in the building to bend upwards so they know it came from below so it is a heavier gas. So they concluded it is a leaking gas pipe from the gas company instead of natural gas. If it is natural gas, the beam would have bent downwards because it would have coalesce into the ceiling and exploded on top.
imagine that tank supposed to last a diver 40-50 mins underwater... [;)]
those SCDF breathing apparatus set bottle even smaller, but charged to 300 bar [dizzy][dizzy]
Hi, i'm keen to get a CNG camry for my next car...what would be a good tank configuration for maximum fuel tank capacity? say 1x YY (kg) or 2 x ZZ (kg) tanks...? am prepared to sacrifice half the boot space in exchange for higher tank capacity..thanks.
ya lor. I saw the increased price...wahlau....now reduce the savings for ppl using CNG liao. Somemore they are setting up more pumps at residential areas like serangoon north....
Currently the waiting time for CNG installation is like 3 months! sigh. Very sian. Should have went for it much earlier.
My plans for CNG:
1) Install CNG for a 7yo W210 kompressor. Hopefully can use similar parts like the E200 NGT. Currently checking with Melchers.
2) Scrap my 323 and buy Axio or Airwave with CNG.
btw, I don't think we have a sticky for CNG yet. As it's getting more and more popular, I think it's beneficial to even have a folder for this......
Yeah, understand that the waiting time to install is 3months and more, very long wait. However, I'm aware that there is going to be one more installer in a couple of weeks time. Will update where the new workshop will be located at. Cheers!
Start on petrol but idle on petrol or CNG is entirely your call.
Aiya...i think i ask wrongly previously.
What i mean is after collecting a new CNG car, for the 1st 1000km to 5000km mileage, should i run on CNG or petrol first.
Will it cause any maintenance issue if CNG is use for the beginning, hope the sifu can share some advise.
Thanks
it should be RM$0.68 per litre. You may want to advise how to convert between price per litre and price per kg. Tks.
so u now know petrol even more dangerous
Er....I wud think CNG is more dangerous. Petrol is under very low pressure only. If tank leak, it only spill on the ground & even then it's hard to ignite.
CNG leak, any naked flame will cause it to ignite. [shocked]
cxxxxxe waiting for you [flowerface]
Hi buddy. I got the contact for this guy selling RP so I think I'll get a couple of qts of 10w40 & use up all my balance stock of engine oil & ATF at me next service.
I'll prob get CL for the service after that. No point wasting the stuff I still have in my store.
Heart pain to throw away all that good oil. Like throwing away $$$$$. [nod]
Anyway, thanks so much for your help. Maybe I can return the favour 1 day. [:)]
1 scuba tank sud last abt 30 mins. Did some diving long long ago.
The BA tank also abt 30mins IIRC. I have taken the BA course b4. Long long ago.
Edited by Pisces69
I saw the Camry taxis using a large cylinder plus a small one at a 60-70 degree angle off the main one. Looks like a 70L plus 30L. Awesome capacity but no space above for whatever ICE mods I think.
Spy on them to have an idea.
The one setting more filling stations is SembGas. They have not increased price at all! FYI SMART Energy and SembGas get gas from two different sources. SMART Energy uses boleh gas. SembGas gets the gas direct from Indonesian gas fields.
SMART Energy has always been more expensive than SembGas.
Hi all, saw a 'CNG' decal sticked on the windscreen in my carpark...there was no 'CNG' sticker on the bumper...is decal permissible? Would be great then...nicer look. [laugh]
Guest
